Decomp plate
From Brisbane
Hey guys, just wondering if you run a decomp plate do you have to run a head gasket on both sides of it!?...
I pulled the head off turbo A14 motor with a decomp plate and just one head gasket on the head side. The motor has run succesfully for awhile, I thought you had to run two gaskets.
Cheers
Posted on: 2007/5/15 14:56
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: Decomp plate
From sydney
Got any pics?
Posted on: 2007/5/15 15:15
Re: Decomp plate
Hylomar or similar would have been used to seal the plate to the cast iron block.
Posted on: 2007/5/15 15:17
Re: Decomp plate
From Christchurch NZ
I got told to use copper head gasket cement. I used VHT coppper head gasket cement.
Posted on: 2007/5/15 15:57
Forced Induction!
Re: Decomp plate
From Newscastle, Australia
Jeff Taylor recommends O-ringing the block as well.
Posted on: 2007/5/15 17:12
Dont die wondering.....
Re: Decomp plate
From Brisbane
Yes thats the stuff I ahve used to seal everything I can around manifold etc... Recommended by rallycar.
Heres a pic of the Decomp plate... I was worried it may be a spacer, if they had take loads of the head or the block because it was warped. (unlikey). It is about 1.5mm thick. I have left it out should raise comp slighty maybe to 8.3? was 8.0:1
Posted on: 2007/5/15 17:13
Re: Decomp plate
From Melbourne, Australia
i said "loc-tite copper max"
i pressume the other is a similar product... xcept it doesn't carry my endoresment
what compression are you chasing? 8.1:1? say hello terrible off boost performance, hope it hits boost early
what wrong with 9-9.5? you arnt gonna boost above 10-12psi are you?
i wouldnt bother o-ringing unless chasing high boost either
Posted on: 2007/5/15 17:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Decomp plate
From Brisbane
Yeah, I was thinking 9:1 would be okay until I went and saw a engine builder mate. Saw the book figures on boost Vs Compression. WAs pretty scay how high it spikes on compression just with 10psi on 9:1 compression, BUT its doesnt take in alot of factors with motors its just genarl idea. But if you have run 9:1 and that sort of boost I cant see too many issuses, thats why I wont use the decomp plate and run it at 9:1.
Hey Rally, What is your current setup!?.. You havent been updating much. What is the most reliable setup you have achieved so far?. ( i know you have mentioned tune being the biggest issue)
Posted on: 2007/5/15 19:13
Re: Decomp plate
From Brisbane, Australia
I used these head shims on my turbo setups with no problems. You only use 1 head gasket on top of the shim and use Hylomar sprayon the block and shim as phunk said. If this engine was running well before with the shim, I'd be inclined to use it again to avoid any problems with pinging.
Posted on: 2007/5/16 5:21
Re: Decomp plate
From Brisbane
Yes you make a good point Harry. It is intercooled too So that should help take the risk down. I would like to run it at 9:1. I may give it ago and keep a close eye on it.
Posted on: 2007/5/16 10:29
