Datsun 1200 Coupe used different badges than the Sedan, for the most part.
1972 Facelift
Coupe got new grille badges and boot badges for the 1972 Facelift.
For the individual badges, see: * #Front Grille badges * #Rear Center emblem * #Rear Right mark
Radiator Grille
Japan market
Center Ornament
Coupe emblem - screws arranged diagonally
Left: #boot badge | Right: #grille badge
#62312-H1826 Export 'D' emblem
#62312-H1825 Japan 'S' badge
1972 #62312-H4025 Center ornament - Winged 'S'
NOT THIS: similar badge -- but with knurled edges -- is the #Rear Center badge.
Custom Ornaments
Late-model Nissan hamburger badge
280Z ornament installed on 1200 coupe grille by club member Datsunbeginner
'S' Ornament
62312-H1825 SET-ORNAMENT radiator grille "S" early Coupe
Red, White, Blue badge colours
'D' Ornament
62312-H1826 SET-ORNAMENT radiator grille "D" Coupe Export
'S' Ornament (winged S)
The famous 'winged-S' was used on all 1972 Datsun 1200 Coupes, including Deluxe, GL, and GX. This is due to the facelift minor change.
62312-H4025 ORNAMENT-radiator grille 1972 Coupe winged-'S'
Although it look near-identical to the rear badge, they are not interchangeable.
Grille badge - diagonal screws | #Rear badge - level screws
Fits any plastic 1200 grille -- meaning it bolts to the early coupe and the mid-model 1200 truck (1978-1989)
Although from the factory it only was applied to coupes, it can be modded to fit on a Sedan Grille:
Grille Trim Badge
Trim badge was placed on left side of JDM grille. USA coupes had no trim badge.
NOTE: the base version (STD/Standard) has no front-mounted trim badge. Neither did DX/Deluxe.
GL
62330-H2026 EMBLEM-'GL' (same as early sedan GL badge)
GL 1972
62330-H3325 1972 EMBLEM-'GL' [not set in a block] (same as Facelift Sedan Badge)
GX
62330-H2325 SET-MARK 'GX' (same as early sedan GX badge)
grille badge has long studs for mounting through the grille
compare to late (1972) sedan (compressed font)
compare to rear see-through badge
GX5
62330-H7225 1972 EMBLEM-'GX-5SPEED' COUPE, SEDAN
Quarter
Badges placed on quarter panel (rear fender).
Export
76854-H1600 EMBLEM-'DATSUN' BODY SIDE-rear (same as sedan)
Japan Market
Japan market (all differ from sedan)
#78841-H1800 EMBLEM-'Sunny' model badge
DX #78842-H1800 EMBLEM-'Coupe'
GL #78842-H2201 EMBLEM-'Coupe GL'
GX #78842-H2400 EMBLEM-'Coupe GX'
78841-H1800
78841-H1800 EMBLEM-'Sunny' model badge, rear side
78842-H1800
78842-H1800 EMBLEM-'Coupe' [fitted to DX coupes] rear side
78842-H2201
78842-H2201 EMBLEM-'Coupe GL' rear side
78842-H2400
78842-H2400 EMBLEM-'Coupe GX' rear side
Has a satin finish behind black 'coupe', and a striated finish behind white-inset 'GX'
Rear
Japan badges all differ, and includes GL and GX trim badges
Automatic
79200-H1020 MARK-"Nissan Full Automatic" [script style] (to '71-March) 79200-H2820 MARK-"NISSAN FULL AUTO MATIC" [block style] (from '71-April) 79855-N2200 MARK-NISSAN AUTOMATIC USA COUPE ONLY
#79200-H2820 MARK-"NISSAN FULL AUTO MATIC" [block style] (from '71-April)
#79855-N2200 MARK-NISSAN AUTOMATIC USA COUPE ONLY
Nissan Automatic
79855-N2200 MARK-NISSAN AUTOMATIC USA COUPE ONLY * 5.75 inches wide * USA Datsun 510 from 1971 June (3N71B)![]()
Placement: trunk lid left side
79200-H2820
Also used by Excellent 1400 (see PB110 Badges#79200-H2820
NOT THIS: non-1200 'Nissan Matic' is blue 84821-U0300 from Datsun 610
NOTE: mounting studs broken off
Right Side
- Export coupes had a "DATSUN 1200" badge; Japan-market coupes had a trim badge
- DX — the base model coupe — had no trim badge
Rear Model
Export coupes had a rear model badge.
USA & Australia 'DATSUN 1200' diagonal
84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID COUPE <> 84822-H1856
GL Rear Trim Badge
84823-H2001 Japan trim badge GL [1970-1971] (same as Sedan badge)
84823-H3300 Japan trim badge GL MARK 'GL' [1972] (same as Sedan badge)
GX Rear Trim Badge
84823-H2300 1970-1972 Japan trim badge GX MARK 'GX' (same as Sedan badge) Used in Japan and South Africa markets.
GX5 Rear Trim Badge
84823-H7200 1972 Japan GX 5-Speed (same as Sedan badge)
Rear Center
Rear badge versus Front badge. Rear has segmented edge, is thinner and fits over the rear panel crease
Center round 'D' badge - #Export Center round 'S' badge - #Japan
NOT THIS: Sedan Grille Badges are not entirely round
Export Rear Center
79202-H1825 SET-ORNAMENT, rear panel
79202-H1826 SET-ORNAMENT, REAR PANEL COUPE <> 79202-H1825
Japan Rear Center
Rear Center 1972
79202-H4025 ORNAMENT SET-rear panel
Winged 'S' badge - 1972 JDM Facelift
Rear badge - level screws | #Grille badge - diagonal screws
