Air conditioning
Revision as of 20:24, 22 November 2025; view current revision
Category: Heating And Ventilation Systems
Datsun 1200, unlike the Datsun 1000, was designed with air conditioning in mind. However, it was still a dealer-installed add-on option and so varied by country and region. In April 1978 it became a factory option for Japanese market Sunny Truck. Also known as a cooler.
I'm cool, are you?
9099.jpgAlbum 9099
But then my datsun's air conditioned
Parts Needed
Buy Universal Air Conditioning kits - $500 on eBay. $1300 from Summit. Contain compressor and everything needed except engine mounting brackets and V-belt.
  • Pump (Compressor) & mounting bracket
  • Double crankshaft pulley & V-belt
  • Condensor (radiator-like unit)
  • Filter dryer/receiver
  • Evaporator (under-dash unit)
  • Hoses
  • Wiring
double-belt Crankshaft Pulley
20080.jpgAlbum 20080
Since B110 A/C is fairly rare, you can source most of the parts from a B210 or B310. Only the interior vent setup is needed specific to the 1200.
13934.jpgAlbum 13934
9378.jpgAlbum 9378 15371.jpgAlbum 15371
Installation
  1. Install all the parts, except leave the dryer/receiver plug and unplumbed
  2. Drive to the aircon service shop
  3. They will evacuate the system (vacuum pump), charge with R-134a and appropriate oil
Compressor
The compressor pump bolts to the engine and is driven by a v-belt. A double-groove Crankshaft Pulley is fitted.
  • Early (to 1979): York-type compressor uses aluminum case. Commonly used from 1958-1980, they last a long time and are generally interchangeable between different car makes. When replacing, unbolt your clutch unit and bolt it to the new compressor.
  • Late (from 1980): Compact swash-type (radial) compressor
York-type | Radial
21309.jpgAlbum click to view 21308.jpgAlbum 21308
27630-G1660 COMPRESSOR-COOLER DKKC
27630-W7002 COMPRESSOR-COOLER DKKC [B421]
* JDM Datsun B120 8110-8910
* JDM Datsun 720 L18 7909-8105
92610-G1900 COMPRESSOR-COOLER DKKC [B421]
* B120 8910-
11910-G1661 BRACKET-COMPRESSOR 7804-7907
* 11911-G1661 BRACKET-COMPRESSOR [2nd piece]
11929-H1000 BELT-COMPRESSOR L-810 7804-7807
11910-G1615 BRACKET-COMPRESSOR 7908-8910
11910-95W00 BRACKET-COMPRESSOR 8910-
11929-G1615 BELT-COMPRESSOR L-814 7808-
11925-A0100 PULLEY ASSY-IDLER,COMPRESSOR 7804-7807
11925-G1615 PULLEY ASSY-IDLER,COMPRESSOR 7808-
11917-M0100 BOLT-ADJUST 7804-7907
* 11933-A0100 NUT 7804-7907
Engine Brackets
Various types of brackets were used over the years to fix the compressor to the engine. NOTE: early A12 and late A12 brackets differ.
You can:
  • Fabricate your own brackets
  • Buy used brackets from a B110/B210/B310 or Cherry/Pulsar
  • Buy new
Compressor Types: YORK or axial
Evaporator
RHD factory Nissan
15193.jpgAlbum 15193
Seen in USA
15372.jpgAlbum 15372
LHD kit by Vintage Air 672001-VHY $309 at Summit
Australia aftermarket
5060.jpgAlbum 5060
PB110 with triple-vent unit (knobs below vents)
174_65ad9242af80f.jpgPost 498203
Electric Compressor
New compressors are available driven by built-in electric motor rather than the vehicle engine belts. All you need is a high output alternator to power it, no need to track down engine mounting brackets and pulleys from ripoff merchants only to find you have the wrong components. The new unit is more efficient than the clapped out old 50 year old units. You also have the option to mount the unit in a remote location to keep a clean engine bay.
12V electric compressors are available from heavy-class trucks, and could be used — however these can be $10,000 new. Classic car customizers like Sierra have units for $2500. The higher capacity units (10,000 BTU) are recommended (1972 systems for the 1200 were 12,000 BTUs). This strong a compressor can draw 60-80 amps, necessitating fitting a 120A alternator. Possibly an inexpensive used GM 120A alternator could be adapted. So you would be trading a belt-driven compressor for a larger belt-driven alternator. But there are still advantages, including the ability to turn off the Aircon when ultimate performance is called for, and easier engine repairs. Plus the new compressors are variable-speed for improved efficiency and actually take less power to drive than the old belt-driven models.
A good used electric AC compressor from a 2012-2018 Ford Focus Hybrid (compressor YCC348) or any 2005-up Prius or Lexus hybrid vehicle might be inexpensive from the wreckers, or new as cheap as $450. Units range in price between around $1000-2500AUD. However, these run on high-voltage AC power. The compressors may include the DC-to-AC inverter, but where would you get the 180 to 300 volts to power it?
Left-hand Drive
Ecuador
20065.jpgAlbum 20065
Taiwan
28781.jpgAlbum 28781
INSTALLATION OF 1971 AIR CONDITION KIT IN 1972 VEHICLES
Bulletin Number: TS72-05
Date: January 11, 1972
Classification Number:
Section: General Information
Models: All
Frigiking Air Conditioning units are redesigned anually for each model Datsun vehicle Never attempt to install a 1971 model air conditioning unit on a 1972 model vehicle, nor a unit designed for one model vehicle on a different model vehicle The units are not interchangable, either from year to year or from model to model
1972 Brochure
24798.jpgAlbum 24798 24799.jpgAlbum 24799 24800.jpgAlbum 24800
The air condition for Datsun cars is made by Frigiking. It's the only system approved by the Datsun factory.
Except that the Factory used a different brand. Frigiking was only used in USA.
USA Type 1
15622.jpgAlbum 15622
16243.jpgAlbum 16243 16244.jpgAlbum 16244 14556.jpgAlbum 14556 14557.jpgAlbum 14557\
Frigiking dealer-installed package. Larger capacity than 240Z, but less than 510 or 521 pickup
24400.jpgAlbum 24400
PERFORMANCE
Capacity: 12,500 BTU/hour
Airflow: 180 CFM
Evaporator Coil: 3/8 x .016 cu tubes, 4 rows
 staggered pattern, 12" x 5" x 2-1/2"
 fin series 120 flat aluminum
Expansion Valve: 1-1/2 ton
ELECTRICAL
Fan Switch: Reostat
Thermostat: Ranco type A-30
 Cold cut-out: 28°F ±2°
 Cold cut-in: 36°F ±2°
 Warm cut-out: 58°F ±4°
Fan Motor: Double shaft, single speed, 4600 RPM @ 13.5 V
 11.5 amps maximum current draw
Clutch: Pitts 6" double groove 12V 4.0 amp
Wiring: SAE specification J558a
Overload Protection: Inline fuse 30 amps
COMPRESSOR: York 206 (6 cubic inches)
CONDENSOR: 3/8 x .016 cu. tube, 2 row inline pattern
 13 x 12 x 1-1/2 fin seris 10 fins/inch
GENERAL KIT COMPONENTS: All meet SAE specifications
COMPRESSOR MOUNT KIT
Brackets are 1/4" hot rolled steel, arc welded and painted
Drive Pulley material: ASTMA-159, Class G3000, grey cast iron
 precision machined, balanced and painted
Idler Pulley: Cast iron, fully machined with single-row sealed ball bearing
Attaching Hardware: Grade 5, black, rust resistant
Compressor Drive Belt: Standard automotive quality, 500 section
EVAPORATOR SECTION
Material: High-strength injection-molded plastic case
Knobs: injection-molded plastic
USA Type 2
7450.jpgAlbum 7450
USA Type Frigette
Frigette Brand. Aftermarket kits still sold at JC Whitney!
2187.jpgAlbum 2187
Optional Fan
Nissan option flex-fan (dealer item)
3053.jpgAlbum 3053
USA catalog
* 21060-H1001 FAN-COOLING A12 (standard B110 fan)
* 21060-A4605, 21060-N0100 FAN-COOLING D=330 FOR TROPICAL USA
  330 mm diameter
NISSAN GENUINE PARTS
Sloop sailboat, Scuba diver & Yellow B110, dash-type air conditioner
28904.jpgAlbum 28904 28905.jpgAlbum 28905 28906.jpgAlbum 28906
oh! cool
日産純正
カークーラー
oh! cool
Car Cooler
B310: CAR AIR CONDITIONER for NEW DATSUN Sunny
30969.jpgAlbum 30969 30970.jpgAlbum 30970
ひろびろサニーに、いま、新しい爽やかさが
新型サニー専用リヒートタイプ·カーエアコン
カラをイ破れ。
日度純正 新型サニー専用
カーエアコン
Bring a new level of freshness to your spacious Sunny.
Reheat-type car air conditioner specifically designed for the new Sunny.
Break the shell.
Genuine Nissan product, specifically designed for the new Sunny.
Car air conditioner
新型サニー専用カーエアコン Car air conditioner exclusively for the new Sunny
Sanden
Sanden Cast
Kit with Sanden compressor 508 S47, 508 cast bracket and A12 'W' pulley (double V-pulley)
31232.jpgAlbum 31232
Sanden Steel
Uses the now-common Sanden compressor bracket for late A12 engine.
custom or off-the-shelf kit?
  • extra-large condensor
  • dual electric fans
  • use with the evaporator (or interior evaporator) of your choice
Engine compartment components
31224.jpgAlbum 31224
Sanden compressor TR-70 TURBO-ROTARY Model No. 9777
31225.jpgAlbum 31225
use with Sanden engine compressor bracket
174_63c632f538f1a.jpgbracket
Sanden Sunny Truck Kit
Starting 1978 April a factory cooler kit was offered with upright compressor and standard interior unit. It is a very nicely designed unit, however the interior cooler protrudes into the passenger legroom and precludes using a package tray. Would you rather have aircon or a Package Tray?
In August 1979 this kit was updates with a different compressor and low-mount idler.
20078.jpgAlbum 20078
This kit is beautiful and easy to install. Unfortunately the interior cooler unit is bulky and protrudes farther into the passenger legroom than other types.
20087.jpgAlbum 20087
Retail Kit
Acqua Garage sells a R-134a kit, 2015 price was 300000 Yen (about $3000 USD).
  • 1 hanging unit Unicla IMPERIAL III with 5/16 - 5/8 O-ring
  • 2 AC compressor UP-90 = U02/A / A charging valves (no)
  • 3 12 x 12 Condensor plust reducer joints
  • 4 receivers & receiver BK
  • 5 electric fan unicla 8 inch PUSH & banding
  • 6 General purpose relay 2 pc
  • 7 a. Special design compressor fixing bracket.
  • 8 AC for stock taking crank pulley
  • 9 cooling fan & spacers
  • 10 hose
Unicla hanging unit 12V R134a right hand drive AG ALL-BLACK specifications (genuine Unicla, not a "Star Road" made in China knockoff)
O-rings made in Japan products composition 5/16-5/8 UNIF wiring fuse + universal mounting bracket included
AG special compressor UP 90 + U02 < gas valve protection > 12 V R134a O-rings
A/A clutch parts w/< front thickness and > pressure valve with 1/2 - 5/8 UNIF
comes with compressor fixing bracket for the A-series block
Condensor 12 inch×12 inch T22mm O-rings
Fitting F3/8-O5/16 reducer + F1/2-> O1/2 < reducer
Receiver-dryer and liquid tank < filter > PSW with O ring 5/16S-5/16S | bracket
Unicla electric pusher fan 8-inch | tie-locks
Relay
Crank pulley with extra groove for AC compressor drive belt
Hoses similar to this, made of varying quality components
OPTION 25000 Yen - 6-blade cooling fan
OPTION 58000 Yen - genuine brass radiator, fit original fan shroud (not included)
OPTION 13000 Yen - fan shroud
Front-distributor A12
Japan setup for front-distributor A12
21644.jpgAlbum 21644 21645.jpgAlbum 21645 21646.jpgAlbum 21646
1977
Non-factory Unicla 311609 from 1977 Sunny Truck H-B120
Unicla imperial-III under-dash unit
unicla-1.jpg unicla-2.jpg unicla-3.jpg unicla-4.jpg unicla-5.jpg unicla-6.jpg unicla-7.jpg unicla-8.jpg
Unusual compressor mount
25585.jpgAlbum 25585 25586.jpgAlbum 25586
idler pulley
Unicla DA-299 compressor
unicla_DA-299-1.jpg unicla_DA-299-2.jpg unicla_DA-299-3.jpg unicla_DA-299-4.jpg
Unusual 6-blade fan
Idle Speed Control
In 1989 they added the FICD (Fast Idle Control Device) to raise idle speed about 100 RPMs when the compressor runs.
See Main Article: FICD
Legroom
Since the cooler unit takes up some of the passenger legroom, what to do? One enterprising 1200 fan mounted the cooler unit in the dash:
18256.jpgAlbum 18256 18767.jpgAlbum 18767
Of course the downside is there is no glove box.
2185.jpg 2187.jpg 2199.jpg 2209.jpg 2210.jpg 2341.jpg 2495.jpg 3053.jpg 3811.jpg 4163.jpg 4164.jpg 4305.jpg 5060.jpg 5063.jpg 7777.jpg 9377.jpg 9378.jpg 11444.jpg 12038.jpg 13181.jpg 13934.jpg 14556.jpg 14557.jpg 14950.jpg 14953.jpg 15192.jpg 15193.jpg 15194.jpg 15622.jpg 16243.jpg f16244.jpg 17263.jpg 17654.jpg 17655.jpg 18256.jpg 18710.jpg 18767.jpg 21300.jpg 21301.jpg 21302.jpg 21303.jpg 21304.jpg 21305.jpg 21306.jpg 21307.jpg 21308.jpg 21309.jpg
