Tunnel
Revision as of 02:03, 14 February 2013; view current revision
Categories: Body | Transmission | Automatic Transmission
Datsun 1200 originally fitted with automatic transmission has a much larger tunnel. It makes it easier to swap in 5-speeds or larger engines.
manual transmission
  • 67300-H1000 ASS'Y-PANEL, dash, lower [manual transmission]
  • 74300-H1010 ASS'Y-FLOOR, front [manual transmission]
  • 67300-H1021 ASS'Y-PANEL, dash, lower [automatic transmission]
  • 74306-H1020 ASS'Y-PANEL, A/T floor cover, front [automatic transmission]
  • 74300-H1021 ASS'Y-FLOOR, front [automatic transmission]
Manual floor cover (normally not a separate piece) vs auto floor cover
18963.jpg Comparo
Manual Tunnel is very small to fit the small stock transmissions and increase space inside the passenger compartment:
Tunnel Swaps
Auto Tunnel Swap
Auto tunnel is very large to fit the 71-series Automatic Transmission, but still fits under the heater box.
Auto Tunnel retrofit - can be welded into manual transmission floor & firewall:
click
click
click
click
B210/610 Tunnel
Can fit into 1200 under heater:
NOTE: All B210 uses the larger size tunnel.
However the B210 floor pans differ (where the transmissions mount point are). There were eight different ones used by B210. See Tunnel Comparison.
A10 Tunnel
Several club members have fitted an A10 Stanza tunnel to the 1200.
unfamilia:
the satnza tunnel in- looks ok, but i wouldnt recomend it as an easy swap(my first one but piggys 3rd or 4th one). 120y was most stright forward he said, but heaps of room around this one
A10 tunnel in 1200
Shifter Location
Photo showing where to cut the tunnel to fit a standard "short" L-series or CA-series transmission.
Or just move the hole back and weld it back in:
71-series Modifications
S13 gearbox clearance in manual tunnel
Rear of tunnel modification:
Reverse Lamp
To fit a 60-Series Transmission 5-speed, move the mounts 115mm back:
56A Modification
to clear that nasty clutch fork im the later type 56A trans
See Also
Also see: Transmission tunnel Photo Index
