The hood (bonnet) latch is in two parts and operated by a cable release from inside the cabin. B210/120Y latch differs from B110/1200.
The bonnect latch aka lock, is two pieces, plus the cable/control assembly
HOOD LOCK CONTROL WITH CABLE MALE HOOD LOCK FEMALE HOOD LOCK
B210 hood latch differs from B110, being a three-piece lock (safety catch is separate from latch), and uses a different cable/control assembly.
Recall
The original Datsun 1200 bonnet latch design was problematic, causing some damages for many owner s. In the USA it was the subject of a recall, but owners in all countries may wish to know about this.
Dent in bonnet | Matching dent above the windscreen
"Nissan Recalls 86,429 Datsun for Latch Check"
Secondary Hood Latch R2022 * campaign No. 72-0052, started April 6, 1972 * Vehicle: LB110 * affects: 86,429 vehicles * serial number ranges: ** LB110-010069 to LB110-307359 ** LB110-748404 to LB110-780283 ** LB110-855585 to LB110-920156 * Correction or inspection action: Inspect latch. Use special gauge to determine misalignment. Adjust latch if necessary.
The newer design has a different shape to the latch catch-hole. With the original design it could cause the bonnet to fly open if the latch is not completely shut.
RHD vs LHD
RHD and LHD latches differ, being mirror images of each other.
Parts
The early troublesome latch was from the Datsun 510. The updated/improved 1200 latch parts (H31 type) are compatible with Datsun 620 truck. Latches for all other Sunny models (B10, B210) differ from the 1200 latch.
RHD
NOTE: regarding Applied Model Codes:
210 is 1698 510
A06 is 1969 510
U01 is 1973 610
H31 is 1972 B110
B50 is Datsun 620 Pickup
Buy at Bprojects
65710-H1000 CABLE ASS'Y-HOOD LOCK (ALL sedan, coupe, pickup)
65601-A0600 MALE ASS'Y-hood lock <> 65601-A0601 65601-H3100 MALE ASS'Y-hood lock 7204- 65601-B5000 MALE ASSY-HOOD LOCK 7501- Pickup
65610-21000 FEMALE ASS'Y-hood lock control * Same as B10 Datsun 1000 65610-U0102 FEMALE ASS'Y-hood lock control 65610-H3100 FEMALE ASS'Y-hood lock control 7204- * ALL including pickup
LHD
NOTE: B64 is Datsun 620 Pickup export.
65710-H7000 ASSY-CONTROL HOOD LOCK WITH CABLE > 65710-H1600
65601-H7025 SET-LOCK,HOOD 0772- * replaces 65601-H3525 SET-LOCK,HOOD 0472-
65601-A2200 ASSY-MALE HOOD LOCK 65601-A2201 ASSY-MALE HOOD LOCK 0472- 65601-H3500 ASSY-MALE HOOD LOCK 0472- 65601-H7000 ASSY-MALE HOOD LOCK 0772- 65601-B6400 ASSY-MALE HOOD LOCK 0772-
65610-H3500 ASSY-FEMALE HOOD LOCK 0472- * new design 65610-U1702 ASSY-FEMALE HOOD LOCK 0472- * replaces 65610-21400 ASSY-FEMALE HOOD LOCK
