Nissan R32 used light alloy 4-piston brake calipers, but the really big R32 brakes used huge cast iron calipers. 4-lug R32 used S13 rotors while R32 turbo models used 5-lug rotors.
R32 is 1989-1994 Nissan Skyline (8905-9411).
Disc-over-hub brakes 4-lug: CA18I, RB20E/RB20DE and RB25DE 5-lug: RB20DET, RB26DETT
R32 GT-R Sumitomo make light alloy
post
R32 GT-R WITH 17" WHEEL (cast iron, non-ribbed)
post
200B/Stanza/240K strut R33 disc R32 caliper
R32 disk and calipers on 1200 strut
Rotors
R32 4-lug rotor (also used by S13) 280 mm 40206-55F01 9108- RB25 including GTS 2.5 257 mm 40206-71E06 8905- RB20 including GTS, GTE 251 mm 40206-40F01 8905- CA18I GXi 40206-40F02 For usage, see S13 Brakes
R32 5-lug rotor 280x30 mm 40206-40P02 RB20DET > 40206-04U01,40206-04U03 * also USA Z32 * DBA 909 GTE, GTS, GTS-T/GTS-4, 280x22 mm 40206-88E01 <> 40206-88E04 * also J30 (USA+JAPAN) 296x32 40206-05U00 8908- RB26DETT GTR 40206-05U01/40206-05U06/40206-05U07 * 40206-05U10/40206-05U11/40206-05U12/40206-05U13 * DBA 4926 GT-R 324x30 40206-12U00 9302 GT-R.17.MT.FT 40206-12U01 * also R33.RB26DETT + AWC34.RB326DETT * DBA 4928 GT-R 17" wheel
40206-40P02 280 x 30 Height: 53.6 mm Diameter: 280.2 mm Centering Diameter: 68.1 mm Pitch Circle Diameter: 114.3 mm Brake Disc Thickness: 30 mm
40206-88E01 280 x 22 mm Height: 49 mm Diameter: 280 mm Centering Diameter: 68 mm Pitch Circle Diameter: 114.3 mm Brake Disc Thickness: 22 mm
296 x 32 mm 40206-05U12 RH, 40206-05U13 LH cross-drilled
Calipers
R32 Single-piston * 41001-40F01 CA18I * 41001-73L01 RB20DT.GTS-T, RB25DE * 41001-44F01 RB20E, RB20D
R32 4-piston ribbed * 41001-04U00 RB20DT.TYPE-M,RB20DT.HI.4WD 41001-04U01 * 41001-05U00 GT-R & RB26DETT 41001-05U01 * 41001-45P00 RB20DT.HI.4WD 41001-40P00 40mm bore also Z32 USA
R32 4-piston non-ribbed (iron) * 41001-12U00 GTR.17 41001-24U00
R34
R34 CALIPER Single-piston * 41001-AA000 RB20DE Twin-piston sliding * 41001-AA100 OPTION RB20DE F/DWHL6 * 41001-0V100 IRS.4WD.RB25DE Four-piston ribbed * 41001-AA510 OPTION IRS.2WD.RB25DE F/DWHLE RB25DET Four-piston non-ribbed * 41001-AA300 RB26DETT
R34 disc-over-hub 280x22 40206-2Y003 RB20DE <> 40206-5L300 280x26 40206-2Y502 RB25DE *RB20DE <> 40206-2Y503 40206-2Y505 * 40206-5L800 <5> 40206-2Y502 * infiniti * laurel 310x30 40206-AA510 HI.2WD *RB25DE 318x30 40206-AA300 HI.4WD (RB26DETT)
BREMBO BRAKE ASSEMBLY - FRONT, RH 41000-RP802 RB26DETT N1 race nismo レースヨウ ニスモアツカイ * steel piston caliper 41000-RP803 チタピストンキヤバ * titanium piston caliper
Z31
Z31 is Nissan 300ZX 1983-1988
Z31 bolt-behind-hub 5-lug
Z32
Z32 is Nissan 300ZX 1989-1996
- Japan: 1989-1990
- USA: 1990-1996 (0289-0896)
Z32 USA ROTORS 280 x 30 mm 40206-40P02 <> 40206-04U00 * VG30DTT -0491 * VG30E 0790-0491 40206-04U03 <> 40206-69F00 * 0491-VG30DTT + VG30D 40206-30P01 * VG30D -0390 40206-30P03 <> 40206-30P05 * VG30D 0390-0790
CALIPER Z32 USA 1990-1996 (all 4-piston) 280 x 26mm rotor * 41001-30P00 alloy 1990 VG30D <> 41001-30P01 * 41001-04P00 alloy 1991 VG30DTT <> 41001-45P00 280 x 30mm rotor * 41001-37P00 alloy 1992-1993 <> 41001-37P01 * 41001-37P01 iron 1994-1996 non-ribbed
Centric 141.42072 FL, 141.42071 RH, to June 1990full
Centric 141.42074 FL, 141.42073 RH, from July 1990full
Centric 141.42078 FL, 14.1420177 FR IRON RockAutofull
40206-04U00 280x30 Height: 53.6 mm Diameter: 280.2 mm Centering Diameter: 68.1 mm Pitch Circle Diameter: 114.3 mm Brake Disc Thickness: 30 mm
Nissan Alloy Twin-Piston Caliper
Lightweight twin spot calipers from R32/R34 Skyline rear caliper for either 1000 or 1200 race front brake conversion. The rotors it uses are perhaps the lightest 297mm rotor around as its only 16mm thick or 3mm thicker than solid Sigma GE rotors.
Rotor/disc DBA part no: 908 Diameter: 297mm Height: 63mm Thickness: 18mm (16 min) Centre hole: 68 (2mm machined for 70mm hubs) The 5 stud rotor can easily be re-drilled for 4 stud
R34 rear caliper
R32 GTS rear caliper
44011-43P00 * Z32 USA * R32 RB20DET * R33 RB25DE,RB25DET
R32 REAR CALIPER (CA18 uses rear drum brakes, as does early RB20) Single piston * 44011-44F00 RB20E, RB20DE Twin piston * 44011-43P00 GT-R, RB20DET 44011-05U00 also Z32 USA * 44011-73L00 RB20DET GTS-T, RB25DE Twin piston large * 44011-12U00 GT-R.17 44011-24U00
R33 two spot rear calipers on 200B/240K strut & rotor
Pigdog
296mm disc rotor
GTST/Z32 calipers on 296 x 30 rotors on 810 struts
