Head Bolts
Revision as of 23:27, 27 September 2025; view current revision
Categories: Cylinder Heads | Engine Mechanical
A-series head bolts are designed to be reused; they are not Torque-To-Yield (TTY) bolts.
Maintenance Schedule
Retighten cylinder head bolts every 24 months or 24000 miles whichever comes first, per the Periodical Maintenance and Lubrication Schedule.
1972 USA Owners manual (Page 32 ... 32):
24 months/24000 miles
600 mile service
See Changing Head Gasket for torque specifications and procedure.
BOLT-FIXING CYLINDER HEAD SHORT [9 needed, 97 mm length]
* M10 x 97mm
11056-18001 36 lb ft [Original use: A10 & A12]
11056-H1000 43 lb ft [original use: A12]
11056-H2301 58 lb ft [original use: A12GX]
Note 'T' bolt for center of early A12 engine. The center bolt is thinner to allow oil to flow around it up to the rocker shaft.
24528.jpgAlbum 24528
BOLT-CYLINDER HEAD, TO OIL GALLERY [1 needed]
11057-18000 '
11057-H1000 'T'
11057-H2300 '13' for 1967-1973 engines [97 mm length]
11057-H5700 '13' for 1974-up engines [111 mm length]
Bolts are the same for A10/A12/A14/A15, but:
  • A14/A15 require the stronger bolts (marked '13')
  • A14/A15 has one longer bolt (marked '13')
    174_61f9b21aa96ea.jpgPost click for topic
  • redesigned A12 use the longer bolt (marked '12T')
A14/A15 long center bolt
23623.jpgAlbum 23623 22286.jpgAlbum 22286
  • '12' bolts are the medium torque version, used on all A12 after about 1972. The 'T' center bolt matches, and is for the early A12. The longer 'T12' bolt is for the late A12 (mid-distributor version) and is the same length as the A14/A15 '13' center bolt
  • the '13' bolts were designed for the B110 GX, but used for A14 and A15 afterwards. The center bolt is apparently marked '13', short for early A12, and long A14/A15.
Strengthened Cylinder Head Bolts
24733.jpgAlbum 24733
1973 A12 (early engine, upgraded H1000 bolts)
Torque: 40-43 ft-lb
CENTER BOLT: 8 mm central portion (head marked 'T')
OTHER BOLTS: 9 mm
174_61f9b20aab940.jpgPost 496525
174_61f9b226472ee.jpgPost 496525
'12' bolts
174_50033e73ecea0.jpgPost 413008 174_50033e859f7a8.jpgPost 413008 174_50033e8cbbcd9.jpgPost 413008
Better to use the GX '13' center bolt, which is high-tensile chromoly V steel
4775.jpgAlbum 4775 7952_4cf7626132cc9.jpgPost 348263 7952_4cf7639da9b87.jpgPost 348263
"13" bolts were first used on the twin-carb A12GX Engine, as opposed to single-carb engine bolts. "13" bolts can be used with any early engine (they are simply stronger than the earliest bolts).
Note that A12/A12A/A13/A14/A15 all may use the '13' bolts, but the center bolt differs between early engines and late engines.
Center bolt 11057-H5000 and 11057-H5700 are interchangeable
6595_4a2b961066620.jpgPost 257619
Original Lo-torque bolts (B10 & early B110 -1172) - 36 ft-lb
* 11056-18001 BOLT-FIXING CYLINDER HEAD SHORT
* 11057-18000 BOLT-FIXING CYLINDER HEAD LONG
* 11058-18000WASHER-LOCK FIXING CYLINDER HEAD
Newer medium torque bolts (1272-) - 43 ft-lb
* 11056-H1000 BOLT-FIXING CYLINDER HEAD SHORT (9 needed) $2.90
*  BOLT-FIXING CYLINDER HEAD LONG [Center bolt] $2.51
   superseded by 11057-H5000/11057-H5010
* 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD $2.28
A12GX, A12T, A12S, A13, A14, A15, A12A - 58 ft-lbs
* 11056-H2301 HEAD BOLT SHORT (9 needed) $3.96
  Also used by Z16/Z18/Z20/Z22 (10 per engine)
  NOTE Some newer lo-power (round port) A12S are spec'd for 11056-H1000
* 11057-H2301 BOLT-CYLINDER HEAD LONG, TO OIL GALLERY (TO 6/73) $3.88
  one needed
* 11057-H5700 BOLT-CYLINDER HEAD LONG, TO OIL GALLERY (FROM 7/73) $4.03
  one needed
  Also used by Z24, KA24E, NA20P (10 per engine)
  replaced 11057-H5000 (lo-torque version)
  * used by 1988- D21/WD21/C22 Z24 engine
A12: Long middle bolt marked 'T' (medium-torque)
A14: Long middle bolt marked '13' (hi-torque)
Hi-torque bolts marked "13" on the head. Remove the valve cover to verify.
23377.jpgAlbum 23377
head bolts
Cro-Mo-V steel
13T
Lock Washer
* 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD -8504 $2.28
* 11058-21002 Washer Cyl Head 8504- $2.57
22287.jpgAlbum 22287
KA24E - 1989-1993 Nissan 240SX
11057-H5010 10 needed
* Same as Datsun 1200 center bolt
KA24E - 1994-1998 Nissan 240SX
11056-F3F01 10 needed. TTY bolts, do not reuse
* reportedly shorter than Datsun 1200/KA24E SOHC
Z20/Z22 Datsun 720
11056-H2301 10 needed
* Same as Datsun 1200 (9 needed)
Z24 Datsun 720
11057-H5000 10 needed
* Same as late Datsun 1200 (center bolt)
ARP Head Studs
Main: ARP
 Web Search: A型ヘッドボルト
