Brake and Clutch pedals go in the pedal box.
The pedal boxes are the all years, and are the same manual & auto. Brake pedal width differs. Brake pedal looks the same RHD and LHD. Clutch pedal differs LHD vs RHD. In Oct 1989 they changed the pedals to use a different pads - they may be interchangeable with earlier pedals.
Stays (brackets) are welded to the upper dash panel. The box bolts to the stays
Steering Column bolts undeneath the front of the pedal box
4 bolts where it bolts to the stays 4 bolts at the front, where it bolts to tabs welded into firewall
Switch
Stop Lamp Switch & (1989-up) Clutch Switch
Stop Lamp Switch
Stop Lamp Switch Part Numbers 25320-H1000 -8109 bullet connectors 25320-H8500 8510-8910 spade connectors 25320-A7500 8910-
Clutch Switch
8910-
Pedal Bushings
Pedal shaft, nut & washer with bushings fitted![]()
Remove this bolt and lubricate the bushings (grease them) every Every 12 months or 12000 miles, whichever comes first.
Throttle Pedal
The accelerator is attached to the firewall, outside of the pedal box.
See main article: Accelerator Pedal
Adjustment
Brake Pedal
- Loosen the stopper nut
- Measure height of pedal. It should be 143.5 mm. Insert shims on outside of firewall until height is 143.5 mm
- Tighten stopper until height is 139.5 to 143.5 mm. Tighten stopper nut.
- Double-check free play (5-15 mm)
- Double-check total travel of pedal (120mm)
Clutch Pedal
See:
Accelerator Pedal
Also See: Dash Part Numbers for the box and stays Brake Pedal Part Numbers Clutch Pedal Part Numbers
* Same: Sedan/Van/Coupe/Truck RHD 46580-H1000 STAY-bracket, pedal & steering post (R.H.) 46581-H1000 STAY-bracket, pedal & steering post (L.H.) 46570-H1001 ASS'Y-BRACKET, pedal & steering post LHD 46580-H1600 STAY-bracket, pedal & steering post (R.H.) 46581-H1600 STAY-bracket, pedal & steering post (L.H.) 46570-H1600 ASS'Y-BRACKET, pedal & steering post fixing reinforce & stay 08110-62062 BOLT-with lock washer (8) or 08110-61262 08915-53510 WASHER-plain (8)
Pedal bushing 46525-18000 BUSHING-pedal fulcrum (2) * replaced by 46525-N8200 0880-up $1.64 USD * Fits B10, B110, B210 & B310 USA & JDM
Pedal Rubber
46531-18001 COVER-PEDAL PAD for BRAKE MANUAL $2.52 46531-20301 COVER-PEDAL PAD for BRAKE AUTOMATIC NLA 46531-M3000 COVER-PEDAL PAD for CLUTCH $2.52 USD * formerly 46531-18001
46512-H0101 RUBBER-BRAKE PEDAL STOPPER $3.00 USD * Will Fit With Most Nissans![]()
Clear: 46584-S0100, Green: 46512-H0101
B140
B210 pedal box differs from B110. For example, it bolts directly to the firewall while B110 bolts to tabs on firewall.
Manual pedal boxes are not interchangeable with auto pedal boxes
post
Manual pedal boxes have an extension welded on the left side for the clutch pedal pivot
post
Brake booster makes a difference too (2-bolt master VS 4-bolt)
post
All B210 (including 120Y) appear to have provision for a hydraulic clutch master cylinder -- though on some pedal boxes the center hole is not drilled.
B210 JDM Pedal Box MANUAL TRANSMISSION 45670-H5000 Manual A12 45670-H5800 Manual for use with booster * A12 GX,MTM OPT GL,MTM from '75-4 AUTOMATIC TRANSMISSION 45670-H5020 Automatic A12 1973-1975 45670-H5820 Automatic for use with booster * GX,ATM OPT GL,ATM from '75-4 MTM: GX マスターバック, GL ラインオプョン
Automatics have a larger brake pedal
post
Datsun 521 pedal box retro-fitted to B210
