Turbo a15
From whakatane, but most of the time canterbury NZ
I know it has been gone over before and once I ask this I am going to get 50 people telling me to use the search bar but If I was to build a blowthrough turbo a15 to run around 10 psi what would be a fairly detailed list of mods and things to buy that I would be looking at. Just so the info is in 1 place rather than scattered around the place as it currently is.
Edit: I just took my own advice and actually had a decent look in the search bar. haha. Amazing what you can find if you actually look
Would a s4/s5 rx7 turbo be a good match for an a15?
Posted on: 2008/1/14 19:45
Experience is directly proportional to the amount of equipment ruined.
Re: Turbo a15
From Sydney Australia
Posted on: 2008/1/14 20:43
Re: Turbo a15
Yeah I know. I found two articles that were exactly what id just asked for. As I said before, its amazing what you can find when you actually look.....
Posted on: 2008/1/14 21:09
Re: Turbo a15
From portugal
Nice!!! i was loking for somthing like this too... very god mates!
Posted on: 2008/1/14 22:53
Re: Turbo a15
Quite a regular
From Gore, NZ
I'm running a blow through set up with a 12a Turbo running about 11-12psi and I'm pretty sure that the engine is standardish. it makes good power but I'm going to upgrade the turbo manifold as it looks a bit small and a bit rangi but works.
Posted on: 2008/1/15 0:21
Re: Turbo a15
From perf
no the s4/5 is no good as it has an air ratio on the exhaust side thatis way too bigfor a little 1.5l engine. rotaries pump out a massive amount of exhuast gases comparedto a piston engine.
Posted on: 2008/1/15 0:59
Re: Turbo a15
cheers man. Im looking to do a budget build so getting a definate list of parts needed before I start buying is a must.
Posted on: 2008/1/15 1:33
Re: Turbo a15
From Canberra
see if you can find a turbo off a vg20, they are variable A/R so they might provide better response and power...
Posted on: 2008/1/15 1:38
Re: Turbo a15
From Christchurch NZ
I'd use a mitsibishi TD04, off an 1800cc lancer, or an AIRESEARCH M10 (aka Garrat T2) off an 1800 U11 bluebird. Should be able to find one cheap enough.
Posted on: 2008/1/15 6:59
Forced Induction!
Re: Turbo a15
hey force your using a weber right? I was just wondering what jets you are running and if I ran with a similar setup for a "base tune" would that be a fairly good starting point for my carb. do supercharging and turbo charging have similar fuel riquirements throughout the rev range?
Edit: also do draw through vs blowthrough have different fuel requirements?
Posted on: 2008/1/15 7:50
