(1) 2 3 »
Turbo setup
Quite a regular
From Western Sydney
Hey all,
im slowly collecting the bits and pieces needed to chuck a turbo on the oldgirl.
1973 1200 sedan, brought the car from its seconds owner i believe, the dash says 89xxx miles but who knows, stock a12, electronic dizzy and headders back 2' exhaust, (yet to put the stainless extractors sitting in the garage on...) planning on going blowthrough.
ive got a turbo and am about to rebuild it, so now im looking into carburetors and FPR's, through my digging through the site ive decided to lean towards a boost preped 350holley.
now my questions are, for a fuel pressure reg, im looking at one of these.
( http://m.summitracing.com/parts/aei-13301 ) or ( http://m.summitracing.com/parts/msd-29388 )
and as for the holley 350, from what i have been able to gather through the search function, it needs to be boost preped, being new solid float, upgraded needle and seat, new jets and gaskets?
anyone with past experience able to shed some info or guidance as to anything ive missed or maybe want to look into?
cheers
Posted on: 2016/2/9 5:02
1973 Datsun 1200 Sedan (work in progress)
FanaticsCo'*<~~~~
Re: Turbo setup
rising rate Malpassi regulator BO18058 Carb Turbo
$112 AUD
Posted on: 2016/2/9 22:44
Re: Turbo setup
From gold coast QLD.
I also have some unused stuff you may be interested in as a result of changing at the 11th. hour from carby to injection
Posted on: 2016/2/10 7:11
Re: Turbo setup
From Brisbane, Australia
The Malpassi unit worked for me.
The Big drama I had was air/fuel mix getting blown out of the throttle shaft bushes. Make sure the shaft bushes are in good condition or new.
Posted on: 2016/2/11 22:15
Re: Turbo setup
From Melbourne, Australia
i say go straight for injection, you will get frustrated with carby and end up there anyway
happened to me, and many others that setup carby turbos
Posted on: 2016/2/11 22:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Turbo setup
From Sydney
Iv got a 2nd hand malpasi rising rate reg if you are interested.
Posted on: 2016/2/23 8:42
Re: Turbo setup
Quite a few people have got good reliable setups using drawthrough but using an SU rather than 32/36 webers.
Topgear, L18_B110 and a few L series on Ozdat as well not to mention Holden 186, 202s and Valiant guys running a set of 2 inch SUs. Some peeps still run it on IP racing, hillclimbs and other sporting events.
If you have good money go injection for sure its better but unless you put aside over a grand or 2 to set it up, an SU does the job and keeps it all simple.
take your pic
https://duckduckgo.com/?q=turbo+drawth ... U&t=opera&iax=1&ia=images
Posted on: 2016/2/23 13:23
Re: Turbo setup
Quite a regular
From Western Sydney
has anyone tried running a holley 350 without a turbo? looking at chucking one on before i finish all the turbo stuff , just not sure how its gonna go...
Posted on: 2016/6/5 6:55
FanaticsCo'*<~~~~
Re: Turbo setup
From Geelong, Vic
Looks at Sikyne's $1500 DIY injection setup. Will be cheaper in the long run and much more potential. I have seen the dead stock a12 that he ran that injection setup and some boost and made over 100kw
When options like that are possible it seems pointless to go down the carby route.
Posted on: 2016/6/6 8:27
Re: Turbo setup
From Christchurch NZ
You'll also want to externally reference the powervalve on your holley too.
Steveo used to run a blowthrough Holley on his A15 too.
Posted on: 2016/6/6 10:26
Forced Induction!
(1) 2 3 »
