1200GXman
From Datsun 1200 Club
Category: User Community
Club member Hendrik (1200GXman) is out of South Africa. He has a nice, well cared-for original condition Datsun 1200 GX sedan.
3747.jpgAlbum 3747
Home Page
archive: http://geocities.com/my1200gx
My 1977 Datsun 1200 GX
Please be patient as there is allot of pictures that must load......
If some pictures have poor quality, it is due to it being scanned as I did not have a digital camera at the time.
This website is about my Datsun 1200 GX that I have restored to how it currently looks on the photos.
Please go through my website and enjoy the story of what has been done.
At the moment it is a stock A12 GX engine with the following specs:
1. GX cylinder head. Although this doesn't sound much impressive. The GX cylinder head is a performance cylinder head that was only fitted to GX models. A standard GX head flows on a flow bench the same as a A12 cylinder head that has been ported and gas flowed with larger valves. The GX head also has double valve springs fitted that gives it the ability to rev higher than other engines. Standard it can rev to 6400rpm for max power of 83 hp and redline at 6700rpm. With a balanced A12GX you can expect to be able to rev 8000 rpm.
2. GX Exhaust Manifold. They work out of the factory just as good as a performance extractor.
3. Two Hitachi SU's carburators. The GX came out with twin carburetors. They gave the GX it's low torque and very good fuel consumption with good power. Personally I would say they are after the Weber sidedraft the best carb you can fit to your Datsun engine. These carbs are still being sought after by Datsun/Nissan people.
The Beginning
The following is pictures I took prior to the challenge of taking it apart and respraying it.
The color that it was resprayed with is the same color the car was originally sprayed with at the factory, lime yellow.
Here is the pictures at the spray painter's house. In the left picture he is visible. To this day I am still thankful towards him in doing
this job for me with the most detail I have ever seen.
He works from his home and has converted his garage into a good and clean sprayroom.
28261.jpgAlbum 28261 28262.jpgAlbum 28262
Front View (Left Picture): Here you can see how ugly it looks without the wheel caps.
Left Back View (Right Picture): If you examine the picture, you will see that the boot and just behind the back door the color is a lighter color than the rest of the car. This is because it was discovered in the spraying and dismantling process the car had a bit of a hit on the back by the previous owner. The color could obviously not be matched that caused it to look as if color has faded due to sunlight.
The Project Begins
28263.jpgAlbum 2826328264.jpgAlbum 28264
Damn. I almost got them to fit into each other to look as if it is one picture. This is into the project where all doors and panels were removed to be worked with. The windows front and rear were also removed.
28265.jpgAlbum 28265 28266.jpgAlbum 28266
This is the engine bay before it was painted yellow again. You can clearly see in the left picture that the firewall also had a bit of color fade. I think it is due to 25 years of engine heat. In the right handed picture you can see the part above the wheel is still relatively rust free. The spray painter said that he saw cars in much worse condition where it started to rot holes into these parts of the cars. Mine only had little rust in these parts that was cleaned away with a wire brush.
28267.jpgAlbum 28267 28268.jpgAlbum 28268
This is the one of the front guards in the spray process. It was sprayed and after the paint dried it was treated on the inside with some rubberizing to keep the rust away.
28269.jpgAlbum 2826928270.jpgAlbum 28270
The spray painter also rubberized the mudguards, front and rear, for rust protection. Right hand picture the lights have been fitted to the body. You can clearly see how good the paintjob looks. When looked at from an angle in direct sunlight the little bit of lime green color can be seen.
28271.jpgAlbum 28271 28272.jpgAlbum 28272
Here is one of the front doors when sprayed. They were also rubberized on the inside for when water comes inside the door during heavy rain. On the right picture is when the doors were assembled and fitted to the car.
Here is the engine bay after it was resprayed. The engine was not removed, but everything that could be removed from the firewall and sides, including the radiator, was removed. On the right just beneath the rubber where the shock is inserted you can see that I still have the original Datsun engine plate. Here can be seen how plain the engine looks without being sprayed the same color as the body.
28274.jpgAlbum 28274 28275.jpgAlbum 28275
The engine bay as it currently is. I removed the tappet cover and the airbox and they were also sprayed the same color as the car. I am really happy with the results.
28276.jpgAlbum 28276 28277.jpgAlbum 28277
This is the final pictures with just the grill to be fitted. I still have the old factory rims on the car here.
28278.jpgAlbum 28278
This is the mags I fitted. Make: Racing Heart Concept.
Mags name: Rocketeer.
Here is some pictures of the interior.
28279.jpgAlbum 28279 28280.jpgAlbum 28280
The seats have no cracks and the dashboard is also still crack free. I try my best to keep the car out of the sun.
28281.jpgAlbum 28281 28282.jpgAlbum 28282
Here is some shots of the outside
2738.jpgAlbum 2738 28283.jpgAlbum 28283
28284.jpgAlbum 28284
3747.jpgAlbum 3747
The Finished product that I would like to keep this way for a long time to come.
In direct sunlight it is a yellow color. As can be seen from this picture, in the shade it has a little greenish yellow color.
2892.jpgAlbum 2892 3745.jpgAlbum 3745 3746.jpgAlbum 3746 8391.jpgAlbum 8391 10755.jpgAlbum 10755 12742.jpgAlbum 12742 13087.jpgAlbum 13087 13132.jpgAlbum 13132 13133.jpgAlbum 13133 13363.jpgAlbum 13363 14452.jpgAlbum 14452 14453.jpgAlbum 14453 14614.jpgAlbum 14614 15399.jpgAlbum 15399
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=1200GXman"
This page has been accessed 6,495 times. This page was last modified 08:20, 24 November 2021. Content is available under Datsun 1200 Club.
