There is no page titled ":Log/move". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- History of Datsun 1200 (17010 bytes)
178: ...te in 1984. There is some evidence this was a bad move ... Nissan have never recovered their status of #... - Weber 32/36 Carburetor (22361 bytes)
90: ...y 5200, fitted to the 2-liter German Ford OHC ("Cologne") engine in the 1971 {{wiki|Ford Pinto}}.
158: ...Mixture screw restrictor cap''' (idle limiter). Remove this unless local laws require them
226: ...move the shaft side-to-side. It should not. If it moves even a little bit, pass on it. It will require d...
256: Remove the existing lever, and bolt the lever off the or... - Choosing A Carburetor (18692 bytes)
150: ... fuel metering is achieved with tapered rods that move with the venturi, allowing more or less air to fl... - Lamp Wiring (8404 bytes)
79: ...nter position of course the power stops here. But move the switch to right or left, and the power is fed... - B-210 Electronic Distributor Swap (12611 bytes)
24: # Set the engine to TDC, remove old distributor and insert new distributor, in co...
30: When you remove the cap, you can see the unique angle-pickup and ...
74: ...read a about 750 ohms resistance. And using an analog voltmeter, should waver while cranking.
79: 2. Remove old distributor, Insert new distributor. And of c...
94: * Remove the standard low-energy (points) coil, then bolt ... - 63-Series Transmission (11885 bytes)
155: [http://www.rockauto.com/catalog/x,carcode,1210813,pgname,Transmission-Manual Rock...
190: ...arbox Mount]] and make an adapter plate that will move the mounts to the right spot. Some say you can si...
196: OR, remove the factory mounting bosses from the tunnel, and ...
198: ...factory crossmember mounting brackets have been removed from inside the tunnel. This custom crossmember ... - 60-Series Transmission (15437 bytes)
107: ...unnel brackets can be [[#Crossmember_Modification|moved back]]
169: <br>{{ExtPhoto|http://www.risebike.com/pro/GAZO_LOGO/e_shop/parts/shassis/|missyon2.jpg}} {{ExtPhoto!...
212: ... the original 1200 gearbox body brackets can be removed, providing enough space for the reverse lamp swi...
233: Remove the 1200 original crossmember tunnel brackets and...
241: Remove the 1200 original crossmember bosses and move them back - Wheels (17134 bytes)
52: [[Sports Options Catalog]] | [[Sports Options Parts]]
116: ...e top of the strut inwards will do that, but also move the centre of tyre contact patch outwards to a le... - Datsun (2834 bytes)
6: ...te in 1984. There is some evidence this was a bad move ... - RWD (2317 bytes)
18: ...), and may others. Only Chevrolet hasn't made the move yet... although their highest-performance car has... - Sunny (2601 bytes)
13: ...ized, usually not appearing in advertisments. Catalogs etc. do say "ダットサ...
26: = The Move to FWD = - Tune-up (10772 bytes)
49: ..., throttle opener, etc. Generally, pull hose off, move vacuum motor with finger or screwdrive, then put ...
51: ...d. Clean valve with carb cleaner, make sure valve moves freely - Canby 2005 (5865 bytes)
3: ...eet, when the Blue Lake meet split and Datsuns NW moved it to June. 2005 was the first time the meet was...
36: <br>We decided to move the event to the fairgrounds in Canby because, in... - Engine buildup (10548 bytes)
80: Gain: noise and fury, plus movement
92: ...s regular A12, same size 1.5" exhaust. No need to move to larger exhaust, though at this level it will h...
152: {{See|Performance}}{{See|1/4_mile_time_log}}
154: [[1/4_mile_time_log#ddgonzal|42 RWHP]]/69 engine HP
157: [[1/4_mile_time_log#datsa73|75 RWHP]] - Remote Clutch Master Cylinder (3087 bytes)
13: Not enough room after a big [[Engine Swap]]? Move the clutch master under the dash!
17: ...58 PIGDOG] used a [http://www.rockauto.com/en/catalog/toyota,1975,celica,2.2l+l4,1273744,transmission-m...
57: Similar to [http://www.rockauto.com/en/catalog/nissan,2002,sentra,1.8l+l4,1429523,transmission-m... - Steering Gearbox Adjustment (3679 bytes)
16: ...ncy to not move straight ahead but to have little movements left and right seemingly at random. Adjustin...
24: # watch to see if any of the rods move independent of each other. If they do, the rod en...
25: # the [[Steering Arm]], and thus tires, should move with the Tie Rods
26: # the [[Idler Arm]] should NOT move up and down
39: ... be no play; they are supposed to rotate, but not move end-to-end or side-to-side. - Steering Linkage (11804 bytes)
3: = Terminology =
27: # watch to see if any of the rods move independent of each other. If they do, the rod en...
28: ...us tires, should move with the tie-rods. If a rod moves, but not the tyres, the linkage is worn at that ...
29: # the idler arm should NOT move up and down, only rotate. Replace Idler Arm bushi...
33: ... be no play; they are supposed to rotate, but not move end-to-end. - Steering System (2901 bytes)
1: ...l recirculating-ball Steering Gearbox with parallelogram behind-the axle [[Steering Linkage]]. USA mode...
18: ...go bad. It causes a squeak, squeak sound when you move teh steering wheel slightly. - Universal Joint (5176 bytes)
45: ...273} $16.16 USD from [http://www.rockauto.com/catalog/x,carcode,1208483,parttype,2392 RockAuto.com]
97: Remove the [[Propeller Shaft]] from the diff (you can le...
98: <br>* Move smoothly (not stiff), in all directions - Transmission Overview (6766 bytes)
31: ... main gears just spin freely. When the shifter is moved, it pushes one of the synchro collars against a ...
