Datsun 1200s came with different types of seats, depending on the market. Front seat style include: fixed, tilting (folding) and reclining. The coupe rear seat folds down. Different trim levels got different materials, namely vinyl or vinyl with cloth inserts. Sedan and Coupe seats generally differ in the cut and level of support padding. Some market like Australia produced seats locally. Head restraints were optional in some markets, but standard in USA.
Stock Seats
1972 USA Owners manual (see pages 4-5 for Seat information):
The rear [Coupe] seat area may be quickly and easily converted into baggage space when needed.
USA models:
- 1973 models had blue or beige seats. Black was available (again) on from 0173
- 1971-1972 models:
- Coupe: Black, Beige or (optional) Yellow
- Sedan: Black, Yellow, Gray
- Reclining seats standard on coupe
- Sedan had folding non-reclining seats with (optional) reclining seats
- Sedan had some sort of optional front seats
Head Rests
- 1971, 1972: Black 87700-H1001
- 1973: Blue 87700-H7000 or Beige 87700-H7001
USA Coupe
Stock Seats
Stock headrests
Standard, Deluxe and Reclining Seats
1200 Coupe seats (custom fabric) in Datsun 1000
Parts
- 86982-A0600 Eyelet 'A' Seat Back $1.12
- 86983-A0600 Eyelet 'B' Seat Back $0.85
- 87550-H1603 Slide-seat LH $44.33
- 87500-H1603 Slide-seat RH
- 87400-M3000 Hinge-recline RH $179.58
- 08310-81410 SCREW-MACHINE M8X1.25 SLIDE FIX TO FLOOR
- 08310-81812 SCREW-MACHINE M8X1.25 [Seat Frame] FRAME FIX TO SLIDE
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors.
TRIM-SEAT RISER, RH
- 74961-H1100 7510-7803 BLACK
- 74961-G1060 7804-8910 DARK BROWN
- 74967-95W00 8910- GRAY
TRIM-SEAT RISER, LH
- 74962-G1000 7510-7803 BLACK
- 74962-G1060 7804-8910 DARK BROWN
- 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
- 66919-H1001 7510-7803 BLACK
- 66919-G1060 7804-8910 DARK BROWN
- 96815-B0700 8910-
Alternative Seats
Recaro Seats
Recaro is the premium automobile seat company.
Custom Upholstery
Racing Seats
Seat Rails
Just unbolt the rails from your seats and bolt them to the new seat:
Seat Slide (aka Seat Rail)
Dimensions - Bolt holes To floor
- Side to side: 15-11/16 inch
- Front to back: 12-3/16 inch
- The famous Bride rails for Sunny Truck
- 200 mm seat travel fore-to-aft
Late Sunny Truck with converter bulge 1989-up
Left seat Dimensions - Bolt holes To floor
- Front to back (left side): 12-3/16 inch
- Front to back (right side) goes 1-1/2 farther back, and 1-1/2 farther forward compared to left side
- slanted tabs
- 15-1/2" at base, 16-1/4" at bottom edges
- front tab: 1-7/16" long
- rear tab: 1-3/8" long
- slanted tabs
Bride B122 Part Numbers
- LH: code N030VO type V*1 TTM-L No. 939063
- RH: code N029VO type V*1 TTM-L No. 939064
- V type: for Bride full bucket, 30 mm height
- S type: for Bride reclining seat
- VF type: for Bride full bucket, no slide (fixed position)
Adapting Seats
B210* seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat:
* early B210 seats fit B110 directly * late B210 seats have a non-flat bottom
If you don't have the B110 rails, you can adapt B210 or B310 slides:
Modifying B310 brackets to fit B110 chassis
Many, many other seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Chassis Brackets - for flat seat runners
Account and pictures of how to adapta Civic seats: http://forum.ratsun.net/showthread.php?t=776
Rear Seats
See Rear Seat
Australia Legalities
