« 1 ... 15 16 17 (18) 19 20 21 ... 28 »
Re: 1/4 mile time log.
From Chihuahua Mexico
CAR: 1200 sedan 72
MOTOR: vg30et
GEAR BOX: 5 speed v71c nissan
CLUTCH:
COMPUTER: 300zx 1988
DIFF: dana 30, 4.1
TURBO: T3/T4 63 a/r 57 trim stage 3
WHEEL/TYRE package: Mickey Thomson E/T 24.5X8X15
60 foot time:2.01
1/4 mile time: 12.19
MPH/KPH:
4650 ft over sea level, pemex gas 97 oct
http://www.nipponpower.com.mx/foro/showthread.php?t=39588
Posted on: 2008/1/31 3:29
From Christchurch NZ
Sounds like a mean machine! How did you fit the exhuast cross over tube between the back of the motor and the firewall? Theres not much room there.
Posted on: 2008/1/31 8:07
Forced Induction!
From Cape Town ZA
CAR: 1200 sedan
MOTOR: 4AGZE turbo
GEAR BOX: 5 speed W58 Toyota
CLUTCH: Spring centered copper button
COMPUTER: Dictator STD
DIFF: standard open 1200
TURBO: MasterPower T3/T4 .48ex a/r 50 trim stage 2 partno 80001
TYRES: Nankang 185x60x13
ELEVATION: Probably 10 foot above sea level
GAS: 95 unleaded pump from whatever station I drive by...
60 foot time:NA
1/4 mile time: 13.75
MPH/KPH:NA
Here's a piccy of the results... results
Posted on: 2008/2/5 7:48
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
From SE Melbourne
Finally did another update in the wiki
Posted on: 2008/2/21 0:08
Mildman, Datsunless
From Canberra
CAR: 120Y sedan
MOTOR: 4AGZE turbo
GEAR BOX: 5 speed T50 Toyota
CLUTCH: Spring centered brass button
COMPUTER: Autronic SMC
DIFF: BW 28spline 3.9
TURBO: Hi-flow Nissan T3 (fj20)
TYRES: Yoko A032R 205/60 13
WEIGHT: 1010kg
ELEVATION: 564m AMSL
GAS: mobil 98
60 foot time: 2.19
1/4 mile time: 13.86
KPH: 165
Posted on: 2008/2/22 3:56
From Canberra
update :)
CAR: 120Y sedan
MOTOR: 4AGZE turbo
WEIGHT: 1010kg
GAS: mobil 98
60 foot time: 2.1
1/4 mile time: 13.23
KPH: 171
Posted on: 2008/2/22 23:47
From Canberra
Is this using the trusty G-Tech Tyrie? Also were you running the avons on the runs?
Posted on: 2008/2/22 23:54
From Canberra
yep good old Gtech :) That was with pretty good yokohama semi slicks, but no burnout to warm them up.
Interestingly we put the Gtech in a 250+rwkw s4 rx7 and he did a 13.0. Makes me feel good that I'm only 0.2s behind a $10k 13bt
Posted on: 2008/2/23 0:06
From Cyberjaya, Malaysia
latest changes are Custom made extractor, and clutch mod.
my latest result... TQ increased dramatically and much earlier too! plus the TQ stay flat line throughout the power band till 5100rpm. the highest torque i got was 96.3Nm (during first run.. later runs get lower torque due to heated clutch, hence slip)
HP luckily stayed the same.
here is my quarter mile timeslip
this is my best 0-100kmh time! 12.5s!
all on
CAR: 120Y sedan
MOTOR: A15 stock (port matched)
GEAR BOX: 5 speed 60a
CARB : Weber 40DCNF12
CLUTCH: Stock clutch with lightened flywheel
DIFF: Charmant 4.1 diff
TYRES: Bridgestone Ducaro 13" 175/70
WEIGHT: 1100kg
my carb was severly flooded after third gear (shift at 5100rpm), any solution to this?
Posted on: 2008/3/17 3:29
From SE Melbourne
EDIT: Weird, ocphangaz pics only showed up when i went to reply about them..sorry
Posted on: 2008/4/6 15:11
Mildman, Datsunless
