There is no page titled ":Quality". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- It runs on quality (1909 bytes)
5: {{BrochureInfo|It runs on quality|red coupe|1978|B210 Coupe|KB210|full page|magazin...
9: ...ont-size:x-large'>48 HIGHWAY, 36 CITY. IT RUNS ON QUALITY.</span>
21: B-210 GX. Quality like this is no accident. It took Datsun ingenuit...
Page text matches
- Strut Insert Part Numbers (10856 bytes)
18: Using a factory-quality Strut rebuild kit (rather than removing the facto... - Parts Sources (15979 bytes)
98: You know the quality is right, because [[History of Datsun 1200|Nissan... - Choosing A Carburetor (15198 bytes)
229: Aftermarket manifold finish quality can be really poor so check for flat flanges, por... - Changing Head Gasket (9192 bytes)
86: If your engine did blow the head gasket, use a quality straight edge and a feeler gauge to measure head ...
88: ... a blown gasket, but you want to be sure. Place a quality straightedge across the head surface and use a fe... - Aftermarket intake manifold (6273 bytes)
4: * Aftermarket manifold finish quality can be really poor so check for flat flanges, por... - Malaysia (1316 bytes)
1: ...riving market for Nissan replica parts of varying quality, like Datsun 1200 badges and seals, which can be ... - Badges (7769 bytes)
1: ...ery good. Aftermarket reproduction badges vary in quality from poor to very good.
257: Be careful of the quality:
259: ...s. However, other reproduction badges may be high quality. - Camshaft replacement (8570 bytes)
56: #* Cam lube can be anything from a good quality engine oil to special moly cam lube. The idea is ... - Fuel Requirements (12778 bytes)
25: ...lthough not designed for unleaded, were of a high quality.
31: ...mproves the {{wikiEx|Engine knocking|anti-knock}} quality of gasoline - Repair Manual (20287 bytes)
49: ...issan photos, or just drawings, sometimes of poor quality. - Anti-diesel valve (4205 bytes)
41: ... the curb idle is set a little too high or if low-quality petrol is used. If the engine wants to "run on" a... - Tools (9147 bytes)
31: Shadetree mechanics will want a quality set of "guaranteed" tools at a budget price.
32: ...acto standard for this application. They are good quality. Yes, they will occasionally break, but the guara...
49: Quality vs Budget tip:
50: * Get an expensive ratchet and a budget-quality set of sockets
118: ... short of measuring internal engine clearances. A quality plastic one is inexpensive yet with high accuracy... - Oil Pump Coolers (4882 bytes)
6: ...ither will the oil. At this temperature, the good quality regular oil (inexpensive) will perform as good as... - Oil pump (3453 bytes)
14: At this temperature, the good quality regular oil (inexpensive) will perform as good as... - Wipers (8777 bytes)
151: ...oney. Because the original Datsun 1200 blades are quality stainless steel, they still look good and operate... - Suspension upgrades (19397 bytes)
16: '''Handling''' is the quality of the car during dynamic changes: how it reacts ...
24: ...ult to improve handling without reducing the ride quality. For a circa 1970 automobile, the 1200 has very g...
45: ...topic.php?topic_id=11555&forum=1 Leaf spring ride quality]).
47: ...h large sedans that start with a 'wallowing' ride quality. Since the 1200 already has a firm suspension the...
49: ...ory B210 shocks also fit and have similar damping quality. Aftermarket struts inserts and rear shocks are g... - Options (10139 bytes)
288: ...akes the car look lower and longer. Stripe is top quality "Scotchcal" vinyl. Each letter is formed with ind...
289: ... stripe. 25 ft. of striping provided, all in high quality "Scotchcal" vinyl. Available in black or white. - Rubber parts (4528 bytes)
118: * eBay (quality from great to poor, check the ratings) - Aftermarket (1669 bytes)
3: ...essarily true, but general they are of acceptable quality. - Piston (17564 bytes)
98: = High Quality Cast Pistons =
