There is no page titled ":Delete". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Radio Delete Plate (1275 bytes)
1: ...ted with a mask plate (commonly called a '''radio delete plate''').
27: You might be able to use a Datsun [[620]] Truck delete plate. It looks to be exact same shape and size.
32: = Custom Delete Plate =
Page text matches
- Radio (17232 bytes)
59: = Radio Delete Plate =
61: {{Main|Radio Delete Plate}}
273: *: {{AlbumLinkH|Radio_Delete_Plate|7292|mask}} - Bar Cluster Gauge (2347 bytes)
13: [[Clock]] or [[Clock#Mask]] (clock delete plate)
15: [[Radio]] (shaft-style) or [[Radio#Delete Plate]] - Grille (9229 bytes)
237: Grille with fog lamps/delete plates unbolted
242: Masks ([[PB110_lights#Fog_Lights|foglamp]] delete plates) comes with the DX/GL grille - Radiator (14153 bytes)
199: B110 hose for heater-delete model - B20 (4304 bytes)
131: <!-- Editors: please don't delete photos here unless they are not of B20. Duplicate... - VB10 (3365 bytes)
68: <!-- editors: please don't delete a pic from this section unless it is not of a VB1... - Glass (11375 bytes)
52: == Wing Delete ==
58: ...861C3EA-4103-000003BDE7D3A1BA.jpg|}}<blockquote>I deleted the triangle front window had custom glass made ... - Editing (1109 bytes)
14: * If it is a typo/mispelling, delete that and type corrected information - Clock (7891 bytes)
157: 25005-H1800 MASK-tachometer ['Sunny' for clock delete]
175: ...25012-H3100 COVER ASS'Y-front ['Datsun' for clock delete]
190: 25005-H1810 MASK-TACHOMETER "DATSUN" [delete plate for dash]
213: H18 MASK-TACHOMETER "DATSUN" [delete plate for dash] - Dashboard (9581 bytes)
154: * "NISSAN" clock delete plate - A12GX Part Numbers (8108 bytes)
49: ** DELETE FROM GX: 13219-H1000 SHROUD-inner valve (from '73...
165: ** DELETE (?) 22301-H1000 CONTROL ASS'Y-vacuum (except GX-H... - Trim (9154 bytes)
46: * Cigarette Lighter delete (plug for dash, no lighter)
47: * Radio delete (Blank Plate)
48: * Antenna delete (a-pillar plugs)
49: * Heater delete (Firewall and cylinder head plugs, different lowe... - Water pump (9463 bytes)
230: Water Pump delete cover plate - EGR (13656 bytes)
86: ...e switches are to limit when the EGR works. Don't delete or bypass them otherwise your EGR will work full-... - Cigarette Lighter (3343 bytes)
22: Blocking plate for delete option - KA Engine Swap (19647 bytes)
440: ...ght=power+steering+delete ka-t.org power steering delete] - Terms of Use (10193 bytes)
16: ... or discontinue this web site and its services or delete the data you provide, whether temporarily or perm...
36: ...ed, infected with a virus or other destructive or deleterious programming routine, give rise to civil or c... - Silvia-specr's B10 (4584 bytes)
64: Radio delete plate - B210 Grille (13595 bytes)
126: 5 62310-H5500 MASK-fog lamp A [delete plate] 2 K-DX
127: 62310-H5600 MASK-fog lamp C [delete plate] 2 K-GL
256: fog lamp delete plate - Competition Distributor (2549 bytes)
3: = Vacuum Advance Delete =
