Bike Carbs
Revision as of 23:23, 16 May 2014; view current revision
Category: Fuel System
Motorcycle carbs, bike carbies. Flat-slide, constant vacuum or variable venturi carburetors.
TUNING is critical. Bike carbs as-is run poorly on automotive engines. But with the right jet or needle selection they can run very well.
961.jpgKeihin Flat CR (FCR)
449.jpg bike carbs on A12Y engine
1047.jpg Matsuoka MSR carbs
adapt carbs from your favorite motorcycle
Suzuki GSX-R (aka GSXR)
Yamaha YZF-R1 (aka R1) carbs are a fad in USA as of 2012.
ヤマハ
Adapter Kits
Fumiya Kit
Datsun 1200 enthusiasts Fumiya sells these
Keihin FCR
rallytwit made 73.22 RWHP on his A-series.
39mm FCR carbs with a near standard GX motor; ported head, headers 2 inch exhaust and 14lb flywheel. As far as reliable FCR carbs are stone axe reliable. For street (or racing) use you would have to do some tuning but it's not a big deal. I only needed an hour of dyno time to get the car 95% dialed. My only problems were because the carbs were on 175HP A-series powered sports racer so the jets were way off what my motor needed............lots of guys use these on street bikes and they are standard equipment on MX bikes. 32MM would likely be better for a street car, the 39's on my car border on over-carbed. As fars as how the motor runs they are the bomb the motor sings......revs like mad and instant throttle response.
Flatslide FCR Sidedraft
Flatslide FCR Downdraft
CR-MX off road ruggedized
Roundslide CR
Matsuoka MSR
Matsuoka MSR are like FCR but about $1000 US cheaper. They use the same sliding throttle valve design. They're made by Mikuni. Manifold can be any DCOE (Weber/Dellorto/Solex) type.
new, jetted to your spec: 96K yen (1230 AUD) or with manifold and linkage closer to 200K yen.
Feral said:
When I say just about as good as injection I mean the low speed response from the Mikuni flat slides is incredible. It will still not be as accurate as any well laid out injection system, but really do work very well
Mikuni
Mikuni also made constant velocity (CV) carburetors. The venturi size is what sets the HP characteristics. CVs use the same bore size as venturi size except for a fixed obstruction to generate vacuum.
Mikuni BS series. For example 1980- Suzuki GS1000 came with BS34 carbs (34mm) for 90 HP. A 1981 Kawasaki KZ1000 fitted with BS34s made 102 HP.
Mikuni BS series
variable venturi
constant velocity design
Side draft
Mikuni BD series
Downdraft
These being CV carburetors are similar to SU carburetors. They have a traditional butterfly throttle but the actual airflow is controlled by the round slide (piston) that floats up by vacuum action. It is opposed by the dome spring.
VM
Mikuni VM - late model round-slide series http://www.mikuni.com/pdf/vmmanual.pdf
VM28 may be ideal for a stock A12 (see Carburetor Sizing) - and are only $100 each.
BDSR40
BDSR
D=Downdraft
R=Radial slide
BDSR40 is the famous Yamaha R1 carbureotor
150hp
BS34
 90 hp 1980- Suzuki GS1000
102 hp 1981 Kawasaki KZ1000
SX650 1989-1984
* 132.5 main jet
* 2.5 pilot jet
* Y-O needle jet
* 5HX12 needle
BS34s are rather forgiving and will at least run most engine set ups with stock jetting. W
The pilot air jet is removable, and the main air jet is fixed.
3 main circuits of the carb
* slow speed or idle (mix screw and pilot jet)
* midrange (slide, slide needle, and needle jet)
* high speed or main (main jet)
These all overlap the circuit next to them and changes made to one will slightly effect the other
Float height on the brass floats is 27.3mm. For later units with plastic floats, 22 mm. +/-1mm. BS34 are are fitted with drain valves opened by a screw, with a hose nipple on the outlet. To read fuel level, attach the sight tube to the outlet and set vacuum petcocks, if fitted, on "Prime," and open the screw until fuel flows into the sight tube. With the motorcycle level, hold the sight tube upright beside the carburetor body. Fuel should rise in the tube no higher than the lower lip of the carb body where it overlaps the float bowl, and no lower than 2 mm. below it.
The pilot circuit fuels the engine in low-speed operation, when the slide is lowered.
real Mikuni jets are availible . Get them from the stock size up to two over on the pilots and up to three over on the mains. Follow the guide and test them to see what your engine needs. http://www.amckayltd.com/carbguide.pdf
Tuning kit
* Pilot jets
* Needles
* Main jets
BS34 Jet Needle
5IX11 richer
5HX12 leaner
Needle Jet
Needle Jet
Y-O
336-Y0
fcr,msr,keihin,cycle carb,bike carb
961.jpg 1001.jpg 1047.jpg 1348.jpg 2197.jpg 2198.jpg 2582.jpg 2583.jpg 2584.jpg 2812.jpg 3073.jpg 4830.jpg 5220.jpg 5221.jpg 5222.jpg 6310.jpg 6746.jpg 6747.jpg 6751.jpg 10205.jpg 11716.jpg 12478.jpg 15244.jpg 15245.jpg 15516.jpg 15326.jpg 15532.jpg 15533.jpg 16531.jpg 16532.jpg 17096.jpg 17097.jpg 17139.jpg 18503.jpg 18714.jpg 18715.jpg 18716.jpg 18833.jpg 18834.jpg 18836.jpg 18837.jpg 18839.jpg 18968.jpg 18973.jpg 18974.jpg 18975.jpg 19317.gif th_19320.gif 19513.jpg 19962.jpg 19963.jpg 19964.jpg 19965.jpg 19966.jpg 19974.jpg 20005.jpg 20006.jpg 20008.jpg 21016.jpg 21136.jpg 21796.jpg 21797.jpg 21924.jpg 21955.jpg 22387.jpg 24290.jpg
Uploads
photo  photo  photo  photo  photo  photo  photo  photo  photo  photo  photo  photo  photo  photo  photo  photo
