Search results
For query "Log/delete"
There is no page titled ":Log/delete". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Radio Delete Plate (1289 bytes)
    1: ...ted with a mask plate (commonly called a '''radio delete plate''').
    31: You might be able to use a Datsun [[620]] Truck delete plate. It looks to be exact same shape and size.
    36: = Custom Delete Plate =
Page text matches
  1. Radio (17232 bytes)
    59: = Radio Delete Plate =
    61: {{Main|Radio Delete Plate}}
    93: ...ILIPS 5.5 70 90 120 160 AM' where D is the Datsun logo (Australia)
    215: B120 Options catalog C-288 1974
    273: *: {{AlbumLinkH|Radio_Delete_Plate|7292|mask}}
  2. Bar Cluster Gauge (2347 bytes)
    13: [[Clock]] or [[Clock#Mask]] (clock delete plate)
    15: [[Radio]] (shaft-style) or [[Radio#Delete Plate]]
    65: ...2479;ー  angle meter (per Datsun catalog)
  3. Grille (9229 bytes)
    237: Grille with fog lamps/delete plates unbolted
    242: Masks ([[PB110_lights#Fog_Lights|foglamp]] delete plates) comes with the DX/GL grille
  4. Radiator (14556 bytes)
    154: [http://www.rockauto.com/catalog/catalog.php?carcode=1208483&pgname=Cooling+System http://...
    214: B110 hose for heater-delete model
    230: ...0070S. About $8 each [http://www.rockauto.com/catalog/x,carcode,1208483,pgname,Cooling%2BSystem RockAut...
    242: ...AC DELCO 20067S, [https://www.rockauto.com/en/catalog/nissan,1972,1200,1.2l+l4,1208483,cooling+system,r...
    323: From [[1984 Nissan Competition Catalog]]
  5. B20 (4330 bytes)
    133: <!-- Editors: please don't delete photos here unless they are not of B20. Duplicate...
  6. VB10 (3391 bytes)
    70: <!-- editors: please don't delete a pic from this section unless it is not of a VB1...
  7. Glass (11593 bytes)
    52: == Wing Delete ==
    58: ...861C3EA-4103-000003BDE7D3A1BA.jpg|}}<blockquote>I deleted the triangle front window had custom glass made ...
  8. Editing (1109 bytes)
    14: * If it is a typo/mispelling, delete that and type corrected information
  9. Clock (8107 bytes)
    159: 25005-H1800 MASK-tachometer ['Sunny' for clock delete]
    177: ...25012-H3100 COVER ASS'Y-front ['Datsun' for clock delete]
    192: 25005-H1810 MASK-TACHOMETER "DATSUN" [delete plate for dash]
    216: H1810 MASK-TACHOMETER "DATSUN" [delete plate for dash]
  10. Dashboard (9966 bytes)
    5: = Terminology =
    6: In Nissan official terminology, the "dash" is the cowl & firewall. But in commo...
    159: * "NISSAN" clock delete plate
    222: * with glass & plug (per 1974 catalog)
    223: * Sedan DX, Van Super-DX 4-speed (per 1971 catalog)
  11. A12GX Part Numbers (8108 bytes)
    49: ** DELETE FROM GX: 13219-H1000 SHROUD-inner valve (from '73...
    61: ... is in the Cherry catalog, not listed in 1200 catalog]
    78: * 1974 Nissan Cherry catalog lists 14003-H5731 for A12T engine
    84: Source: [[1984 Nissan Competition Catalog]]
    165: ** DELETE (?) 22301-H1000 CONTROL ASS'Y-vacuum (except GX-H...
  12. Trim (9361 bytes)
    46: * Cigarette Lighter delete (plug for dash, no lighter)
    47: * Radio delete (Blank Plate)
    48: * Antenna delete (a-pillar plugs)
    49: * Heater delete (Firewall and cylinder head plugs, different lowe...
  13. Water pump (9747 bytes)
    108: [http://www.rockauto.com/catalog/catalog.php?carcode=1208483&pgname=Cooling+System http://...
    232: Water Pump delete cover plate
  14. EGR (13656 bytes)
    4: EGR is a key emission control technology. Even the new 2012 cars use EGR, although now it...
    86: ...e switches are to limit when the EGR works. Don't delete or bypass them otherwise your EGR will work full-...
    131: * (22110-N3600 shown in catalog, perhaps a typo)
  15. Cigarette Lighter (3343 bytes)
    22: Blocking plate for delete option
  16. KA Engine Swap (19647 bytes)
    103: SOHC 12-valve [http://www.rockauto.com/catalog/x,carcode,1208922,parttype,5412 Rockauto]
    124: [http://www.rockauto.com/catalog/x,carcode,1208988,parttype,5412 Rockauto]
    129: [http://www.rockauto.com/catalog/x,carcode,1316773,parttype,5412 Rockauto]
    137: [http://www.rockauto.com/catalog/x,carcode,1356757,parttype,5412 Rockauto]
    249: ...Gasket (early 240SX) [http://www.rockauto.com/catalog/x,carcode,1208922,parttype,5436 Rockauto.com]
  17. Terms of Use (10193 bytes)
    16: ... or discontinue this web site and its services or delete the data you provide, whether temporarily or perm...
    28: ...onsible for all uses via your registration and/or login, whether authorized or unauthorized by you. You...
    36: ...ed, infected with a virus or other destructive or deleterious programming routine, give rise to civil or c...
    45: ...will apply with respect to any form, media, technology known or later developed;
  18. Silvia-specr's B10 (4584 bytes)
    64: Radio delete plate
  19. B210 Grille (13595 bytes)
    120: RADIATOR GRILLE (B210 Japan catalog)
    126: 5 62310-H5500 MASK-fog lamp A [delete plate] 2 K-DX
    127: 62310-H5600 MASK-fog lamp C [delete plate] 2 K-GL
    256: fog lamp delete plate
    284: ...6878d3.jpg|brochure|height-179|was=Photo|GB211catalog_.jpg\Datsun%20Misc/B210/PB210}}
  20. Competition Distributor (2549 bytes)
    3: = Vacuum Advance Delete =
    17: = 1984 Catalog =
Search in namespaces :
List redirects   Search for
