Turbo exhaust manifolds
From Datsun 1200 Club
Category: Forced Induction
The stock manifold may be used with a J-pipe for mounting a turbo. But a more direct mount is more efficient (allows more power).
Direct Mount exhaust manifold
13630.jpgAlbum 13630
Stock Manifold with #J-pipe
topgear manifold | rev210 manifold
8137.jpgAlbum 8137 10599.jpgAlbum 10599
This factory A14 forklift exhaust manifold might be useful:
1090.jpgAlbum 1090
Exhaust manifold ideas
518.jpgAlbum click to view 13663.jpgAlbum 13663
J-pipe
The stock manifold may be used with a looping pipe (J-pipe) for mounting a turbo. But a more direct mount is more efficient (allows more power), the J-pipe is the easiest and quickest to fabricate. It will make a lot more HP than a stock engine.
1000.jpgAlbum 1000 999.jpgAlbum 999 2949.jpgAlbum 2949 2948.jpgAlbum 2948
POST B110SSS: The exhaust of a A15 with a 'j' made out of plumers steam pipe bends works very well and does'nt require any bracing as it is inherently very strong, similar to what 1200 rc has posted, a bit shorter. All flanges can then be profile cut from a decent thickness plate steel and mig welded to the steam pipe.
J-pipe (u-pipe?) made out of steam piping
5881.jpgAlbum 5881 5904.jpgAlbum 5904 5906.jpgAlbum 5906
Bottom Mount with Stock Manifold
4589.jpgAlbum 4589 4590.jpgAlbum 4590 4591.jpgAlbum 4591 4592.jpgAlbum 4592
Top Mount with Stock Manifold
See Turbo#steveo 1
frankthedolphintrainer
13245.jpg 13266.jpg 13267.jpg 13524.jpg 13630.jpgAlbum click to view 13641.jpg 13692.jpg 13693.jpgAlbum click to view 13768.jpg 14248.jpg
Big bore 1.5 inch mandrel bent steam pipe with HPC coating
datto1000wagon
18884.jpgAlbum 18884 18885.jpgAlbum 18885
16585.jpgAlbum click to view 16584.jpgAlbum click to view 16583.jpgAlbum click to view 16582.jpgAlbum click to view 16563.jpgAlbum click to view 16562.jpgAlbum click to view 16561.jpgAlbum click to view 16560.jpgAlbum click to view
shaun
shaun's top mount manifold. A14 with a T03 turbo (ex-VL), +1.5mm forged pistons and runs on straight LPG (new gas research), all fitted to a red 1200 ute. SOLD 23 June 2005
6680.jpgAlbum 6680 6681.jpgAlbum 6681 6682.jpgAlbum 6682 5365.jpgAlbum 5365
zigmondo
Main Forum discussion: POST A15 turbo manifold build
  1. Start with manifold flange
  2. Build up runners using steam pipe (for strength and heat resistance)
  3. Add turbo flange (in this case, 3-bolt Subaru flange)
16236_5979989c141ed.jpgPost 485711 16236_59801c904890e.jpgPost 485746 16236_59801c9a54722.jpgPost 485746 16236_59801c9a54722.jpgPost 485746 16236_5b4c4a8486819.jpgPost 488941
See Main Article: Turbo Manifold Photos
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Turbo_exhaust_manifolds"
This page has been accessed 12,009 times. This page was last modified 02:43, 17 November 2021. Content is available under Datsun 1200 Club.
