Grille
From Datsun 1200 Club
Category: Body
Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the sedan grille changed for 1972.
#Stainless Grille: Sedan, Wagon & 1971-1978 ute
#Facelift Grille (1972 JDM Sedan & South Africa sedans)
#Coupe Grille (black headlight surrounds)
#1978-1989 Ute Grille (silver headlight surrounds)
#Late Sunny Truck/Bakkie Grille (1989-2007)
#Sunny Excellent Grille
Stainless Grille
Early sedan grille
20857.jpgAlbum 20857
See Main Article: Sedan Grille
Sedan grille "D" and "S" emblems
917.jpgAlbum click to view 6001.jpgAlbum click to view
Plastic Grilles
20861.jpgAlbum 20861
1. Silver headlamp surrounds (#mid-model ute)
2. Black headlamp surrounds (#coupe GX)
3. With Silver center strip (#coupe non-GX)
Black headlight surrounds: (#coupe)
1741.jpgAlbum 1741
Silver headlight surrounds: Mid #Pickup (1978-1989)
Emblems: Rectangular for pickup, Round for coupe
26382.jpgAlbum 26382
Coupe Grille
See Main Article: Coupe_Grille
GX Coupe | DX/GL Coupe
8580.jpgAlbum 8580 3918.jpgAlbum 3918
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck/ute/bakkie used the stainless Sedan Grille.
15804.jpgAlbum 15804 736.jpgAlbum 736
Mid-Model Truck
1978-up Truck/ute/bakkie. This grille looks nearly identical to the Coupe grille, except:
  • Silver headlight surrounds (coupe has black surrounds)
16656.jpgAlbum 16656 5720.jpgAlbum 5720
  • Rectangular center emblem (Coupe is round)
  • Emblem screws have horizontal arrangement (Coupe is diagonal)
Coupe or Ute grille accepts both emblems
Coupe emblem - screws arranged diagonally
Pickup emblem - screws arranged (nearly) horizontally
385.jpgAlbum 385
To fit a Plastic grille to an early ute or sedan, add these tabs:
21713.jpgAlbum 21713
Square Headlight Truck
See Main Article: Square Light Grille
From October 1989
* JDM Sunny Truck (late B122)
* South Africa bakkie (B140)
Facelift Grille
For 1972, Japan-model 1200s received a minor facelift.
Coupe
Coupe continued to use the original grille during the 1972 facelift. Only the badges were changed.
Sedan
See Main Article: Sedan Grille, Facelift
Late JDM grille + intricate "S" grille emblem
457.jpgAlbum click to view 752.jpgAlbum 752
Customized Grilles
Gold
12785.jpgAlbum 12785
Blackout center ornament
24625.jpgAlbum click to view
120Y grille
174_55ea1becdb6be.jpgPost 471955
four-eye
10528.jpgAlbum 10528
Chrome highlights
26395.jpgAlbum 26395
FRP
20646.jpgAlbum 20646
Ɛ̃fini emblem (a.k.a. Mazda Efini badge/infini) 1991-1997
10210.jpgAlbum 10210
Kustom grille
11725.jpgAlbum 11725
Color Matched
2099.jpgAlbum 2099 2100.jpgAlbum 2100
D21 Style
Bprojects Nissan D21 style grille on Datsun 1200 truck
8772.gifAlbum 8772
  • D21 was marketed as "DATSUN truck" is Japan
  • D21 was marketed as "Nissan Hardbody" in North America
  • D21 was marketed as "Navara" in much of ROW (rest of world)
D21 Hardbody minor update 1993-1997
400px-Nissan-Hardbody.jpgWIKI go to Wikipedia
JDM look
Coupe-grille with custom insert
5859.jpgAlbum 5859 6761.jpgAlbum 6761 7497.jpgAlbum 7497 16539.jpgAlbum 16539 9956.jpgAlbum 9956 9955.jpgAlbum 9955 grille.jpg
Facelift custom
10195_4d39306f36cd5.jpgPost 354127
Flush
2843.jpgAlbum 2843 7061.jpgAlbum 7061 15945.jpgAlbum 15945
Datrotor: Made up my own mirror finish stainless grill that deffenetly is a 1off.every single bolt that isn't hi tensile has been mirror polished finish and is all stainless
D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpgPost click for topic D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpgPost click for topic 3bcf07cd.jpg
Blackout Grille
Coupe/Ute grille painted black
3972.jpgAlbum 3972 15846.jpgAlbum 15846 22270.jpgAlbum 22270 12784.jpgAlbum 12784
Square Eye Retrofit
rectangular headlights - dual or quad
Billet
Aluminum Slat
174_549787fb031b9.jpgPost 461992
174_54978870025dd.jpgPost 461992 26394.jpgAlbum click to view 174_54978883e992b.jpgPost 461992
GDM Style
Jetta A2 headlights (1984-1992) retro-fitted a 1200 -- for the GDM look
Mercedes
8584.jpgAlbum 8584
BMW
VW Caddy look (see post for more pics)
174_56d798f9ac013.jpgPost 476836 5668.jpgAlbum 5668
Bimmer E30 datsunb120
fgjfgj435.jpgPost click for topic 103_0143.jpgPost click for topic
Mounting
Each grile type has unique mounting variation.
A plastic grill will not bolt in place of a sedan grille and vice-versa.
24815.jpgAlbum 24815 24814.jpgAlbum 24814
Ditto for round vs square headlight grilles.
The four Datsun 1200 grille types and their mount points
18436.jpgAlbum 18436
See:
* Sedan Grille Mounting
  19558.jpgAlbum click to view
* Coupe Grille Mounting
  19571.jpgAlbum click to view
* Coupe Grille in Sedan: add the missing brackets.
* Sedan Grille in late Sunny Truck
* Coupe Grille in late Sunny Truck
  20859.jpgAlbum click to view
For a late Sunny Truck with square headlights, you also need to fit round headlights. See Converting
Coupe/Mid-ute
16511.jpgAlbum 16511
Dimensions
Coupe/Mid-ute/Late-ute
* 123 x 22 x 10 cm box
Sedan/Early-ute
TBD
PB110
PB110 Sunny Excellent Grille
174_61de5fe583b3f.jpgPost 496430 174_61de88f81f378.jpgPost 496433
GX with fog lamps
741.jpgbrochure
DX, GL without fog lamps
1985.jpgAlbum 1985 174_61de88ea649cb.jpgPost 496433
174_61de890226af7.jpgPost 496433 1533.jpgAlbum 1533
62302-H2525 GRILLE-radiator (gray) DX, GL
62302-H2725 GRILLE-radiator (dark gray) GX
62310-H2525 MASK-fog lamp, with screw 2 DX, GL
Grille with fog lamps/delete plates unbolted
174_61de5f4c1bd2b.jpgPost 496430
18843.jpgAlbum 18843
Masks (foglamp delete plates) comes with the DX/GL grille
174_61de5f6687837.jpgPost 496430174_61de82424a18a.jpgPost 496431 29777.jpgAlbum 29777
On the back of the grille are two brackets that look like the 1200 sedan grille mounting brackets. On the 1400 these are actually the fog lamp brackets (#8 in the parts diagram)
62321-H2500 BRACKET ASS'Y-fog lamp (L.H.)
62320-H2500 BRACKET ASS'Y-fog lamp (R.H.)
174_61de83336abd5.jpgPost 496432 174_61de8340736f9.jpgPost 496432
174_61de834d377f7.jpgPost 496432 174_61de83572c465.jpgPost 496432
This grille is missing the metal fog lamp brackets and lower grille bracket
174_61deabec246c7.jpgPost 496434 174_61deac212bfa7.jpgPost 496434 174_61deac4ddbf43.jpgPost 496434
174_61deac6142702.jpgPost 496434 174_61deabd0cab5c.jpgPost 496434 174_61deabe0ddbe2.jpgPost 496434
PB110 Custom
PB110 sedan retrofitted with chromed B110 Coupe grille. The chrome matches nicely with the PB110 corner lights
U00017593481_10_001.jpg U00017593481_18_001.jpg U00017593481_1_001.jpg U00017593481_16_001.jpg
See Main Article: Grille Photo Index
keywords: グリル
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Grille"
This page has been accessed 97,815 times. This page was last modified 03:57, 11 January 2025. Content is available under Datsun 1200 Club.
