wat kind of diff is in a datsun 720 ute
From nowra nsw
as it seez lol wot kind of diff is in a 720 ute
Posted on: 2007/10/14 12:01
Re: wat kind of diff is in a datsun 720 ute
From Perth WA
H190 in the back
R180 in the front (4WD)
Apparently the later ones (3/83 on) have LSDs?
Posted on: 2007/10/14 12:15
Chris...
From San Jose, California
The front is an independent suspension setup that won't fit easily in a 1200.
Posted on: 2007/10/17 6:04
-Daniel
From nowra nsw
um i think its a 2 wd not a 4wd lol i think its a 720 not shore ill take a picture of it on the weekend or is there an id plate or something in the engine bay lol
Posted on: 2007/10/17 8:20
Quite a regular
From orange nsw
It should say on the compliance plate what it is. I had an 85 model 720 4wd it did have an lsd in the rear and it was a good diff and strong too never gave me any problems. Not sure what the 2wd have though.
Posted on: 2007/10/17 13:27
From Toowoomba Q Australia
How does the track width compare with a 1200 and what ratios were available? Cheers
Posted on: 2007/10/18 2:02
From sydney australia
ratios - anything from 4.1:1 through to 5.1:1 or so, because there were 2wd manuals, 2wd autos ,4wds, diesels, etc, all seeming to need a different ratio. The track is wider than a 1200, but the axles are so tonka you wouldn't have any problems narrowing & resplining them, though you'd have to get the stud pattern changed.
Posted on: 2007/10/18 9:57
From Geelong, Vic
or use bluebird series 3 axles, should do the job
then get a nice 1500 ute alloy front housing
makes it one nice diff, but they are the same width as 200b adn bluebird diffs.....so maybe 2-3 inches wider a side at a guess
Posted on: 2007/10/19 3:34
