Lighting System
Revision as of 04:54, 17 May 2012; view current revision
Lamps, lights. Parking lights, running lights. Whatever you call them, Datsun 1200s have them.
Also see:
27.jpg North America lights
Headlights
Large round headlights from *any* car will fit. These are type 6012/6014 for a two-headlight system (a single large round headlight on each side of the car). These are "dual beam" lights (two-filament), encompassing both regular and high-beam in the same light.
Note that the original specification 6012 headlamp is only 50W/40W. You can substitute the brighter 6014 which is 60W/50W. Type 6015 is a longer-life bulb, but more expensive.
USA 1972 Owners manual (see page 36 for headlight specification):
Alternatively, and recommended, H6024 (65W/35W) is a halogen replacement. Halogen is a brighter light, and now available in shades of blue, gold, white. Street-legal in USA.
The brighter 6014 is as inexpensive as $3. See RockAuto headlights for Datsun 1200
Type Spec. Comments
6012 50/40 watt Original spec.
6014 60/50 watt replaces 6012
H6014 60/50 watt Halogen
6015 60/50 watt long-life
H6024 65/35 watt Halogen
H6024 XV 65/55 watt Extra-bright, long life
See Lamp Part Numbers
High-power Headlamps
H4 euro-type, Halogen, etc that require upgraded wiring.
2962.jpg Halogen
Side Markers
  • Side markers/lamps come in two sizes: small and large
Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged.
9856.jpg USA - Large running lights
2301.jpg Other countries - Small running lights
See main article: Side Lamps
Front Lights
See Front Combination Lamp
Rear Lights
Rear light lenses are either:
  • orange-red-white, white-red-orange
or
  • red-red-white, white-red-red
Orange & red: Australian market, while all-red in America, Japan and South Africa markets.
1549.jpg Sedan (USA)
10520.jpg Sedan (Australia)
Coupe: long and thin. Sedan: short but tall:
9806.jpg Coupe vs Sedan Comparo
Coupe:
7034.jpg Australia
8570.jpg America
10207.jpg Coupe closeup
5164.jpg Wagon and Sedan (Australia)
1524.jpg GL Sedan (Japan)
2851.jpg ute
638.jpg Van (Australia)
47.JPG Sedan (portugal)
2842.jpg Sedan (Europe) - orange blinkers
9857.jpg Sedan (USA) - red blinkers
Later GLs used a different taillight:
    1972 GL
Possibly it was the same as Coupe or PB110, but with a different trim surround:
  • 757.jpg 1972 PB110
Rear License Plate Lamp
For USA market, the rear number plate light changed in 1973 to meet higher government standards of illuminating the plate.
Early license plate lamp (on top of bumper):
Late license plate lamp (dual lamps on either side of plate):
Customized Lights
  • Square headlights
  • Quad headlights
  • Clear lamp lenses
  • All-red rears
  • White-outside rears
  • Coupe rear lights on Sedan
  • Supra lights on Coupe:
Driving Lights
fog lights, etc
Operation
Headlight Switch
10046.jpg See: Instrument and Controls#Switches
Turn Signal Switch
T/S switch
Interior Lamps
The middle position operates from the door switches (if equipped).
5036.jpg interior "dome" light
USA 1972 Owners manual (see page 6 for Interior Lamp):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
13404.jpg int. lamp switch
3401.jpg alternative interior headliner light
Replacing Procedure
USA 1972 Owners manual (see pages 36-38 for replacing details):
headlights:36.jpg front & rear:37.jpg
license lamp & side lamps:
Dash Lamps
Seven Meter lamps fit in the seven black holders with the white dots on them
Type 161 Lamps - twist lock (in this photo have white dots)
Lamp Specifications
  Spec. SAE No. Nissan^
Headlight unit 12V-50/40W 6012 see above
Direction and Parking 12V-23/8W 1034 26717-89920
Side marker 12V-8W 67 26715-89902
License plate 12V-7.5W 89 26715-89901
Rear combo. Light
Taillight
Stop (brake)
Turn signal
Back-up light
12V-23/8W
12V-23/8W
12V-23W
12V-23W
1034
1034
1073
1073
26717-89920
26717-89900
Meter illumination 12V-1.7W (round gauge) 161 26711-89900
Wiper Knob illumination (1973) 12V-3.4W 158  ?
Heater control ill. (1973) 12V-3.4W 57  ?
Ignition warning 12V-1.7W 161 26711-89900
Turn Signal indicator 12V-1.7W 161 26261-89902
Headlight beam ind. 12V-1.7W 161 26711-89900
Oil press. warning 12V-1.7W 161 26711-89900
Brake warning 12V-1.7W 161 26711-89900
Room light 12V-10W n/a 26736-89902
^from USA catalog, all are ICHIKO brand
USA 1972 Owners manual (see page 36 for bulb specifications):
  1. Exterior single element, one bottom contact
    Rear T/S (turn signal)
    23 watt (North America) Sylvania 1156 Wagner 1156
    21 (other countries)
  2. Exterior dual element, two bottom contacts
    Front park & T/S, Rear Tail & Stop
    23/8W (North America) Sylvania 1157 Wagner 1157
    12/5 watt (other countries)
  3. FUSE, 10-AMP (2 needed) 08941-11000
  4. FUSE, 15-AMP (4 needed) 08941-11500
  5. 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
  6. Dome lamp - 10 watt (room lamp) 26736-89902
    • Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w
    • Parts stores specify the larger unit (see above Wagner 12100, Sylvania DE3175) which is readily available
  7. Instrument Panel lamp with twist-lock holder (7 used in round dash)
    26260-89900 Wedge Socket (7 total for round gauge) $3.28 each
    • 1.7 watt bulb (ROUND GAUGE) 26261-89902
    • 3.4 watt (Square Gauge) Type 158 14V
    • NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V
  8. Exterior Lamp
    • Side-marker lamp
      • 8 watt (North America, non-flashing)
        Wagner 97 Sylvania 97 (9.32 watt nominal)
      • 6 watt (flashing, non-North America)
    • License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
      10 watt (Sedan, except North America)
      7.5 watt Coupe, Van 26715-89901 Ichikho
      7.5 watt Sedan USA
    • Reverse light - 10 watt
  9. Instrument Panel Turn Signal indicator (2 needed)
