Search results
For query "Dimmer"
There is no page titled ":Dimmer". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below 19 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
  1. Lamp Wiring (8404 bytes)
    61: Near the stalk are the three red Dimmer wires for the [[Head Lights]] system. Opposite ar...
    78: ...on|Fig. BE-28 Circuit diagram for turn signal and dimmer switch system}}
    125: == Dimmer Switch==
    126: '''Dimmer Switch''' (in T/S & Light Switch unit on steering...
  2. Headlight Wiring (9056 bytes)
    1: ...mn. From here -- depending on the position of the Dimmer lever position -- it goes to either the low (DIM...
    15: * Dimmer Switch (T/S & Light Switch on steering column)
    32: ...terminal of Dimmer Switch</td><td>only powered if Dimmer lever is forward</td></tr>
    33: ...terminal of Dimmer switch</td><td>only powered if Dimmer lever is back</td></tr></table>
    74: * To RY wire of Dimmer Switch</td></tr>
  3. Wiring Diagram (7077 bytes)
    16: * Headlight switch for Australia has two-position dimmer and positions act differently
    117: * Dimmer dash illumination switch
  4. Raw List 2 (24619 bytes)
    358: 25540-H1100 COMP-SWITCH TURN SIGNAL & DIMMER WITH
    359: 25540-H1006 COMP-SWITCH TURN SIGNAL & DIMMER
    360: 25540-H1007 COMP-SWITCH TURN SIGNAL & DIMMER
  5. Sunny Truck Options (2293 bytes)
    29: 25540-H1100 Switch Comp-turn signal & dimmer with passing (from '71-4)
  6. Instrument Panel Wiring (17617 bytes)
    318: ... or BEAM light goes on when headlights are on and Dimmer Switch is flipped forward.
  7. Switch Part Numbers (5458 bytes)
    87: 17 25540-H1100 COMP-SWITCH TURN SIGNAL & DIMMER WITH OP
    88: 17 25540-H1006 COMP-SWITCH TURN SIGNAL & DIMMER -1272 2
    89: 17 25540-H1007 COMP-SWITCH TURN SIGNAL & DIMMER 0173- 2 25540-H1006
  8. Turn Signal Testing (7003 bytes)
    118: ...heck for 12V at the Hazard switch. For 12V at the Dimmer/TS switch. At the headlight switch. At the Flashe...
  9. Lighting Switch (2655 bytes)
    10: Japan - in middle position, Dimmer switch turns headlights on/off
  10. Bulbs (26487 bytes)
    148: ...LED version can be so much brighter, consider a [[dimmer]].
  11. 620 Headlight Wiring (5498 bytes)
    10: ...to the 3rd position. From there power goes to the Dimmer Switch on the steering column. Depending on the l...
    23: ...ed. Power OUT is sent to the relay instead of the Dimmer Switch.
    25: ... is much simpler. Power is not routed through the Dimmer Switch. When in High Beam position, it grounds th...
    99: E coil RY dimmer switch ground
  12. 510 Headlight Wiring (4065 bytes)
    24: Relay Coil is switched by BR wire from Dimmer Switch
    28: Dimmer Switch
    91: E coil BR dimmer switch ground
  13. Speedometer Calibration (6547 bytes)
    71: # 500W dimmer switch to vary constant drill speed
    72: # 60W light bulb (dimmer requires this)
    78: ...M. The speedometer is 50mph=1024 rpm, so turn the Dimmer down about 1/3 from full to start.
    80: ...lly to run drill at constant speed. Then vary the dimmer switch to show 60mph.
  14. Instruction Manual (20633 bytes)
    314: page 8 Light Switch, Dimmer Switch
  15. Turn signal switch (3358 bytes)
    1: ... system. It is column-mounted, a combination with dimmer/turn signal stalk and horn button contact.
    20: SWITCH COMP-turn signal & dimmer
    27: 25540-H1100 SWITCH COMP-turn signal & dimmer
    47: ...cted. It has a 2nd square 4-pin connector for the dimmer wires, which on the 1200 are in the large connect...
  16. They're really something (9029 bytes)
    73: signal and dimmer switch, 4-way flasher
  17. 1973 USA Service Manual (7868 bytes)
    153: BE-10 #TURN SIGNAL AND DIMMER COMBINATION SWITCH
    164: === TURN SIGNAL AND DIMMER COMBINATION SWITCH ===
    171: ...|Fig. BE-28]] Circuit diagram for turn signal and dimmer switch system
  18. LED (7490 bytes)
    113: ...ontrol]] option. Some LED bulbs don't work with a dimmer but others do.
  19. DATSUN 210 (13186 bytes)
    84: ...assist grip, courtesy lights and instrument panel dimmer switch. Behind it all lies Nissan's single-minded...
Search in namespaces :
List redirects   Search for
