Tail lights, tail lamps, or as Nissan calls them "rear combination lamps", combines the running lights, brake lamps (stop lights) and turn-signal lamps (blinkers). USA lights have no yellow section as it was forbidden by US law in the 1970s.
| Contents |
Troubleshooting
Inoperative rear taillights, Turn Signal lights, or brake lights? Check for adequate grounding/earthing of the plastic combination lamp assembly.
1. Check the metal-to-metal contact of the ground wire (black) from the right side tail light assembly at teh grounding post on the panel inside the trunk area. Remove any paint or dirt that prevents good contact
2. Using an ohmmeter, check the ground wire (black) from the harness in the engine compartment to the battery negative post for continuity to the instruments and lights of the vehicle. If continuity is lacking, repair the break or replace the wire
3. A heavy gauge ground strap connecting the engine to the body of the vehicle assures proper grounding. The ground strap is built into the original negative battery cable
Sedan
Japan and USA tail light have Red blinkers, instead of Yellow/Orange
Australia and Euro lenses have Orange for the blinkers
HOUSING (available as Assembly)
- 26550-H1001 ASS'Y-LAMP, rear combination (R.H.)
-  26555-H1001 ASS'Y-LAMP, rear combination (L.H.)
- 23W bulb (2 per side)
- 23/8W (1 per side)
- 3W (1 per side)
- 26552-H1001 ASS'Y-RIM (2) $38.82 USD
- 26553-H1000 ASS'Y-PACKING (2) $18.33 USD
- 26551-H1001 ASS'Y-LENS (R.H.) NLA
- 26556-H1001 ASS'Y-LENS (L.H.) NLA
- 26563-H1000 ASS'Y-HARNESS (R.H.)
- 26568-H1000 ASS'Y-HARNESS (L.H.)
- 26550-H1902 ASSY-LAMP REAR COMBNATION RH(ICHIKHO) $143.10 USD
- 26550-H7000 ASSY-LAMP REAR COMBINATION RH FROM 0772 $143.10 USD
- 26555-H1902 ASSY-LAMP REAR COMBNATION LH(ICHIKHO)
- 26555-H7000 ASSY-LAMP REAR COMBINATION LH FROM 0772
- 26551-H1902 ASSY-LENS RH RED-RED-WHITE (ICHIKHO) $35.63 USD
- 26556-H1902 ASSY-LENS LH RED-RED-WHITE (ICHIKHO) $35.63 USD
- 26563-H1600 ASSY-HARNESS,R.H NLA
- 26564-H1600 ASSY-HARNESS,L.H NLA
- No 3W bulb
Facelift
1972 Japan-market models had new tail lamps:
- 26550-H3101 LAMP ASS'Y-rear combination (R.H.)
-  26555-H3101 LAMP ASS'Y-rear combination (L.H.)
- 23W bulb (4)
- 23/8W bulb (2)
- 3.4W bulb (2)
- 26552-H3101 RIM ASS-Y (2)
- 26553-H3101 PACKING ASS'Y (2)
- 26551-H3101 LENS ASS'Y (R.H.)
- 26556-H3101 LENS ASS'Y (L.H.)
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim.
3-bulb Type vs 4-bulb Type
Custom
Wagon
1000
See main article: B10 Lights
Pickup
Datsun 1200 (Pickup) has three-segment rear lamps:
- Bottom section is clear for backup lights, 23W single filament bulb
- Middle section is red for running lights, 23W/8W dual filament bulb
-  Top section is for turn signals: Red for older ones, Yellow or newer models.
- 23W single filament bulb, same as bottom section
- Aftermarket clear lenses are available, which use color bulbs
The lens frames were offered in various styles:
- Chrome through 1978 March
- Black from 1978 April
- 1971-1977: were originally silver
- 1978-1989: changed to black
Wiring early - Spade connector
Wiring late - Pin connector (positive locking)
- 26563-G1000 HARNESS ASSY-REAR COMBINATION -7803 [spade connectors]
- 26563-G1060 HARNESS ASSY-REAR COMBINATION 7804-8608 PIN CONNECTOR
- 26563-G1900 HARNESS ASSY-REAR COMBINATION -8608
Right Hand
- 26550-G1001 LAMP ASSY-REAR COMBINATION, RH -7803 [chrome]
- 26550-G1060 LAMP ASSY-REAR COMBINATION, RH 7804-8608 [black]
-  26550-G1900 LAMP ASSY-REAR COMBINATION, RH 8608- [black]
- 08310-41620 screw, 8 needed per side
- 26521-G1000 LENS-COMBINATION LAMP, RH [top lens]
- 26541-G1000 LENS-REVERSE LAMP, RH [bottom lens]
- 26561-G1001 LENS-COMBINATION LAMP, TAIL & STOP, RH [Japan, middle lens]
- 26552-G1000 RIM-COMBINATION LAMP, RH [Chrome] -7803
- 26552-G1060 RIM-COMBINATION LAMP, RH [Black] 7804-
- 26553-G1000 PACKING-LAMP, RH [gasket]
Left Hand
- 26555-G1001 LAMP ASSY-REAR COMBINATION, LH -7803 [chrome]
- 26555-G1060 LAMP ASSY-REAR COMBINATION, LH 7804-8608 [black]
-  26555-G1900 LAMP ASSY-REAR COMBINATION, LH 8608- [black]
- 26526-G1000 LENS-COMBINATION LAMP, LH [top lens]
- 26546-G1000 LENS-REVERSE LAMP, LH [bottom lens]
- 26566-G1001 LENS-COMBINATION LAMP, TAIL & STOP, LH [Japan, middle lens]
- 26557-G1000 RIM-COMBINATION LAMP, LH [Chrome] -7803
- 26557-G1060 RIM-COMBINATION LAMP, LH [Black] 7804-
- 26558-G1000 PACKING-LAMP, LH [gasket]
Export
JDM vs Export
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
Semi-Clear
Custom
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
North America Notes
Canada generally adopts the same standards as USA.
USA "Federal Motor Vehicle Safety Standard No. 108 [1968] allows rear turn signals to be either red or amber in color... amber signals show a 5.3% effectivenss in reducing involvement in two-vehicle crashes where a lead vehicle is rear-struck in the act of turn left, turning right, merging into traffic, changing lanes, or entering/leaving a parking space. The advantage of amber rear turn signals is shown to be statistically significant." -- NTSHA document.
Nevertheless, amber was slow in coming. Even in the 1990s red rear turns signals are commonplace. The Nissan Altima even changed three times, from Amber to Red to Amber and back to red.
"In Europe and many other countries, rear turn signals are required to be amber. Currently [2009], manufacturers ... [for] North American markets choose whether to produce [amber or red rear turn signals]." -- NTSHA document.
