need to no upgrade of eng mounts!!!!!
hi people ive been told that there is a differant eng mount that are almost the same as a12 ect, i far as i no they are out of a cortina but not sure wat type any help would b good
thanks nick
Posted on: 2008/8/30 13:18
Car free
Re: eng mounts
From Christchurch NZ
Rb20 ones are bloody close. They are the same thickness, but have a much larger area. Although they dont fit the Xmember without minor modification to the flange upon which they seat. Also the studs are directly opposite, opposed to the slight offset of the A series mounts. So there's a need to slot the holes slightly.
Posted on: 2008/8/30 21:32
Forced Induction!
Re: eng mounts
From Brisbane, Australia
Posted on: 2008/8/31 3:26
Re: eng mounts
From Coondle, WA Australia
those are for a jag arnt they.
Im using the same ones.
Posted on: 2008/8/31 4:23
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: eng mounts
From Brisbane, Narangba
Best upgrade the cortina mounts. Stock mounts are puny. Used to go through them as reguarly as underpants. 2years on the cortina mounts show no signs of failing what so ever.
Posted on: 2008/8/31 5:21
Re: eng mounts
From Melbourne, Australia
which model cortina is the question???
they arnt just sitting in wreckers for us to investigate anymore
Posted on: 2008/8/31 7:09
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: eng mounts
Use the part number in the picture above. They are the correct ones.
Posted on: 2008/8/31 9:16
Re: eng mounts
bump
Posted on: 2008/9/16 11:55
Car free
Re: eng mounts
From Darwin NT
those mounts are v8 rover ones about $140 a pair from rapeco i am using them in my a series turbo build....
Posted on: 2008/9/16 12:49
current project 4x4 patrol...
Re: eng mounts
From SE Melbourne
I use these same "hockey puck" mounts as the Americans call them, in my CA
Posted on: 2008/9/16 12:51
Mildman, Datsunless
