Tail Lights
(Redirected from Sedan Rear Lights)
<-- back to Lighting_System
Taillights, tail lamps, or as Nissan calls them "rear combination lamps", combine the running lights, reverse lights, brake lamps (stop lights) and turn-signal lamps (blinkers).
Sedan (short) vs Coupe (long)
9806.jpgAlbum click to view
AUS/Europe: white-red-orange
Japan/USA/ZA: white-red-red
Sedan: AUS vs USA
10520.jpgAlbum 10520 1549.jpgAlbum 1549
Coupe: AUS vs USA
7034.jpgAlbum 7034 8570.jpgAlbum 8570
Wagon and Sedan (Australia)
5164.jpgAlbum 5164
Ute
2851.jpgAlbum 2851
Van (Australia)
638.jpgAlbum 638
Sedan (portugal)
47.JPGAlbum 47
Sedan: Europe orange blinkers vs USA red blinkers
2842.jpgAlbum 2842 9857.jpgAlbum 9857
Facelift Sedans used a different taillight:
755.jpgAlbum 7551524.jpgAlbum 1524
Troubleshooting
Inoperative rear taillights, Turn Signal lights, or brake lights? Check for adequate grounding/earthing of the plastic combination lamp assembly.
Bulbs
Main: Bulbs
All 1200s use a 3-section taillight. Japan market and North American market use these bulbs:
* 26717-89900 12V-23W   [Top/Outer bulb]
* 26717-89920 12V-23/8W [Middle bulb]
* 26717-89900 12V-23W   [Bottom/Inner bulb]
Japan-market has an additional small bulb in the middle section:
* 26261-89900 12V-3.4W (Wedge socket)
  used until Aug 1986 in the Truck
Japan small bulb (sedan)
Japan small bulb (coupe)
Sedan
1970 vs Facelift
JDM USA EUR
All trims use the same taillights. STD and GX use the same units
1605.jpgAlbum 1605
#H10 Japan and #H16 North America tail lights have Red blinkers, instead of Yellow/Orange
20733.jpgAlbum 20733
#H19 Australia/Europe lenses have Orange for the blinkers
20738.jpgAlbum 20738
LENS
20734.jpgAlbum 20734
RIM
20743.jpgAlbum 20743
PACKING (rubber seal -- lens-to-body)
20736.jpgAlbum 20736
HOUSING (available as complete Combination Lamp Assembly)
20737.jpgAlbum 20737
PB110
Facelift
20729.jpgAlbum 20729
Clear Sedan
21158.jpgAlbum 21158
Custom Sedan
Coupe On Sedan
H10
H16
Modified for North America lighting standards.
H19
Amber blinkers for EUR and AUS
Coupe
Coupe tail lights have a silver, light gray, or dark gray surround in the chromed rim (all same part number, appears to be production variance).
5618.jpgAlbum 5618 14005.jpgAlbum 14005 511.jpgAlbum 511 1417.jpgAlbum 1417
Mounting
25311.jpgAlbum 25311 25312.jpgAlbum 25312
Amber-Red-White (AUS & EUR)
10207.jpgAlbum 10207 18045.jpgAlbum 18045
Red-Red-White (Japan & USA)
20739.jpgAlbum 20739 20740.jpgAlbum 20740
3-bulb Type vs 4-bulb Type
20711.jpgAlbum 20711 20742.jpgAlbum 20742
20741.jpgAlbum 20741
USA 3-bulb harness
amber 4-lamp - Australia?
25992.jpgAlbum 25992 25993.jpgAlbum 25993 25994.jpgAlbum 25994
IKI4005R RH SAE
26030.jpgAlbum 26030 26031.jpgAlbum 26031 26032.jpgAlbum 26032
PB110 Coupe
PB110 coupe - similar to B110 Sedan lights, but they protrude out
25854.jpgAlbum 25854
* Japan and North America both use Red lenses (no amber)
* the red lenses differ, presumably in reflective pattern
* the center section has two bulbs (Japan) or one bulb (NA)
  Therefore the assembly housing and Harness differ
All other parts are the same (Bulbs, Rim, Packing, white reverse Lens)
Custom
White-outside rears
1417.jpgAlbum 1417
Supra lights on Coupe:
5606.jpgAlbum 5606 2869.jpgAlbum 2869 24277.jpgAlbum 24277 24278.gifAlbum 24278
Wagon
638.jpgAlbum 638 13022_4e3cb98ba155c.jpgPost 378695 2998.jpgAlbum 2998 5090.jpgAlbum 5090 20195.jpgAlbum 20195
Also fits 620 Pickup
400px-Datsun_620_622.JPGWIKI click for photo
26551-H1401, Koito 220-23461
25527.jpgAlbum 25527 25528.jpgAlbum 25528 26551-H1401_s.jpg 26551-H1401_t.jpg
Housing
LENS style 2
20744.jpgAlbum 20744
Reverse Lens
Repair
5145.jpgAlbum 5145
174_5d8159050dcc3.jpgPost 492625 174_5d8158f8e4031.jpgPost 492625
1000
Template:Album!H 8337.jpg
Pickup
Black-rim OR Silver-rim tail lights
7899.jpgAlbum 7899 5648.jpgAlbum 5648
Datsun 1200 (Pickup) has three-segment rear corner lamps:
20713.jpgAlbum 20713 18255.jpgAlbum 18255
* Top section is for turn signals, 23W single filament bulb
  * Yellow in Japan market
  * Aftermarket clear lenses are available, which use color bulbs
* Middle section is red for brake & running lights, 23W/8W dual filament bulb
* Bottom section is clear for backup lights, 23W single filament bulb
20716.jpgAlbum 20716 20717.jpgAlbum 20717 17268.jpgAlbum 17268
Lenses are held in place by 8 screws
26033.jpgAlbum 26033
The lens frame (Rim) was offered in Silver or Black:
20694.jpgAlbum 20694
1971-1978: were silver/chrome through 1978 March
20693.jpgAlbum 20693
1978-1989: changed to black from 1978 April
20692.jpgAlbum 20692 25639.jpgAlbum 25639
1971-1973 Chrome. Spade connector
1973-1978 Revised tail & stop (middle) lens
1978-8608 Black. Pin connector (JAP) or locking spade (AUS)
8608-2004 3-bulb type (no parking lamp)
Gasket (Packing)
20696.jpgAlbum 20696
Wiring early - Spade connector
20714.jpgAlbum 20714
Wiring late - Pin connector (positive locking)
20695.jpgAlbum 20695
Wiring AUS - 6-Spade connector (positive locking)
25789.jpgAlbum 25789
Spacers on the attachment studs
26034.jpgAlbum 26034
Plugs were used from 1989 October, to cover the hole for the missing small bulb
26035.jpgAlbum 26035
2785.jpgAlbum 2785 2851.jpgAlbum 2851 2852.jpgAlbum 2852 2994.jpgAlbum 2994 5355.jpgAlbum 5355 16760.jpgAlbum 16760 16887.jpgAlbum 16887 17561.jpgAlbum 17561 18255.jpgAlbum 18255
600x450-2015062100362.jpg 600x450-2015062100363.jpg 20150607210843497.jpg 20150607210843566.jpg 20150607210843630.jpg 20150607210843699.jpg 20150607210843769.jpg 20150607210843834.jpg 20150607210843908.jpg 20150607210843975.jpg
Bulbs
* 26717-89900 12V-23W (4) [Top bulb, Bottom bulb]
* 26717-89920 12V-23/8W -8608 (2) [Middle bulb]
* 26261-89900 12V-3.4W (2) [small middle bulb]
WIRING
* 26563-G1000 HARNESS ASSY-REAR COMBINATION -7803 [spade connectors]
* 26563-G1060 HARNESS ASSY-REAR COMBINATION 7804-8608 PIN CONNECTOR [4-bulb type]
* 26563-G1900 HARNESS ASSY-REAR COMBINATION -8608 [3-bulb type]
LAMP ASSY-REAR COMBINATION
G100     -7803 [chrome]
G106 7804-8608 [black, 4-bulb]
G190 8608-     [black, 3-bulb]
Export
JDM vs Export
20707.jpgAlbum 20707 20708.jpgAlbum 20708
Round reflector section varies in size
輸出用 - Export , small reflector
国内 - Domestic, larger reflector
Aftermarket Ute
Semi-Clear
White trim
16820.jpgAlbum 16820
Chrome trim
23471.jpgAlbum 23471 2137.jpgAlbum 2137
Black trim
14390.jpgAlbum 14390 15841.jpgAlbum 15841 17087.jpgAlbum 17087 17088.jpgAlbum 17088
Clear
1783.jpgAlbum 1783 1948.jpgAlbum 1948 1949.jpgAlbum 1949 9306.jpgAlbum 9306 20376.jpgAlbum 20376 20377.jpgAlbum 20377 20381.jpgAlbum 20381 2137.jpgAlbum 2137
Fumiya-brand clears
Custom
14913.jpgAlbum 14913 14933.jpgAlbum 14933 15431.jpgAlbum 15431 19423.jpgAlbum 19423
ストップラ ランプ レンズ ウインカー テールレンズ テール レンズ
Reflectors
In most countries, reflecting surfaces are built-into the rear lamps.
For those countries where they are not, or where a bigger relector is required -- such as Australia and Kenya -- separate rear reflectors were added:
See Main Article: Reflectors#Tailgate
Third Brake Lamp
Center High Mount Stop Lamp (CHMSL) a.k.a. 3rd brake light can be adapted to the 1200, or a "universal" fitted. USA data indicates a long-term enduring crash-reduction benefit of 4.3%.
2554.jpgAlbum 2554
Mandatory for new cars
* United States and Canada since 1986
  light trucks since 1994
* Australia and New Zealand since 1990
* Many European countries since 1998
third brake light
North America Notes
USA regulates the wattage, color and placement of the tail lights. However, USA allowed all-red, the same colors used in the Japan market, so that was also used for 1200 exported to North America. Canada generally adopts the same standards as USA.
Markings
Example. The codes indicate this lens meets both Europe and USA specifications
IKI 4004 R 1 E4 310 R-120 SAE ISTR 69
IKI manufacturer
    4004 model of the lens
E-Mark certification for Europe
R 1 E4 310 R-120
R   rear position (tail) lamp
  1 turn indicator
    E4 certification by Netherlands
SAE Society of Automotive Engineers (now SAE International)
ISTR 69 SAE Identification Codes
I       indicators (turn signal lamps)
 S      stop lamps
  T     tail lamps (running lights)
   R    reverse lamps (backup lights)
     69 year of specification
"The last two numbers of a year which means that the code letters refer to SAE Specifications listed in the SAE Handbook current in the year indicated, or the applicable requirements of Federal Motor Vehicle Safety Standard 108 specified for the device function in the year indicated."
Repair
If the bulb socket tabs are broken in the lamp housing, the bulb socket may keep working its way out.
Normally, the socket goes in and twist-locks to the housing.
If the tabs are broken, sometimes tape will hold them fast to the housing.
Or you can purchase a Datsun universal tail light socket repair kit
Here they are shown installed in all 3 positions of a 1200 sedan tail light
Here they are installed in a 3 positions of a fully assembled 1200 coupe light (no need to disassemble to install)
テールランプ
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Tail_Lights"
This page has been accessed 78,086 times. This page was last modified 22:32, 11 September 2025. Content is available under Datsun 1200 Club.
