« 1 2 (3)
Re: Diff problems
From Perth WA
Yeh im pretty sure H190s axles are beefyer. I know H145(1000) and H165 axles are the same.
Also lockers #### out you susp dont they? And ive head them also twisting bodys etc I was keen on doing it on the 1000 but im going H165 LSD insted
Posted on: 2007/4/24 10:03
Chris...
Re: Diff problems
From Mudgee NSW Australia
H190's have a few diff size axles some have the 26 spline 25mm?? 510 or 1600 wagons ect same axles size as h165s. The bigger ones from 620- 720 utes and early navaras and comercial vehicles have the 29spline 30mm axles series 3 bluebird also have the bigger axles.
Lockers are fine in track cars I have had one in mine for years without problem. Not very good in the wet or street use though.
Posted on: 2007/4/24 10:23
If In doubt run more BOOST
Re: Diff problems
From sydney australia
Strange question,but how did you welded the centre? Did you just weld the spider gears together? Or did you fill up the hole with weld, or make blocks to drop into the gears & weld it all in? I ask because years ago, i broke an axle with a welded diff because the end of the axle hit the blocks in the spider gears when i was tapping it in & at the first standing start it shattered both axles. Just wondering if something similar is happening to you, as a 180b diff is a h165 with the same axle sizes as a ute diff, & i've never even come close to blowing up any of the welded diffs i've had.
Posted on: 2007/4/26 5:37
Re: Diff problems
From NSW South Coast
That could be the it. I just weld everything up , spider gears to spider gears and spider gears to the carrier. I think the axles have some end play but I need to check.
Thanks
Posted on: 2007/4/26 5:50
Re: Diff problems
From Toowoomba Q Australia
You seem to know your diff from your daff. Can you tell me what diff is in a 200b? and while we are at it what diff is in a 4speed aussie built stanza (early 80s). Cheers Simon
Posted on: 2007/4/26 5:54
Re: Diff problems
Sorry but I don't know. I would say they are both 3.9 h165s but I'm only guessing
Olboy
Posted on: 2007/4/26 6:09
Re: Diff problems
Is 3.9 the ratio ? As in 3.9 : 1 ?
Posted on: 2007/4/26 6:25
Re: Diff problems
From Geelong, Vic
they both have the small BW diffs
Posted on: 2007/4/26 6:28
Re: Diff problems
The earliest Datsun 200B's in Australia used IRS in Sedans & SSS, & a H165 axle under the Wagon
This lasted for about a year or less untill local assembly kicked in when both Sedans & Wagons used a Borg Warner rear axle assembly. The suspensions differed, but the basic axle was the same & these lasted untill the end of 200B production.
Early Stanza's [A10] used the H165 axle, but this too was eventually changed for the Warner rear to accomodate local content laws.
Posted on: 2007/4/28 5:05
Love your Datsun.
Treat it well.
« 1 2 (3)
