Brakes
Revision as of 02:04, 21 April 2014; view current revision
Category: Brake System
Datsun 1200s came with two brake systems: all drums (Standard models), or Girling-Tokico front disc with rear drums. They were excellent brakes for the period. All are manually adjusting except non-North America Left-hand drive 1200s, which were equipped with auto-adjusting rear drum brakes.
Also see:
* Rear Brakes
* Brake Swaps
* Brake Upgrades
* Brake Adjustment
Types
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads.
Calipers
Calipers are used with disc brakes. Datsun B110, B210 and B310 used floating two-piston ANETTE types. These were desinged by Lucas Girling who make the Anette, Babette and Colette series.
Type
B110: ANNET 12/14A (1.894" cylinder inner diameter)
B310 small: AN-18 (1.894" cylinder inner diameter)
B310 large: Disc-AN20 (2.012" cylinder inner diameter)
1200 Brake Rotor
Outer diameter: 212 mm
Height: 35.6 mm
Nominal thickness: 9.5 mm
Minumum thickness: 8.6 mm
Hub Reg: 70 mm
Bolt size: 10 x 1.5 mm
Bolt circle: 4 x 87 mm
Weight 5.9 - 6.1 pounds
Caliper bolt spacing:
84 mm: B110
* and all 12" wheel B210 and B310
88.9 mm: B310 large struts for 13" wheels
Rotor Sizes
Dia. (mm)Part NumberSource
20840207-G1501Sunny Truck 8910-
212.540206-H1006B110, B210 A12 1974-1975
220 (AN18)40206-H7500B210 A12 1976-1978,B310 with 12" wheels
23240206-A1155B210 A13, PB110?, PB210 early?
245 (AN20)40206-U6700A10, B210 A14, 1976-1978 120Y, B310 A14/A15, PB210 late?
??B210 Australia-assembled
? (Girlock)?A10, Australia-assembled
Brake Lines
The hard lines are 3/16" outside diameter.
* 3/16" lines (4.75 mm) with M10 metric fittings
* Cunifer lines on early 1200s for corrosion resistance
* Later 1200 utes have poly-coated steel lines
Front Drum Brakes
1200 DX and STD trim received front drum brakes (GL and GX were fitted with Disc Brakes). It uses two cylinders, unlike the rear drums which have one cylinder.
* Wheel cylinders: 13/16 inch bore diameter
Rear Drum Brakes
See Rear Brakes
brake cylindersB110 (disc)1977 US B2101980 US B310 (Disc-AN20)1980 Canada A12A (Disc-AN18)
Proportioning valvenot usedyes1,961 kPa x 0.4 psi1,961 kPa x 0.4 psi
Booster (Master-Vac)not used?M60 6-in diameter 135mm rod length (flange-to-pedal)M60 6-in diameter
Master diameter11/16 inch3/4 inch13/1613/16
Front cylinder diameter1.894 inch (drum brakes: 11/16)2.012 inch2.012 inch1.894 inch
Rotor diameter212.5 mm245mm245mm220mm
Pad (width x length)42.5 x 53.1 mm41.2 x 63.4 mm41.2 x 61.4 mm42.0 x 56.8 mm
Pad thickness10.310.010.010.3
Total front braking area (discs)14.0 sq in16.2 sq in~14.6~13.8
Total front braking area (drums)42.3 sq inn/an/an/a
Rear cylinder diameterdisc brake models: 11/16 inch (all-drum models: 13/16)13/16 inch13/1613/16
Drum diameter8.0 inch8.0 inch8.08.0
Drum width1.378 inch1.378 inch1.3781.378
Total rear braking area42.3 sq in42.3 sq in42.342.3
http://www.rockauto.com
ブレーキ
Brake Pedal Switch
  • Beck/Arnley 201-0288
    • 1987-1988 Dodge Colt
    • 1990 Mitsubishi Sigma
    • 1985 Mitsubishi Starion
    • 1967 Toyota Corona
    • Datsun B110/B210/F10/N10/S10, 1974-1978 S30, A10, 620, 810, 910
Front Brake Cylinder
41100-18000 ASS'Y-CYLINDER, front wheel, fore (R.H.) B10, B110 STD,DX
41102-18000 ASS'Y-CYLINDER, front wheel, fore (L.H.) B10, B110 STD,DX
41101-H1000 CYLINDER ASS'Y, front wheel, after (R.H.) B110 STD,DX
41103-H1000 CYLINDER ASS'Y, front wheel, after (L.H.) B110 STD,DX
22145.jpg 22146.jpg Seiken
41101-27700 ASS'Y-CYLINDER, front wheel, after (R.H.) B10
 superceded 41101-18000 ASS'Y-CYLINDER, front wheel, after (R.H.) B10
41103-27700 ASS'Y-CYLINDER, front wheel, after (L.H.) B10
 superceded 41103-18000 ASS'Y-CYLINDER, front wheel, after (L.H.) B10
22148.jpg Meisan (n & n)
B10 front & rear brake cylinders
B10
フロント ホイール シリンダー
Brake Hoses
See main article: Brake Hoses
Pads
See Brake Pads
Rotor
B310 - 245 mm
Height: 35.5 mm
Thickness: 10 mm
Thinness: 8.4 mm
Hub reg: 73 mm
4 x 95 PCD (bolts to hub)
weight: 8.56 lb
* Centric 121.42002
Wheel Bearings
See Wheel bearings
Rear Wheel Bearings
See Axle Shaft. These are not easily replaced.
Caliper
* Bore Size=1.89" Inlet Thread=M10x1.0 Bleeder Thread=M10x1.0
Right: RAYBESTOS FRC3021 $30.79, RC3021, A-1 CARDONE 19124, 17124
Left: RAYBESTOS FRC3022 $30.79, RC3022, A-1 CARDONE 19125, 17125
Parking Brake
See Hand Brake
Master Cylinder
A-1 CARDONE 111655 Remanufactured $26.79
RAYBESTOS MC39087
ACDELCO 18M1072, 19106858
* Bore Size=11/16" Number of Ports=2 Primary Outlet Size=M10x1 Secondary Outlet Size=M10x1
B120
Front Disk Brakes from 8910. These are unique as they fit the same strut as the former drum brake setup.
Rear Drum Brake
See Rear Brakes
Master Cylinder
Master cylinder has two bolts in horizontal plane; previous drum brake system used two bolts in vertical plane (like B110).
Front Discs
Sunny Truck staring in October 1989 has a disc brake system similar to B11/N12.
See main article: Sunny Truck Disc Brakes
Nissan Competition
* 44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4
* 44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4
* 44100-M7000 CYL ASSY-Wheel 5/8" LT20 Selective Use, N10 standard
* 44100-M4901 CYL ASSY-Wheel 11/16" LT20 Selective Use
* 44100-G2800 CYL ASSY-Wheel 1/4" LT20 Selective Use
* 44100-U9200 CYL ASSY-Wheel 13/16" LT20 Selective Use
