« 1 2 (3)
Re: any one interested in bolt in 6 point roll cages
From nowra nsw
yer i know wat ya mean thats wat im worried about maybe i should just make a couple for my own cars then maybe might do some for other cars and stuff ones iv got some experiance
Posted on: 2007/10/31 23:02
From nowra nsw
hay laney maybe r fastmotorsports mate can do ya one he is ment to have a lot of experiance at making cages and he probly already has the has like a dummie or done won for a ute already
Posted on: 2007/10/31 23:06
From Newcastle
iv been thinkin bout it i might just make a alloy 1 up myself later on down the track . . . cheers
Posted on: 2007/10/31 23:10
From Central Vic
Before anyone fits a cage remember there are three authorities that you need to comply with your state roadworthy body which I believe in most case state if your head can touch it its not legal for a road car.
and the CAMS requirements a very stringent involving how its welded where its bolted the style of the bolting process the materials have to be exactly the right type and thickness also the front legs can only have a set number of bends in them and the rear legs must be straight there has to be a diagonal in the main hoop and the list goes on. Once you fit a cage you must also fit a harness for CAMS events.
ANDRA also have a similar set of regulations that must be complied with
If you ever intend to register race or drag the car make sure you read the online documentation for each of these first
CAMS Rollcage Specs
Posted on: 2007/10/31 23:28
to buy or not to buy???? OK
This is the reason I have five coupes
From Canberra
I was under the impression that each cage had to be certified by someone from CAMS, not just the prototype then the rest are certified without inspection. Hence the no painting. Obviously they can be painted after they are certified.
Posted on: 2007/11/1 0:48
From Newscastle, Australia
basically when i got my car log booked I could have had anything in there once painted who would know....the guy from cams barely looked at the car. he just wanted to chat all day and gave me the ticket. For my own piece of mind though I followed the book...oh and by the way the car WAS rolled at Suttons corner at Oran Park and the driver (not me) emerged from the car onyl with his pride and wallet dented. Thank God.
Posted on: 2007/11/1 1:07
Dont die wondering.....
From bathurst nsw
for my say in the matter, i dont think they can be painted or powdercoated BEFORE cams approval because the guy that looks at the welds needs to see that they are of good penetration, without that they would fail the cage. but after it would be fine
as for road use im pretty sure that you tecnically can only have a half cage installed, that is that no bars are allowed to be, beside or in front of the driver, for obstruction of vision reasons (thats a load of bull$#!t if you ask me)
which is just the same as no road car can have a race harness installed unless it is the crappy standard seat belt buckle 4 point type
thats my understanding for nsw regulations
Posted on: 2007/11/1 2:03
My car gets me from A to B...Just faster ;)
From Geelong, Vic
i think it was the vic guide lines i was reading a while ago that said you could have full cage, as it gave measurements of how far away from the roof and a pillar it had to be and where it could come down in relation to the front door and such
and if your car had retractable seatbelts standard you cant have a harness in use when a police man sees you.....which is good for 1200 sedans with their non retractable belts
Posted on: 2007/11/1 4:10
From Brisbane, Australia
this is the way CAMS approval works:
log book/pre-race inspection is only to check eligibility of the car and that it has all the required safety gear.
the cage is registered with CAMS seperately, before the log book/pre-race inspection. A CAMS Cage Registration form has to be signed by the cage builder to certify the materials used and the welding and workmanship. A reputable cage builder should have the forms, otherwise you have to contact your CAMS state office.
Posted on: 2007/11/1 5:14
« 1 2 (3)
