Relay
Revision as of 02:06, 1 September 2022; view current revision
Categories: Body Electrical System | Engine Electrical System
Nissan relays
Also see:
* Automatic relay
* Auto Choke relay
* Horn relay
* Passing Lamp relay
And these non-stock items:
* Fuel pump relay
* EFI relay
* Headlight relay
3-pin
25630-79960
26320-D0100
15A T-connector
25630-79960
25630-C9960
25630-C9961
25630-C9962
26320 Miyamoto
Miyamoto Japan 12V 15A 211 ASSY RELAY HORN. Similar to late 1200 #26320-G1001, except with a two-hole bracket (G10 has a one-hole bracket)
28716.jpgAlbum 28716 28717.jpgAlbum 28717
26320-89907
1976 B210 horn relay
   2
3 | | 1
MIYAMOTO HORN JAPAN 12V 5A
28711.jpgAlbum 28711 28712.jpgAlbum 28712
26320-89912
28720.jpgAlbum 28720
26320-G1001
Three spade connectors H B S
26320-G1001 Horn relay - Imasen brand
14970.jpgAlbum 14970
26320-P6500
28718.jpgAlbum 28718 28719.jpgAlbum 28719
4-pin
25230-0B000
25230-0B060
25230-0B080
25230-61A05
25230-61A10
25230-C9965
25230-C9970
25230-C9980
25230-C9985
15A
25230-C9980 15A
25230-C9965 15A
20A
25230-59975
20A
25230-C9970
25230-0B000
30A cross-shape connector
25230-C9970
25230-C9980
25230-C9965
NO A-shape
25230-61A05
25230-61A10
25230-C9970
25230-C9980
25230-C9985
25230-0B000
NO open spade
82501-44060
25230-89977
25230-89975
25230-C9977
25230-C9965
25230-79971
25130-79915
25230-5T020
25230-18A00
5-pin
NO/NC with Common pin - open spade
25230-W1300
25230-C9900
25230-C9905
25230-C9907
25230-C9963
C9905
25230-C9971 15A
6-pin
25230-79963
25230-C9925
25230-C9963
25550-25004
C99
NO/NC open spade
25230-C9910
25230-C9915 15A
NO/NC h-shape connector
25230-0B010
25230-81W00
25230-C9962 15A
25230-C9972
25230-C9973
NOx2 open spade
25230-C9920
25230-C9925
25230-C9927
C9920
25230-89915
6-pin connector
Superceded by #B5230-89985
25230-89915 RELAY ASSY-AUTO CHOKE $24.57 USD
* B110 Automatic_Transmission#Relay
* B310 Choke Wiring
* 510 Headlight Relay
<25230-89915> JIDECO MR3-011-1
23482.jpgAlbum 23482 28501.jpgAlbum 28501 28502.jpgAlbum 28502 28503.jpgAlbum 28503
21562_621598a68151d.jpgPost 496630
B5230-89985
6-pin spade connectors, Normally Connected + Normally Open
B5230-89985 supercedes:
  • #25230-89915; 25230-89918; 25230-89964; 25230-H6202; 25230-N4300; 25230-N5310; 25230-R0100; 25230-U2000; B5230-89918; B5230-N4300; B5230-N4400; B5230-N5310; B7000-N8501KT
  • Used from 1972-1984
  • Used by 280Z, 280ZX, 1972-1973 510, 1975-1976 610, 1975-1979 710, 1978-1981 810, 1984 910 Maxima GL
  • S30 ignition/fuel pump RELAY B
<B5230-89985> square relay (#C99?) with 6-pin mini-harness
28500.jpgAlbum 28500
Original part #25230-89915 has built-in 6-pin connector
Alternative? <25230-89905> JIDECO RELAY type K5
25230-89905
25230-89905 3-connector
* B110 Passing Lamp from 1971.4
  Switch_Part_Numbers#25230-89905
25230-89912
25230-89912 4-connector
* B110 Passing Lamp to 1971.3
  Meter_Part_Numbers#25230-89912
25230-89918
25230-89918
26320-14800
3-connector spade-type inline marked H B S
26320-14800 RELAY-horn
* B110 Horn#Relay
26320-14800 RELAY-horn: early type used by Datsun 311 Roadster, 520/521/1300 Pickup Truck, 620/1500, Datsun 510/1600 and many other 1960s/early 70s Datsuns
174_5bfe20b0593b7.jpgPost 490018 174_5bfe20b8c55c9.jpgPost 490018 174_5bfe20bfc9565.jpgPost 490018 174_5bfe20c5f369f.jpgPost 490018
26320-15400
26320-15400 RELAY-horn
* B120 Horn#Relay Early
26320-G1001
26320-G1001 RELAY-horn
* B120 Horn#Relay 1974-1975
26320-G1600
3-connector spade-type non-inline
26320-G1600 RELAY-horn
* B120 Horn#Relay late type (1976-1994)
26320-G1600
174_5bfe36bfc2ef6.jpgPost 490020 174_5bfe36d2cd8fa.jpgPost 490020 174_5bfe36c62d9e6.jpgPost 490020 174_5bfe36cb88462.jpgPost 490020
Misc
15A
25230-79978
20A
25230-79962
24V
25230-0B060
24V 25A
25230-04G00
