Search results
For query "General"
There is no page titled ":General". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. General Lee (2342 bytes)
    1: ...ting your car like {{wikiEx|General_Lee_(car)|The General Lee}} is popular. Little 1200 coupes look especia...
    6: The General paint scheme originated from the television serie...
    8: General's [[B310]] General Lee
    11: K-DOGG's General Lee
    16: ...al-Lee-6.jpg|Datsun%201200/wiki}} {{Photo|1976_GX_General-Lee-8.jpg|Datsun%201200/wiki}}
  2. General specifications (2009 bytes)
    1: General specifications for Datsun 1200 are listed here.
    5: {{OwnersManual2x|29399|p1=39|29400|p2=40|General Specifications}}
Page text matches
  1. FAQ (6725 bytes)
    86: Generally you won't change these, instead add your inform...
    151: [[Category:General Information]]
  2. Datsun 1200 encyclopedia (3415 bytes)
    14: * [[:Category:General Information|General Information]]
    66: [[Category:General Information]]{{End}
  3. History of Datsun 1200 (16941 bytes)
    35: ...s Sunny sold more, other years Corolla. Sunny was generally always a bit lighter, but Corolla had more engi...
    75: ... car. The name "Sunny" was actually chosen by the general public after Nissan ran newspaper ads inviting pe...
    192: [[Category:Datsun Sunny RWD]][[Category:General Information]][[Category:Documentation]]{{End}}
  4. Racing History (26063 bytes)
    44: ...#24029;亜美 Ami Tamagawa No. 21 General sprinter
  5. Engine Swaps (25981 bytes)
    16: ...$2500-$4000 USD building up the A12. Also it will generally mean time that the car is not driveable, while ...
    82: ... I'll trade a 1% peak power disadvantage for a 7% general power advantage any day of the week.
    260: {{wikiEx|General_Motors_90°_V6_engine|Chevrolet 4.3 V6}}
    263: {{wikiEx|General_Motors_60°_V6_engine|Chevrolet 2.8}} in [[B210]]...
    266: {{wikiEx|General_Motors_60°_V6_engine#3.1_L/3100|GM 3100 Engine}}...
  6. Rear Axle Swaps (24650 bytes)
    40: In general, determine how much torque you new engine will ou...
    90: ...110/B120 H145 rear-axle assemblies (housing, etc) generally interchange but may be small difference in the ...
    324: ...Hiace}} vans used beefy rear axles assemblies. In general, Hiace rear axles are wider than Hilux. They use ...
    437: In general, all B110, B210 and B310 driveshafts are the same...
  7. Performance (21399 bytes)
    264: = General Information =
    328: ...de-rated about 5 HP (e.g. Honda) while Fords were generally unchanged and a few even were uprated a touch.
    330: This means you can generally have good faith in new-car manufacturer's power...
    355: [[Category:General Information]]
  8. Ignition Timing (9164 bytes)
    1: ...k timing) is the foundation of any tune-up. It is generally the first step you need to perform as all other...
    13: = General Procedure =
    137: General process to find optimal timing after the timing h...
  9. Emission Controls (28459 bytes)
    24: ...rich at full-throttle (even new cars) since it is generally not a strict part of emission test procedures.
    150: For reduction in unburned HC, generally the spark timing is reduced from optimal-power ...
    280: ...lean in part-throttle use to reduce emissions. In general, Datsun 1200 carbs are richer than newer Datsun c...
  10. Parts Sources (15979 bytes)
    82: == General Tune-up Parts ==
    158: I generally email/talk with Karin Britts. I send the parts ...
    288: [[Category:General Information]]
  11. Radio (17232 bytes)
    52: GENERAL DIRECTIONS
  12. Yahoo Auctions Japan (4625 bytes)
    67: [[Category:General Information]]
  13. Fuel Injection (19606 bytes)
    52: ...due to the precision required of the parts, it is generally just as expensive as EFI.
    77: ...ier to work on than an emissions-controlled carb, generally speaking from 1st hand experience. I've rebuilt...
    117: Generally, the kit won't include a hi-pressure fuel pump ...
    306: ...ECU, or aftermarket ones, including MegaSuirt and General Motors.
    362: EFI generally needs a high-pressure (~40 psi) fuel supply.
  14. Choosing A Carburetor (14914 bytes)
    79: ...e engine ports is a straighter line. But they are generally more expensive and require a special intake man...
    111: <li>Angled runner design is generally a plus, although the a-series heads don't have ...
    268: For a general tuning guide to Webers, see:
  15. Ignition Switch (12669 bytes)
    164: * General Motors 19021152
  16. Changing Head Gasket (9192 bytes)
    26: * Generally, for any engine, tighten the middle bolts first...
    97: In general, to avoid a "blown" head gasket:
  17. 200SX EFI (13119 bytes)
    78: * Pressure Regulator - generally included with used Manifold
    88: * Air regulator - generally included with used Manifold
    90: * Throttle chamber - generally included with used Manifold
    95: * I.A.S. unit - generally included with used Manifold
    169: = General Description =
  18. Datsun B10 (14041 bytes)
    30: ... car. The name "Sunny" was actually chosen by the general public after Nissan ran newspaper ads inviting pe...
  19. 63-Series Transmission (11903 bytes)
    6: For an overview of 5-speeds in general, see:
  20. Engine (2481 bytes)
    1: ...ngine, as are most articles in this wiki. For the general article, see [[Nissan A Engine]] -->
Search in namespaces :
List redirects   Search for
