Tension Rod
Revision as of 02:01, 23 August 2011; view current revision
Tension Rod, also known as compression rod, strut rod, or caster/castor rod. Sometimes called a radius rod.
The tension rods keep the front wheels located fore/aft.
It is the lower bar in this photo:
With bushes in place:
  • 54470-H1000 Tension Rod R.H
  • 54471-H1000 Tension Rod L.H
Bushes
Nissan Competition
Experimental Engineering Tension/Compression Rod Bearing Kit. This kit fits: All 510, 610, 710, B210, 240Z, 260Z, 280Z, 280ZX, S12 200SX, & Z31 300ZX thru 7/87. This kit includes all parts neccesary for one car, a 'U' shaped gauge for setting pre-load, and complete instructions.
The T/C Kit eliminates all rearward movement of the front wheels caused by bushing deflection. At the same time it reduces the amount of force required for the T/C rods to pivot during suspension travel by 75% vs. stock rubber and by up to 95% vs. polyurethane bushings. This is accomplished by replacing the forward bushings on the tension/compression rods (aka: strut rods) where they attach to the chassis with pivoting ball & socket joints. These joints completely eliminate all rearward deflection under driving, cornering, and braking loads. This insures that castor remains constant and toe changes under heavy braking and cornering loads are very nearly eliminated.
612.jpg 614.jpg 1264.jpg 2042.jpg 3200.jpg 3201.jpg 3866.jpg 6391.jpg 6716.jpg 7150.jpg 8711.jpg 8712.jpg 8713.jpg 8758.jpg 9433.jpg 11907.jpg 12593.jpg 12653.jpg 15218.jpg 15865.jpg 16591.jpg 20794.jpg
