Stumped?????????????
From Launceston,Tasmania,Aus
Allright,how is it done??????
How do i get the dash fascia off so i can fit my oil pressure gauge????????????
(i may want to fit a cd player later on aswell)
Posted on: 2003/4/23 13:42
Re: Stumped?????????????
From Brisbane Australia
Hi Dat16, it is quite straight forward, you will need a torch,philips head scredriver and maybe a pair of pliers.
1 push and twist off the h/light and wiper knobs and remover the alloy retaining nut.
2 undo the speedo cable
3 remove steering wheel(it get's in the way)
4 get in the most uncomfortable position you can think of and try and find the 2 screws at the bottom of the guages after about ten minutes crack the ####s and have a beer.
5 after removing the screws try and work out why the hell it will not come out and then remove the ciggy lighter.
6 have another beer and pull the facia from the top and it will (hopefully) pull out without to much trouble
and no I am not trying to be a smartasse
this is what I did the first time I tried it !!
good luck
Ade
Posted on: 2003/4/23 14:02
From Sydney, Australia
[Edit: Previous fella beat me to it..but you get the idea]
Ok...It's not easy... And it's sometimes best to remove the whole dash..especially when there's been wiring changes.
Need to disconnect speedo, dash loom (circular connector), remove stereo volume/tuning knobs and nuts/washers. Remove heater control knobs (screw is underneath) Remove light switch and wiper escutcheons (nuts), Remove connectors to tacho (if fitted). Remove trip meter knobs.Then there's 2 screws either side of the steering column that hold the facia to the steel dash frame. Use a stumpy medium phillips screwdriver.
I've saved you a few hours upside down under the dash, as I'm sure most of the people here have already experienced.
There you go..
Chris
Posted on: 2003/4/23 14:06
Not too shy to talk
From brissy & sometimes melbourne
Beer fix almost every thing. NOTE Almost
I need a ute to tow my boat
Thanks guys.
You will all be pleased to know i had already spent the mandatory hour twisted up like a pretsil under the dash.
Then i came to my senses,cracked open a beer and came here.
Posted on: 2003/4/23 14:15
Not too shy to talk
You have to reward your self, Other wise you'll end up crack"n" the s*#ts and braking something in witch will s*#t you more.
Stuff It Have Two
Posted on: 2003/4/23 14:23
From Canberra, Australia
remove the cowling aroudn the steering column too...
To remove the lights, wiper and choke knobs. Pull them all the way out. Then grip the stalk with needlenose pliers. Then push the knob down while gripping the stalk of the switch and twist the knob and it comes out...
I think next time I do this is my car that I will take pictures... IT took me ages to figure out too. probably would have gone insane in my dad didn't figure out the push and turn thing with the knobs...
Posted on: 2003/4/23 17:02
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Melbourne, Australia
huh, makes me laugh every time
me and my bro-in-law have a saying
"the stereo install position"
this involves folding the seat right back down then turning yourself upside down in the seat hanging your head in the footwell trying to balance a torch and about three tools twisting your arms around under the dash, its sooo frustrating sometimes
i actually found today that when installing the radio it makes life a lot easier if you take out the glovebox (only 4 screws inside the lid), then you can reach behind that area quite easily through the opening, this could have save me hours previously!
Posted on: 2003/4/26 13:13
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
1200rallycar wrote:
this involves folding the seat right back down then turning yourself upside down Quote:
in the ute no chance in folding the seat down gotta lay half your body on the floor and half in the car and look under the dash not soooo much fun
Posted on: 2003/4/26 13:17
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Brisbane
i dont know that the hell happened to that message i didnt do it!!!! did it on its own !!
Posted on: 2003/4/26 13:19
