Contents[hide] |
Grille #Center Ornament Grille #Left Side Badge (trim badge)![]()
Side #C-pillar trim badge Side #Rear Quarter name badge![]()
Rear #Model badge (Datsun or Sunny) Rear #Trim badge (Deluxe, GL or GX) Rear #Transmission badge (Sports or Automatic)![]()
Grille
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
1972 Center Ornament
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
Grille Left Side Badge
DX early - no trim badge on grille
DX 1972 #62330-H3125 EMBLEM SET-radiator grille "DELUXE"
GL early #62330-H2026
GL 1972 #62330-H3325 EMBLEM SET-radiator grille "GL"
GX early #62330-H2325 COUPE, SEDAN
GX 1972 #62330-H3425 EMBLEM SET-radiator grille "GX"
1972 GX5 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
62330-H2325
GX early COUPE, SEDAN grille badge| CONTRAST to rear see-through badge
grille badge has long studs for mounting through the grille
contrast with rear sedan badge which has flush-mount pins
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
62330-H2026
screw-on type. Rear GL badge is push-in type.
62330-H3125
EMBLEM SET-radiator grille "DELUXE" [1972]
compare to rear badge 84823-H1000
62330-H3325
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" has long studs for mounting through the grille
compare to early rectangular GL badge #62330-H2026
62330-H3425
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX"
compare to 1970-1971 'GL' expanded font
Side
Rear Quarter
#76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export #76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon![]()
76854-H1000
Similar: PB110_Badges#Sunny_Quarter_Badge![]()
76854-H1600
76854-H1600 EMBLEM-'Datsun' BODY SIDE Sedan, Coupe Export
'Datsun' badge has same three pins as '#Sunny' badge, so it is interchangeable
C-pillar
C-pillar Emblems: DX, GL, GX
DX: 80mm wide? , GX: 99mm wide?, GL 109mm wide?
#76852-H1000 BADGE-"Deluxe" SEDAN-DX
#76852-H2001 BADGE-"GL" SEDAN-GL
#76852-H2300/76853-H2300 BADGE-"GX" SEDAN-GX RH & LH
C-pillar Badge Location
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places:
* 1970-1971 - down low * l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
76852-H1000
76852-H2001
76852-H2300
76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX 76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
Rear
#Model #Trim #Transmission
Model
- Japan domestic models had 'Sunny' badges as they were sold by Sunny Shop
- Export models had 'Datsun' badges
84822-H1000
84822-H1600
84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN
Trim
Left Rear
Deluxe #84823-H1000 Left Rear
GL early #84823-H2001 Left Rear
GL 1972 #84823-H3300 Left Rear
GX #84823-H2300 Left Rear
GX 5-Speed 84823-H7200
Deluxe Rear
Deluxe 84823-H1000 Left Rear sedan
differs from similar looking front facelift badge
* Grille badges: long studs for mounting through grille * Trunk badge: small pins for surface mount
GL Rear 1970-1971
GL early 84823-H2001 Left Rear sedan & coupe
GL Rear 1972
GL 1972 84823-H3300 Left Rear Facelift sedan & coupe
GX Rear
Rear GX "see-through" script. Used in Japan and South Africa markets.
84823-H2300 trim badge GX MARK 'GX' * 1970-1972 Japan * 1974-1976 South Africa
Used by coupe on Right Side
compare to #front GX badge which is not see-through but has a solid background attached
Transmission
- 3-speed cars did not have a gearbox badge
- 4-speed cars were badged "Sports"
Sports
79200-H1020 MARK-"Sports" sedan 4-speed 79200-H1060 MARK-"Sports", with sealing washer
4-speed Center Rear (left of license plate)
Sports badge
"Sports" 4-speed - to right of license plate - 1972 GL Sedan rear
Automatic
#79200-H1020 Early "Full Automatic"
79200-H2820 Late "Full Matic" from '71 April (also used by coupe), 79200-H3200 1972
N22 Coupe badge on sedan ('Nissan Automatic')
79200-H1020
Used on early Coupe
