Tail lights, tail lamps, or as Nissan calls them "rear combination lamps", combines the running lights, brake lamps (stop lights) and turn-signal lamps (blinkers).
Troubleshooting
Inoperative rear taillights, Turn Signal lights, or brake lights? Check for adequate grounding/earthing of the plastic combination lamp assembly.
1. Check the metal-to-metal contact of the ground wire (black) from the right side tail light assembly at teh grounding post on the panel inside the trunk area. Remove any paint or dirt that prevents good contact
2. Using an ohmmeter, check the ground wire (black) from the harness in the engine compartment to the battery negative post for continuity to the instruments and lights of the vehicle. If continuity is lacking, repair the break or replace the wire
3. A heavy gauge ground strap connecting the engine to the body of the vehicle assures proper grounding. The ground strap is built into the original negative battery cable
Bulbs
Also see main article: Bulbs
All 1200s use a 3-section taillight. Japan market and North American market use these bulbs:
* 26717-89900 12V-23W [Top/Outer bulb] * 26717-89920 12V-23/8W [Middle bulb] * 26717-89900 12V-23W [Bottom/Inner bulb]
Japan-market has an addition small middle bulb:
* 26261-89900 12V-3.4W (Wedge socket) [until Aug 1986]
Sedan
Japan and USA tail light have Red blinkers, instead of Yellow/Orange
Australia and Euro lenses have Orange for the blinkers
HOUSING (available as Assembly)
- 26550-H1001 ASS'Y-LAMP, rear combination (R.H.)
- 26555-H1001 ASS'Y-LAMP, rear combination (L.H.)
- 23W bulb (2 per side)
- 23/8W (1 per side)
- 3W (1 per side)
- 26552-H1001 ASS'Y-RIM (2) $38.82 USD
- 26553-H1000 ASS'Y-PACKING (2) $18.33 USD
- 26551-H1001 ASS'Y-LENS (R.H.) NLA
- 26556-H1001 ASS'Y-LENS (L.H.) NLA
- 26563-H1000 ASS'Y-HARNESS (R.H.)
- 26568-H1000 ASS'Y-HARNESS (L.H.)
- 26550-H1902 ASSY-LAMP REAR COMBNATION RH(ICHIKHO) $143.10 USD
- 26550-H7000 ASSY-LAMP REAR COMBINATION RH FROM 0772 $143.10 USD
- 26555-H1902 ASSY-LAMP REAR COMBNATION LH(ICHIKHO)
- 26555-H7000 ASSY-LAMP REAR COMBINATION LH FROM 0772
- 26551-H1902 ASSY-LENS RH RED-RED-WHITE (ICHIKHO) $35.63 USD
- 26556-H1902 ASSY-LENS LH RED-RED-WHITE (ICHIKHO) $35.63 USD
- 26563-H1600 ASSY-HARNESS,R.H NLA
- 26564-H1600 ASSY-HARNESS,L.H NLA
- No 3W bulb
Facelift
1972 Japan-market models had new tail lamps:
- 26550-H3101 LAMP ASS'Y-rear combination (R.H.)
- 26555-H3101 LAMP ASS'Y-rear combination (L.H.)
- 23W bulb (4)
- 23/8W bulb (2)
- 3.4W bulb (2)
- 26552-H3101 RIM ASS-Y (2)
- 26553-H3101 PACKING ASS'Y (2)
- 26551-H3101 LENS ASS'Y (R.H.)
- 26556-H3101 LENS ASS'Y (L.H.)
Custom Sedan
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim.
3-bulb Type vs 4-bulb Type
See Coupe Rear Combination Lamp Part Numbers
* Japan and North America both use Red lenses (no amber) * the red lenses differ, presumably in reflective pattern * the center section has two bulbs (Japan) or one bulb (NA) Therefore the assembly housing and Harness differ All other parts are the same (Bulbs, Rim, Packing, white reverse Lens)
Custom
Wagon
Also fits 620 Pickup
1000
See main article: B10 Lights
Pickup
Datsun 1200 (Pickup) has three-segment rear lamps:
* Top section is for turn signals, 23W single filament bulb * Red for older ones, Yellow for newer models * Aftermarket clear lenses are available, which use color bulbs * Middle section is red for brake & running lights, 23W/8W dual filament bulb * Bottom section is clear for backup lights, 23W single filament bulb
The lens frames were offered in various styles:
1971-1978: were silver/chrome through 1978 March
1978-1989: changed to black from 1978 April
Wiring early - Spade connector
Wiring late - Pin connector (positive locking)
Wiring AUS - 6-Spade connector (positive locking)
Bulbs * 26717-89900 12V-23W (4) [Top bulb, Bottom bulb] * 26717-89920 12V-23/8W -8608 (2) [Middle bulb] * 26261-89900 12V-3.4W (2) [small middle bulb]
WIRING * 26563-G1000 HARNESS ASSY-REAR COMBINATION -7803 [spade connectors] * 26563-G1060 HARNESS ASSY-REAR COMBINATION 7804-8608 PIN CONNECTOR [4-bulb type] * 26563-G1900 HARNESS ASSY-REAR COMBINATION -8608 [3-bulb type]
Right Hand
- 26550-G1001 LAMP ASSY-REAR COMBINATION, RH -7803 [chrome]
- 26550-G1060 LAMP ASSY-REAR COMBINATION, RH 7804-8608 [black, 4-bulb]
- 26550-G1900 LAMP ASSY-REAR COMBINATION, RH 8608- [black, 3-bulb]
- 08310-41620 screw, 8 needed per side
- 26521-G1000 LENS-COMBINATION LAMP, RH [top lens]
- 26541-G1000 LENS-REVERSE LAMP, RH [bottom lens]
- 26561-G1001 LENS-COMBINATION LAMP, TAIL & STOP, RH [Japan, middle lens]
- 26552-G1000 RIM-COMBINATION LAMP, RH [Chrome] -7803
- 26552-G1060 RIM-COMBINATION LAMP, RH [Black] 7804-
- 26553-G1000 PACKING-LAMP, RH [gasket]
Left Hand
- 26555-G1001 LAMP ASSY-REAR COMBINATION, LH -7803 [chrome]
- 26555-G1060 LAMP ASSY-REAR COMBINATION, LH 7804-8608 [black]
- 26555-G1900 LAMP ASSY-REAR COMBINATION, LH 8608- [black]
- 26526-G1000 LENS-COMBINATION LAMP, LH [top lens]
- 26546-G1000 LENS-REVERSE LAMP, LH [bottom lens]
- 26566-G1001 LENS-COMBINATION LAMP, TAIL & STOP, LH [Japan, middle lens]
- 26557-G1000 RIM-COMBINATION LAMP, LH [Chrome] -7803
- 26557-G1060 RIM-COMBINATION LAMP, LH [Black] 7804-
- 26558-G1000 PACKING-LAMP, LH [gasket]
Export
JDM vs Export
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
Semi-Clear
Custom
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
North America Notes
Canada generally adopts the same standards as USA.
USA "Federal Motor Vehicle Safety Standard No. 108 [1968] allows rear turn signals to be either red or amber in color... amber signals show a 5.3% effectivenss in reducing involvement in two-vehicle crashes where a lead vehicle is rear-struck in the act of turn left, turning right, merging into traffic, changing lanes, or entering/leaving a parking space. The advantage of amber rear turn signals is shown to be statistically significant." -- NTSHA document.
Nevertheless, amber was slow in coming. Even in the 1990s red rear turns signals are commonplace. The Nissan Altima even changed three times, from Amber to Red to Amber and back to red.
"In Europe and many other countries, rear turn signals are required to be amber. Currently [2009], manufacturers ... [for] North American markets choose whether to produce [amber or red rear turn signals]." -- NTSHA document.
