Datsun 1200 and Truck variants were fitted with a variety of steering wheels. They are 15 inch diameter wheels (overall diameter 15.75"/40cm). They have a 5/8" (16mm) thick rim section.
Variations
PB110 used the same steering wheels as B110 (at least with early PB110)
aftermarket horn button (fits GX wheel?)
B10
The Datsun 1000 (B10) wheels were different:
See main article: B10 Steering Wheel
Nismo 10th Anniversary
Removal and Installation
Be sure to use a wheel puller:
Occasionally you can remove the nut and "pop" it off by hitting it from behind with your fists, but you risk the chance of having it hit you in the face when it pops loose. Discussion
Be safe, don't worry. Only about $15 new.
To remove the horn button, remove the two screws from behind the wheel (B110 normal) or push in and twist for GX type.
Other wheels fit the hub but may not match the trim. The B110 steering wheel hub uses the same bolt pattern as:
- 1977-79 SX200, F10, N10
- 1974-78 B210
- 1971-73 1200
45mm between bolts (1-15/16 inch)
Only three Datsun models used the small diameter steering column shaft, those models being the B10, B110 & B210. The B10 used blinker canceling pins that were reasonanly close together & this made it unique, The B110 & B210 share the same specs so the hub/boss is interchangeable between these two models.
All other Datsun models [at least those from the mid 60's], including the B310, used a larger diameter shaft & the boss for any of these will be too big in the hole.
B110 and PB110 (at least early PB110)
- 48498-H1000 EMBLEM 'S' MARK DX
- 48498-H1100 EMBLEM 'D' MARK DX
- 48400-H1000,48400-H1001 ASS'Y-WHEEL-steering Std, Dx
- 48400-H2300,48400-H2301 ASS'Y-WHEEL-steering GX
OPTIONAL - There were two Optional Steering Wheels
- 48400-H1200 ASS'Y-WHEEL-steering (wood) OPTION ALL (per JDM catalog)
- metal three-spoke, one-slot spokes covered with plastic trim
- 48400-H2310 ASS'Y-WHEEL-steering (foam skin) OPTION ALL (per JDM catalog)
These wheels were derived directly from the B10 option wheel. They made a new hub (boss) to suit the 1200 column & a new horn button to 'update' them but are otherwise the same.
The optional wheels are different from the B10 mainly in the horn button and the hub part (the wheels themselves appear to be the same, but were only sold as an assembly).
- The 1200 horn button is wider at the top, and narrower where it bolts to the wheel
- The 1000 horn button is the opposite (narrower at the top)
Also, the 1200 hub part where it meet the steering column is bigger diameter. So the 1200 hub flares out slightly to this larger diameter. The 1000 hub is completely cylindrical.
Note that the 1000 hub on the right is cylindrical & has closely spaced blinker pins, while the 1200 hub on the left is conical, or bell shaped & has pins more widely spaced.
The wheel & the complete horn switch assembly are identical between the B10 OPTION wheel and the B110 OPTION wheel.
Sunny Truck
Center Emblem
- 48498-H1000 -7803 NLA
- 48409-H5002 7804-7907
- 48409-G1660 7908-
- 48400-H5000, 48400-H5001 STD, DX, PB210 DX
- 48400-H5100, 48400-H5103 black (wood-like) GL
- 48400-H5102,H5105 black (wood-like) PB210 GL, op. PB210 DX
- 48400-H5101,H5104 brown (wood-like) PB210 GL, op. PB210 DX
- three-spoke
- 48400-H5104 brown (wood-like) L16 GL
- 48400-H5105 black (wood-like) L16 GL
- 48400-H5200, 48400-H5202, 48400-H5203 (leather-like) GX, op. ALL
- three-spoke, five rectangular holes in each spoke
center:
- leather-like
- 48400-H7210 ASSY-STEERING WHEEL 3 SPOPK LEATHERETTE OP.COUPE FROM 0875 USA
- 48400-H5600, 48400-H5800, 48400-H5802 (wood) OPTION ALL, PB210 OPTION ALL
- 48400-H6000, 48400-H6001, 48400-H6002 (leather-like) PB210 GX, L16 GX, L16 GL
- 48400-H7509 A14T
- 48400-H7800 Van Super Deluxe (black wood-like)
GX center pad removal: Push in hard and and slowly gently twist it counterclockwise and it should just turn and plop off.
S10
1977-1979 Datsun 200SX (Silvia) used a steering wheel that looks like the B210 GX wheel.
- Black 48400-N5810/48400-N5815
- Brown 48400-N5811/48400-N5816
- Brown, light 48400-N7800 1979
- Green 48400-N5812/48400-N5817
- Blue 48400-N7801 1979 only
Does this fit small shaft (B110/B210) or large shaft (B310)?
Aftermarket Adapter Hubs
See main article: Steering wheel boss kit
Unidentified
Datsun B10 OPTiON wheel with aftermarket (Nismo?) 'GT' horn button
post
