« 1 (2) 3 4 5 6 »
Re: New Mad Dat Owners & Website
From Coondle, WA Australia
pity there isnt yet a section for 1000s (hint hint)
good looking site though, hope it all goes well.
Posted on: 2007/6/24 5:08
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Adelaide
so are the prices gonna drop at all :)
:P
Posted on: 2007/6/24 5:14
From Brisbane
Good to hear SSS... then there are other options such as One peice tailshafts, whole diff bolt in packages, complete wiring sets etc etc..... Is your ute gonna be the Maddat sponsor ute now?...could be very nice one to start on. If you need one up here lets talk haha... Could be keen, looking for a upgrade at some stage! ...already got most stuff on the my struts hehe
Posted on: 2007/6/24 6:02
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From perth airport
yea if u sell a lsd diff cut down for a 1200 ute ca18 would be great
Posted on: 2007/6/24 7:06
From perth airport
just on a side note where did you get ur 17inch volt rims from ??
the ones in you profile pic s???
Posted on: 2007/6/24 7:12
From Adelaide
What sort of gear are the 1000 boys/girls wanting. Front disk conversions? Engine conversions?
Posted on: 2007/6/24 8:02
From Townsville, Qld
The castor bars I'm using are the blank hole/ threaded hole ones. Couldn't find the tape measure to see how long they actually are? I should of done that when I swapped the struts a few monts back and I had the two lying around
Posted on: 2007/6/24 8:42
engine conversion kits would be nice, but since the swap options are limited, im not sure what you could in fact offer.
cut down diff housings perhaps
modified radiators
gearbox adaptor plates (eg 60a )
reverse switch ataptors for the 60a into a manual tunnel
turbo manifolds
I guess the list goes on and on and on.
i guess that if you offered the same soft of stuff in the 1000 as the 1200 then you would certainly be on the right track
as far as demand goes, well I cant answer that.
Posted on: 2007/6/24 9:02
i wanna see the site but keep getting the stoopid can't find the
"The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings."
i used to be able to see it but get that now ??!@!! any help people ??
Posted on: 2007/6/24 10:00
sssute wrote:
If anyone has any sugestions on products that thay get hold of, let me know, i may be able to help you out.
Cheers Scott
There are many with drum brake utes & other non Coupe 1200's that could use a relatively simple & affordable front brake upgrade that was better than the 1200 Coupe/120Y disc brake, & did not involve a strut change. A bolt-on kit for drum brake 1200 struts.
Nothing humungous needed, but something from a larger 4 cyl car that is still readily available in wrecking yards would be good.
This would serve very nicely in just about all A series powered 1200's
Posted on: 2007/6/24 10:06
Love your Datsun.
Treat it well.
« 1 (2) 3 4 5 6 »
