Tension Rod
Revision as of 03:45, 23 August 2011; view current revision
Tension Rod, also known as compression rod, strut rod, or caster/castor rod. Sometimes called a radius rod.
The tension rods keep the front wheels located fore/aft. It forms one leg of the virtual lower A-arm. The LCA forms the other leg of the "A".
1974 and later tensions rods have a different bolt spacing at the end, to match the updated bolt pattern on the 1974 and later LCAs.
The tension rod is the lower bar in this photo:
With bushes in place:
Red poly bushings for a stiffer ride
  • 54470-H1000 ROD-TENSION FRONT SUSPENSION RH
  • 54471-H1000 ROD-TENSION FRONT SUSPENSION LH
  • 54470-H7200 Tension rod R.H 1974 to 7910
  • 54470-H8500 Tension rod R.H 7911-
54472-18000 WASHER-SPECIAL TENSION ROD -7910
54472-H8500 WASHER-THRUST TENSION ROD 7911-
54630-H1001 COLLAR-BUSH TENSION ROD
08915-44210 WASHER-PLAIN M12
08912-34210 NUT-HEX SELF LOCK M12
Also see Ball Joints for the two bolts that fix the Tension Rod to the ball joint & LCA.
Bushes
JAPAN
Early B210
 54474-H5000 ROD ASS'Y-tension, front suspension (R.H.)
 54475-H5000 ROD ASS'Y-tension, front suspension (L.H.)
Late B210 Van 1075-, sedan/coupe 1275-
 54474-H7400 ROD ASS'Y-tension, front suspension (R.H.)
 54475-H7400 ROD ASS'Y-tension, front suspension (L.H.)
54472-18000 WASHER-special, tension rod (4)
54630-H1001 COLLAR-bush, tension rod (4)
54476-H1001 BUSH-tension rod (4)
08915-44210 WASHER-plain (2)
08912-34210 NUT (2)
NORTH AMERICA (HLB210, fits PB210 LCA)
54474-H5900 ASSY-ROD,TENSION RH
54475-H5900 ASSY-ROD,TENSION LH
54537-21003 WASHER-SPECIAL (4)
54479-21000 COLLAR-BUSH TENSION ROD (2)
54476-21000 BUSH-TENSION ROD (4)
08915-54210 WASHER-PLAIN (2)
08912-34210 NUT-SELF LOCK TYPE N M12 (2)
B310
54470-H8500 ROD-TENSION,FRONT SUSPENSION RH
54471-H8500 ROD-TENSION,FRONT SUSPENSION LH
54472-H8500 WASHER-SPECIAL TENSION ROD TO BRACKET (4)
54630-H1001 COLLAR-BUSH,TENSION ROD TO BRACKET (2)
54476-W5000 BUSH-TENSION ROD TO BRACKET (4)
08915-44210 WASHER-PLAIN (2)
08912-34210 NUT-HEX,SELF LOCK TYPE (2)
Body brackets, which are welded to the front side member (front rail)
74830, 74831
54532-H1001 BRACKET-SUSPENSION ROD, RH
54533-H1001 BRACKET-SUSPENSION ROD, LH
Nissan Competition
Experimental Engineering Tension/Compression Rod Bearing Kit. This kit fits: All 510, 610, 710, B210, 240Z, 260Z, 280Z, 280ZX, S12 200SX, & Z31 300ZX thru 7/87. This kit includes all parts neccesary for one car, a 'U' shaped gauge for setting pre-load, and complete instructions.
The T/C Kit eliminates all rearward movement of the front wheels caused by bushing deflection. At the same time it reduces the amount of force required for the T/C rods to pivot during suspension travel by 75% vs. stock rubber and by up to 95% vs. polyurethane bushings. This is accomplished by replacing the forward bushings on the tension/compression rods (aka: strut rods) where they attach to the chassis with pivoting ball & socket joints. These joints completely eliminate all rearward deflection under driving, cornering, and braking loads. This insures that castor remains constant and toe changes under heavy braking and cornering loads are very nearly eliminated.
612.jpg 614.jpg 1264.jpg 2042.jpg 3200.jpg 3201.jpg 3866.jpg 6391.jpg 6716.jpg 7150.jpg 8711.jpg 8712.jpg 8713.jpg 8758.jpg 9433.jpg 11907.jpg 12593.jpg 12653.jpg 15218.jpg 15865.jpg 16591.jpg 20794.jpg
