Oil Pump Coolers
(Redirected from Oil cooler)
Category: Engine Lubrication System
An oil cooler can keep the oil from overheating, thus extending the life of your engine. This is called for in racing, or in extended high-speed driving. Normal driving does not benefit from an oil cooler, as oil is designed to work at a temperature of around 200 degrees Farenheit. Cold oil is is also bad. In a stock engine, the oil is cooled internally by the engine coolant, hence the importance of keeping the water temperature below 200 degrees, for example by using a 180 degree Thermostat.
Nissan Competition sells oil coolers, which utilize a sandwhich plate bolted between the Oil pump and the Oil filter.
The oil temperature is controlled by the engine coolant temperature. As long as the engine coolant ("water") does not overheat, neither will the oil. At this temperature, the good quality regular oil (inexpensive) will perform as good as the expensive synthetics in a street car. It is high temps that ruin regular oil whereas the synthetic oil can take high temps OK.
If you are racing or towing the oil may heat up. Fortunately oil cooler parts are not rare.
5353.jpgAlbum 5353 9226.jpgAlbum 9226 947.jpgAlbum 947
The sandwich plates are also available from racing supply companies like Earle's, Summit Racing, etc ‐ Ford type fits the Datsun. The the oil coolers are available from Jeff Taylor and others.
Transdapt Oil Sandwich Adapter #1313 for Fords and others with 3/4x16 thread.
Transdapt on A12
14743.jpgAlbum 14743 230.jpgAlbum 230 25732.jpgAlbum 25732
A12 oil filter C20 Vanette are nice and short and clear winged sumps.
7414.jpgAlbum 7414
Fittings on Competition Oil Pump
5226.jpgAlbum 5226 14742.jpgAlbum 14742
On CA18DET engine
14370.jpgAlbum 14370
Thermostat
A thermostat is recommended for efficient cold starts, and for working oil temperatures. Engine oil that is too cold will not burn off water vapor in the crankcase.
Summit Racing☁: Cold oil does not flow and does not lubricate correctly. Plus, moving cold oil robs power. These thermostats are designed to bypass the cooler until the oil reaches 215 [F] degrees.
POST ang94541: I keep my oil cooler covered most of the year because the oil temp doesn't get hot enough. It never gets above 180 F [in California].
MOCAL oil cooler thermostat is factory set for 180F (82 c) degrees.
[Spruce]: it has always been recommended to get the oil temperature just over 100°C during each flight to burn off the water which can contaminate the engine oil
Mounting
One possible place to mount the cooler is in front of the radiator.
7412.jpgAlbum 7412 7413.jpgAlbum 7413
A better location may be next to the radiator, where the A/C panel is.
23137.jpgAlbum 23137
9227.jpgAlbum 9227 9091.jpgAlbum 9091
Nissan Competition Parts
From 1984 Nissan Competition Catalog
Competition198439.jpg* 21305-H2310 OIL COOLER ASSY Easily adapted to 1200, B210 and 210 models with minor modifications. Designed for use with the competition Oil pump. Dimensions are 8.5"(w)x11"(h)x1.5"(d)
  • 21355-H2310 HOSE FOR OIL COOLER
  • 21356-H2310 HOSE FOR OIL COOLER
ニスモオプションオイルポンプオイルクーラー
31212.jpgAlbum 31212 27014.jpgAlbum 27014 8004.jpgAlbum 8004
オイルクーラー
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Oil_Pump_Coolers"
This page has been accessed 19,553 times. This page was last modified 20:01, 10 November 2025. Content is available under Datsun 1200 Club.
