Leaf Springs
(Redirected from U-bolts)
Datsun 1200 used the tried and true leaf spring rear suspension, which was common among most cars — including American cars — in the early 1970s. Also known as blade springs or cart springs.
2134.jpgAlbum 2134
55020-H1000 Sedan, Coupe $159 USD
55020-H1400 Van (heavy duty)
55020-G1000 Truck 4-leaf early
55020-G1001 Truck 4-leaf 7510-
55020-G1002 Truck 4-leaf 8504-
55020-G1060 Truck 5-leaf 7804-8503
55020-G1061 Truck 5-leaf 7804-8503 8504-
Ute 4-leaf pack Type 1
leaf-overrider.jpg 21316.jpgAlbum 21316
Ute 4-leaf pack Type 2 (2nd leaf overlaps 1st leaf)
24758.jpgAlbum 24758
Front Shackle, Rear 3-bolt Bracket
174_619c212581f9e.jpgPost 496241
Rear Shackle is same for all 1200s
24931.jpgAlbum 24931
Front 3-point Mount Plate (Sedan, Coupe)
18675.jpgAlbum 18675
Sedan rear shackle pin bracket
18674.jpgAlbum 18674
Details (truck, Pin front mount)
Truck rear shackle pin bracket
12728.jpgAlbum 12728
Truck front leaf pin
12729.jpgAlbum 12729
Custom adjustable shackles
Spring Specifications
All 1200 springs are: 1110 mm long, 50mm wide
Spring Rate
See Spring_Rates#Rear_Spring_Rate
Spring Eye Diameter
* Coupe, Sedan, Van: 35mm front,  23mm rear
Sedan, Coupe
* 3 leaf: 1 x 6mm thick, 2 x 7mm thick
Van
* 4 leaf std: 3 x 6mm thick, 1 x 13mm thick
* 4 leaf H-D: 2 x 6mm thick, 1 x 7mm thick, 1 x 11mm thick
Truck
* 4 leaf: 2 x 6mm thick, 1 x 7mm thick, 1 x 13mm thick
* 5 leaf: 2 x 6mm thick, 1 x 7mm thick, 2 x 10mm thick
Free Camber
* Sedan, Coupe: 109mm +-3
* Van         : 131mm +-5
* Truck       : 118.5 mm
Laden Camber
* Sedan, Coupe: 11mm @ 192kg
* Van: 11mm @ 295kg
* Truck std 4-leaf: 18.5mm @ 267kg
* Truck HD 5-leaf:  15.1mm @ 376kg
Free Camber 'S'
* Truck: 118.5 mm
6317_51354966421f7.jpgPost 431466
Leaf Mounting
See also: Shocks#Mounting
B110 mounts leaf directly to metal (unlike B10 and B210 which use rubber-based isoclamp).
Rear axle mounting
24932.jpgAlbum 24932 3772.jpgAlbum 3772 14584.jpgAlbum 14584
Sedan mounting with Vertical Shock bolted to axle tube bracket (coupe, wagon and truck have diagonally-oriented shock bolted to lower spring seat)
9744.jpgAlbum 9744 28724.jpgAlbum 28724 14584.jpgAlbum 14584
B210 mounting uses an Isoclamp, with a rubber pad between the spring seat and leaf
28722.pngAlbum 28722
Spring Seat
H10 Sedan (plain seat without shock stud)
Spring Seat Assembly
Sedan: 55262-H1001
Truck: 55262-G1000 (RH) 12mm shock Nut wide u-bolt
Van:   55262-H1401 (RH) 12mm shock Nut narrow u-bolt
       55262-H1402 (RH)   (from '73-6)
Coupe: 55262-H1801 (RH)  8mm shock Nut
       55262-H1802 (RH)   (from '73-5)
18451.jpgAlbum 18451
See also: Shock absorbers
G10 B120 Truck large stud for shock + large U-joints
24027.jpgAlbum 24027 27515.jpgAlbum 27515 27516.jpgAlbum 27516
25582.jpgAlbum 25582 25583.jpgAlbum 25583
H18 Coupe small stud for shock
1201.jpgAlbum 1201 174_54d5aa409d1da.jpgPost 463507
Sedan and Coupe parts
18721.jpgAlbum 18721
B210 coupe
2491.jpgAlbum 2491
U-bolts
Ute
6212.jpgAlbum 6212 6211.jpgAlbum 6211 6210.jpgAlbum 6210
U-bolts
55247-H1002 CLIP-rear spring Sedan, Coupe.USA
55240-H1800 Coupe.JPM.early
55247-H1401 CLIP-rear spring Van, Coupe.JDM.late
55247-G1000 CLIP-REAR SPRING Truck 4-leaf
55247-G1060 CLIP-REAR SPRING Truck 5-leaf 7804-
Fasteners for U-bolts (Sedan,Coupe,Van,Truck)
08911-64010 NUT-HEX M10 x 1.25 8
08915-14010 WASHER-spring lock 8
Sedan
Ute U-bolts (same M10 diameter but wider spacing for larger axle tube)
24930.jpgAlbum 24930
Ute U-bolts fit over 62 mm axle housings (62 mm inside diameter)
26351.jpgAlbum 26351
Bound Bumpers
Coupe, Truck & Van rear suspension bumper (above the axle housing)
55240-G1900 ASSY-BUMPER REAR AXLE > 55240-H1800 > 55240-H1400
08911-64010 NUT-HEX M10X1.25
08915-14010 WASHER-SPRING LOCK
6210.jpgAlbum 6210 24926.jpgAlbum 24926
Sedan rear suspension bumper (on the Shocks)
55240-H1001 BOUND BUMPER A
56124-H1001 BOUND-BUMPER B
24801.jpgAlbum 24801
Truck Bound Bumper
174_56c011bf552a9.jpgPost 476312 11171.jpgAlbum 11171
Torque Arrester
The Torque Arrester (pinion snubber) is a rubber bumper that prevents the leafs from rotating too much under torque input.
Bushings
18316.jpgAlbum 18316
5 55044-H1001 front upper Sedan, Coupe
  * superseded by 55044-H5001 $4.90 USD
  24085.jpgAlbum 24085
6 55045-H1000 front lower Sedan, Coupe [leaf eye, course] $3.63 USD
17 55046-H1000 rear upper $2.27 USD
24927.jpgAlbum 24927
18 55047-H1000 rear lower [leaf eye, plain] $1.22 USD
NOTE: B210 USA uses the same bushes as 1200 Coupe/Sedan.
Wagon & Ute
24922.jpgAlbum 24922
V 55045-H1400 front Van, Truck [leaf eye, fine] $4.25 USD
24924.jpgAlbum 24924
20900.jpgAlbum 20900
55044-H5001
20429.jpgAlbum 20429
Ute/Van complete set
24928.jpgAlbum 24928
Make your own
Or, make your own performance bushings per Nissan Competition book:
Aftermarket
Or, get stiff aftermarket bushings:
  • Polyurethane bushings (north america): Parbo
Lowering Springs
See also: Lowering
120Y Springs
120Y B210 leaf spring is 1165mm. It is 55mm longer than 1200 B110 (1110mm) and is not interchangeable.
12482.jpgAlbum 12482
B210 use an Isoclamp system which means the bolts are farther apart, even though the leaves are the same 50 mm width as 1200 leaf springs.
B210 Coupe
2487.jpgAlbum 2487 2488.jpgAlbum 2488
B210 Sedan U-bolts (plate has wider spacing than B110)
18491.jpgAlbum 18491
Isoclamp
B210 use an Isoclamp system, similar to that used by B10.
Bolt holes 3 inches
174_565973852692c.jpgUpload click to view
Datsun 1000 clamp
19924.jpgAlbum 19924
Alternative Leaf Springs
Composite Leafs - See Suspension_upgrades#Smooth_ride
Adjustable
Unknown adjustable suspension. Does it work well?
11450.jpgAlbum 11450
Improving
New leaf springs work very well, but worn leafs don't slide too well.
リーフ スプリング シャックル ブッシュ
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Leaf_Springs"
This page has been accessed 112,161 times. This page was last modified 21:39, 6 June 2025. Content is available under Datsun 1200 Club.
