Stock Seats
USA Coupe
Stock Seats
Stock headrests
Standard, Deluxe and Reclining Seats
1200 Coupe seats (custom fabric) in Datsun 1000
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors.
TRIM-SEAT RISER, RH
- 74961-H1100 7510-7803 BLACK
- 74961-G1060 7804-8910 DARK BROWN
- 74967-95W00 8910- GRAY
TRIM-SEAT RISER, LH
- 74962-G1000 7510-7803 BLACK
- 74962-G1060 7804-8910 DARK BROWN
- 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
- 66919-H1001 7510-7803 BLACK
- 66919-G1060 7804-8910 DARK BROWN
- 96815-B0700 8910-
Alternative Seats
Racing Seats
Adapting Seats
B210 seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat:
Seat Slide (aka Seat Rail)
If you don't have the B110 rails, you can adapt B210 or B310 slides:
Modifying B310 brackets to fit B110 chassis
Many, many other seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
Chassis Brackets - for flat seat runners
Account and pictures of how to adapta Civic seats: http://forum.ratsun.net/showthread.php?t=776
Rear Seats
Australia Legalities
