Engine Mounts
From Datsun 1200 Club
Category: Engine Mechanical
See also: Crossmember
#Insulator | #Brackets
20928.jpgAlbum 20928 20923.jpgAlbum 20923
Rubber Insulators
Engine mounting insulator sits between the engine mounting brackets and the crossmember, and provides insulation from noise and vibration.
Brackets
B110 (1970-1973)
25736.jpgAlbum 25736
Late 1200 (1974-1994) + B210 + B310
20934.jpgAlbum 20934
B110 and B120
Which brackets you need depend on the vehicle's crossmember.
Front: 1970-1973 1200 engine tall crossmember (B110/B120)
Rear: 1974-up 1200 tall/short engine crossmember
13676.jpgAlbum 13676
Not only does the new-style engine have a lower right-hand mount, but the mounts are further back 35mm (~1-3/8"). These photos shows how far back:
There are TWO types of right-side brackets:
  • Top: original style
  • Bottom: new style for revised crossmembers
    • Allows fitment of reduction gear starters
    • Starting with 1978 B210 USA (H8500)
    • All B310 (H8500)
    • Starting with 1985 B120 JDM (G1900)
NOTE: If you mix early engine with late crosmember (or vice-versa) it will require some modifications. In this case see A-series Engine Swaps.
Early Engine Mounting
1970-1973 Datsun 1200 uses bracket that fit the early A12 engine. Note that the left-side bracket is stepped to fit the engine block.
20925.jpgAlbum 20925 19820.jpgAlbum 19820
B110 Insulator
20929.jpgAlbum 20929 20940.jpgAlbum 20940
Late Engine Mounting
1974 and up engines are different, and 1974-up 1200s use a corresponding crossmember
20924.jpgAlbum 20924
Engine Mounts dimensions
25421.jpgAlbum 25421
High side mount (similar to earlier)
11221-H5000 BRACKET-ENGINE MOUNTING, RH 7510-8503
11221-G1900 BRACKET-ENGINE MOUNTING, RH 8504-
Low side mount (new crossmembers)
11222-H5001 BRACKET-ENGINE MOUNTING, LH 7510-8503
* Same part for 74-up B120 (ute), B210 and B310
11222-G1900 BRACKET-ENGINE MOUNTING, LH 8504-
11221-G1900 RH
2563.jpgAlbum 2563
11222-H5001 LH
2564.jpgAlbum 2564
1978 Revision
1978 Reduction gear starter modification
23748.jpgAlbum 23748 20923.jpgAlbum 20923
B10 Mounts
The Datsun 1000 parts look similar to B110 mounts, but have different part numbers.
11221-18000 BRACKET-engine mounting front (R.H.)
* stepped bracket - looks similar to B110 LH bracket
11222-18000 BRACKET-engine mounting front (L.H.)
* flat (unstepped) bracket
B110 Datsun 1200
B10 Datsun 1000
31274.jpgAlbum 31274 31275.jpgAlbum 31275
RH stepped bracket
2569.jpgAlbum 2569
Late Engine Into Datsun 1000
For putting a 1974-up engine into a B10, see POST Chris's Rip Snorter A12 & Red B10
B210 Mounts
20926.jpgAlbum 20926
11223-H5000 INSULATOR-ENGINE MOUNTING FRONT V [8 mm studs]
* also used by 1976-1985 Datsun 1200
11223-H6100 INSULATOR-ENGINE MOUNTING FRONT USA -0874 [for A13 engine]
* ? mm studs, A13 engine harder mounts]
11223-H7500 INSULATOR-ENGINE MOUNTING FRONT except Van [10 mm studs]
11223-H7300 INSULATOR-ENGINE MOUNTING FRONT USA 0974-
* [10 mm studs, A14 engine softer mounts] $30.47 USD
* replaces 11223-H7500
* replaces 11223-H6100 INSULATOR-ENGINE MOUNTING FRONT USA -0874
  [? mm studs, A13 engine harder mounts]
11221-H7301 BRACKET-ENGINE MOUNTING, FRONT RH
* USA -0777
USA 11221-H5000 BRACKET-ENGINE MOUNTING FRONT RH -0874
20517.jpgAlbum 20517
USA 11121-H7300 BRACKET-ENGINE MOUNTING FRONT RH 0974-1074
USA 11221-H8500 BRACKET-ENGINE MOUNTING FRONT RH 0877-
* Bracket notched for Reduction Gear Starter?
11222-H5001 BRACKET-ENGINE MOUNTING, FRONT LH
20516.jpgAlbum 20516
Right-side mount comparison:
Middle pair is B110 early, right is B210? (thin), left is B310? (thick)
20945.jpgAlbum 20945
B210 crossmember change for 1978 North America
Crossmember horns are farther apart, requiring new style RH bracket
B310 uses this new spacing
B310 Mounts
The B310 insulators have a metal wrap in case the rubber breaks, the engine won't move too far.
20927.jpgAlbum 20927
11223-H9100 INSULATOR-ENGINE MOUNTING FRONT RH [10 mm studs] $34.38 USD
11224-H9100 INSULATOR ASSY-ENGINE MOUNTING FRONT LH $44.32 USD
4689.jpgAlbum 4689
B310 insulators have a larger studs and locating pins, but otherwise are the same dimensions as B110 mounts.
11221-H8500 BRACKET-ENGINE MOUNTING, FRONT RH
Stronger, more rigid than ever - perhaps to reduce NVH (noise, vibration and harshness)
20930.jpgAlbum 20930 20935.jpgAlbum 20935
* Same as B210 and mid-model B120
16679.jpgAlbum 16679 20936.jpgAlbum 20936
Left and Right together
Engine Mounting Part Numbers
1 11223-H1000 INSULATOR-ENGINE MOUNTING FRONT (2) A12
2 11221-H1000 BRACKET-ENGINE MOUNTING FRONT RH A12
3 11222-H1001 BRACKET-ENGINE MOUNTING FRONT LH A12
4 08915-53810 WASHER-PLAIN FIXING INSULATOR TO (8) A12
5 08915-23810 WASHER-LOCK FIXING INSULATOR TO BRACKET (8) A12
keywords マウント エンジン マウンテング
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Engine_Mounts"
This page has been accessed 55,242 times. This page was last modified 04:18, 20 November 2025. Content is available under Datsun 1200 Club.
