Browsing this Thread:   5 Anonymous Users
What is the item in this picture of the back of my dash
From Flinders View, QLD
Hay all, a while back I posted a thread telling how my temp and fuel gauge where playing up. When ignition was turned on the needles would move a little then go back to nothing. In the picture below is the box on the back of the speedo with 3 wires - red, green and black the voltage regulator. And would this be the cause of my GREMLINS. If so can I source a new one or if there an aftermarket replacement.
AND DOES SOMEONE HAVE A WIRING DIAGRAM FOR THE BACK OF THE DASH SO I KNOW THAT AND WHERE EACH WIRE GOES. Thanks for the help
Posted on: 2007/2/15 9:47
Just trying to put the bloody puzzel back together
Re: What is the item in this picture of the back of my dash
From Christchurch NZ
Is that a voltage stabiliser? I've seen three wires under the dash of my 1200, which don't have anywhere to go.
Posted on: 2007/2/16 4:20
Forced Induction!
never seen one of these on any of the datsuns i have owned or pulled a part...
Posted on: 2007/2/16 4:24
From Cape Town ZA
Could it possibly be a very primitive speed control device, seeing as it's mounted around the speedo cable input?
Posted on: 2007/2/16 5:18
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From Castro Valley,CA USA
Isn't that a speed sensor. On my 73 MT it had that for emissions. In TOP gear going more than whatever MPH the distributor would be allowed to advance.
Posted on: 2007/2/16 10:29
From Burbank, CA
does your car act up at a particular road speed, not rpm?
i had a problem with one of the other systems that happened around 35-40mph, only there and ran fine otherwise.
but since it is on the speedo cable, i'd imagine it's a little generator that makes enough power to activate a solenoid as a particular speed.
Posted on: 2007/2/16 14:51
|||\ 81 KPB310 /|||
surely DD will know what it is for sure.
Posted on: 2007/2/16 16:33
Forced Induction!
From Sydney, Australia
damn, we all learn something every day.
Certainly looks like a speed sensor...
It would make good sense that this might be fitted to a auto or 4 speed model, that doesn't have the overdrive switch for changing igniton advance.
I have seen the back of maybe 15 dashes in my time and never seen this either.
Must be a bakkie or very late model 1200 Ute thing.
Posted on: 2007/2/16 20:45
From Brisbane
it is for the clock
Posted on: 2007/2/16 21:47
From Burbank, CA
oh it's just bolded to the same post as the speedo cable...
Posted on: 2007/2/16 23:45
|||\ 81 KPB310 /|||
