Datsun 1200s were fitted with various consoles including full-style and compact style.
Full Size
Full size console was usually fitted with a Clock. The Tachometer was rightly fitted into the dashboard, but you can put the tachometer in the console if you so choose.
Heater vents still work even with the console in place
1970-1971 appears to be gold tinted, while 1972 seems to be silver-tinted. But the GL brochure shows what looks like a black tinted console. The catalogs show only two numbers: early and 1972.
GL
GX Facelift
Bracket tabs are hot air deflectors
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog * 74980-H2010 ASS'Y-CONSOLE BOX (大型 large type) GL/GX manual * 74980-H2020 ASS'Y-CONSOLE BOX (大型 large type) GL automatic
Japan catalog * 74980-H2010 ASS'Y-CONSOLE BOX (大型 large type) GL/GX manual * 74980-H2020 ASS'Y-CONSOLE BOX (大型 large type) GL automatic
1972 Japan [Facelift] catalog * 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL/GX 4-speed * 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
USA Catalog * 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772 * 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772- * 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
Mask
Console mask starts with the same plastic piece as the dash mask, and then rivits it to a complex aluminum adapter.
'Sunny'
74990-H2021 MASK-clock [console]
'Datsun' 74990-H1800 MASK-CLOCK [console]![]()
Compare to simpler Dash blank
The console mask has an aluminum adapter bracket to allow it to bolt to the three console holes.
Clock Fitting
Just unbolt the mask plate, and bolt in the Clock. The same clock fitted in the dash is used in the console.
The second set of tabs - back from the face - are used to bolt into the console
click
If the side-brackets are missing - e.g. a 1976-up Truck clock - you may fabricate a simple bracket to hold the clock in place.
discussion
27389-H2300 SPACER-rubber (fixing clock to console box)![]()
post
If you buy a second-hand clock and end up with the Facelift clock, cut the long bracket off to make it fit in the console:
click
24043-H2000 ASS'Y-CABLE, for console clock GX [extension harness for clock wiring]
Fibreglas
Short Console
The short pocket-type console was fitted to:
* Automatic DX * OPTION 4-speed 1200s STD and DX * JAPAN 3-speed column shift OPTION * B120 Pickups as standard equipment (except STD models)
74987-H1801 BRACKET-CONSOLE FRONT [long bracket] 74988-G1161 BRACKET-CONSOLE [rear, short bracket] 01241-00061 NUT (4) 08510-61697 SCREW (holding console to bracket) 08510-61642 SCREW (holding bracket to floor)
Sunny 1200 Optional Parts catalog * G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
Japan CONSOLE BOX * 74980-H1801 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket 4-speed (ex. GL, GX) * 74980-H1021 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket A-all (ex. GL)
North America * 74980-H1921 ASSY-BOX CONSOL SEDAN,COUPE AUTOMATIC * 74980-H1801 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION * 74980-H7000 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION 0772- [Fire-resistant?]
B120 * 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET -7803 [Black] * 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN * 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN * 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910 [revised finisher panel] * 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
Shifter Boot
シフト ブーツ Boot for shift lever. Full and short consoles use the same boot.
Buy from Bprojects
BOOT 74986-H1801 ASSY-BOOT MANUAL [Black] -7803 74986-H7000 ASSY-BOOT MANUAL 0772- USA [Black Fireproof?] 74896-G1160 7804-7907 [Dark Brown] 74896-G1660 7908-8910 [Brown] 96935-95W00 8910- [Gray]
Finisher 08961-13240 NUT (4) (holding finisher to console) 74982-H1021 FINISHER-CONSOL BOX AUTOMATIC 74982-H1801 FINISHER-CONSOL BOX MANUAL -8109 74982-G1900 PANEL-CONSOLE A 8110-8910 96930-95W00 PANEL-CONSOLE A 8910-
Fibreglas
Aftermarket
Amco aftermarket/dealer installed
Westel docking-type 70 Console Custom (click for more photos)
EC 4420N (was spotted on eBay out of Austria)
Custom
Português 1200s. Eles são consoles personalizados? Ou o equipamento padrão Entreposto
Portugal 1200s. Are they custom consoles? Or the standard Entreposto equipment?
Documentation
Alternative Sources
PB110
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also extends further back under the handbrake lever.
- Console could be had without any gauges (just a Sunny plate)
- Clock with cubbyhole below was optional
- Clock with two small gauges was optional
- Has heater vent extender with directional (!) vents
* With option Large Clock * With option auxliary gauges * Oil P (oil pressure) measured from 0-6 kg/cm3 * AMP (ammeter) from -30 to +30
A. DX 'Sunny' plate B. GL/GX Clock with cubbyhole C. OPTION Clock with oil & AMP gauges
BOX ASS'Y-console 74980-H2501 (black) DX 74980-H2601 (black) GL 74980-H2602 (blue) GL 74980-H2701 (black) GX 74980-H2702 (brown) GX * Also available in DX AUTO and GL AUTO versions * Colors are on the Finisher and the vent Louvers
MASK-console box body コンソール ボックス ボヂー マスク 74982-H2501 DX 'Sunny' 74982-H2600 GL,GX [clock] 74982-H2601 OP. [gauges]
74990-H2600 MASK ASS'Y-clock 27380-H2600 CLOCK ASS'Y [same as PB110 dash clock]
GL/GX MASK - Clock with cubbyhole
OPTION MASK - Clock with Gauges
B210 Console
Does not fit the 1200 well
A12/A14/L14 H50 DX,V short type H51 GL,GX long type
L16 H59 GB210 black or brown * with coin tray * with pocket * with clock B210 * with twin gauges B210 or PB210
Short B210
Long B210
Standard for GX & GL, Option for DX & Van
Modified for use with shifter of long gearbox
This one has been cut to shorten it?
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD 96935-H9160 BOOT (BLUE) 0879- $32.62 USD 96935-H9100 BOOT (BLUE) -0779 $30.12 USD 96935-H8561 BOOT (BROWN) $35.58 USD
click
keywords: コンソール
