A15 BORE
From Launceston, Tasmania
G'day all just would like to know how far you can bore out a stock A15 motor so that it's still reliable and strong.
I don't want it to be to extreme, but something that is streetable and is not going to wear out in a few years time.
I know they are 1488cc standard, what would be a suitable bore size. Can they be taken out to 1500cc with no drama's???????
Also what type of piston's do they use?
dished or flat top?
all comments greatly appreciated.
Posted on: 2008/3/11 1:17
Re: A15 BORE
From Darwin NT
theyve been taken out to 1600cc without problems so 1500 is easy
Posted on: 2008/3/11 1:19
current project 4x4 patrol...
Re: A15 BORE
From South Brisbane, QLD
<<< use the search there was a really big thread on this a few weeks ago even discussing piston's to use etc...
Posted on: 2008/3/11 1:30
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
Re: A15 BORE
From Sydney
I think my A14 is bored 120thou.. Wouldnt want to bore much more than that!!
Posted on: 2008/3/11 3:02
Re: A15 BORE
From Christchurch NZ
3mm-120thou is the max.
Posted on: 2008/3/11 6:55
Forced Induction!
Re: A15 BORE
The standard bore size is 76mm & there are three standard oversizes in half mm increments, so the factory supplies pistons out to 77.5mm.
Many racers regard 79mm as the 'racers standard' & while this pushes it over 1600cc, it's just a little, it's still legal in the1600cc class.
If your standard bore was worn 0.3mm, which is outside service limits, your smokey engine would displace 1499.72cc. Now that's 1500cc in my book, so to answer your question, yes 1500cc is achievable. The following bore sizes will give you the capacities indicated.
First oversize 76.5mm= 1507.6cc
Second oversize 77mm= 1527.4cc
Third oversize 77.5mm= 1547.3cc
If you want reliability & serviceability in a street engine, then any of the sizes above should do the job just fine.
Posted on: 2008/3/11 8:15
Love your Datsun.
Treat it well.
Re: A15 BORE
From sydney.nsw
I have a set of A14 80mm forged pistons with rings ,the block must be sonic tested and bores offset to suit , can stroke or destroke to suit A15 for more info ring ernie 0412 864 741
Posted on: 2008/3/11 9:01
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: A15 BORE
Also what type of piston's do they use? dished or flat top?
by bige on 2008/3/11 19:01:23
I have a set of A14 80mm forged pistons with rings ,the block must be sonic tested and bores offset to suit , etc.
Running an 80mm bore is pushing it right to the limit & then some in my view, & as it says in the post, block must be offset bored. The cylinder walls can get mighty thin at the ends & in the center of the block when this happens.
Even 79mm is pushing your luck in many cases. The problem mainly centers around the amount of material between the end pairs of cylinders for the head gasket to seal on. It starts getting awfully thin at these sizes. Awfully thin indeed, yet most racers seem to hold together most of the time.
Offset boring helps even at this size.
I doubt that thid bore size would constitute 'reliable' or 'not extreme' in a street engine but they will push an A15 to 1649cc
To answer a question I forgot to address earlier, the stock A15 pistons are not only dished, but have the deepest dish of the stock A series family in order to keep the compression ratio the same as the others.
I've ordered 78mm pistons for my A13 & this should be a good safe size for this engine as it's only a half mm larger than the third/largest standard oversize.
Posted on: 2008/3/11 15:53
Love your Datsun.
Treat it well.
Re: A15 BORE
From sydney australia
i agree with Dodgeman that going to 80 mm isnt something i'd do for a road engine. I assume the 80 mm pistons were for a speedway engine, so they might run a bit cooler due to the fuel. The constant heat cycle of road use would probably create bore shift & cause blow by. So maybe use the largest stock pistons at 77.5 mm. When the bore wears you can then get a half mil clean up & use the 78 mm pistons. Get 2 lifes out of the engine. The philosyphy of maximum bores for race engines is because if the bore ever wears out, you get another block. A friend with an LJ Torana has problems because all the engines he finds in wreckers & such are at the maximum overbore. Also note the pistons suit an A14, to get it to fit an A15, you have to machine the piston tops to even get a flat top. Not something i'd be doing if i wanted a reliable engine, weaken the pistons & you get still get an astronomical compression ratio.
Posted on: 2008/3/13 2:09
Re: A15 BORE
From Burbank, CA
there's an A15 that manages to get 1608 so it's one of the very few A16's.
Posted on: 2008/3/13 2:49
|||\ 81 KPB310 /|||
