Browsing this Thread:   3 Anonymous Users
H165 into 73 Sedan
From Sunshine Coast, QLD
Hey guys got meself stuck on the smallest thing, putting the h165 in me sedan got the low down on the install but the shock mounting brackets r diff on the ute and the ones from the h145 wont fit the h165 axle, what do i do here to rectify my problem???? Cheers
Posted on: 2009/1/13 10:42
Re: H165 into 73 Sedan
From Darwin NT
mod the ute ones to suit
Posted on: 2009/1/13 10:44
current project 4x4 patrol...
is that the only way as the ute ones mount on angles, not keen on chopin and welding, can the sedan ones flange out??
Posted on: 2009/1/13 10:46
From Snohomish, WA USA
Cut and weld or find someone to do it for you. I am modifying one right now but it is out of a 411 which is becoming a pain in the butt. It will work out in the end but it has been a lot of work so far.
Posted on: 2009/1/14 2:08
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
He's probably got the H165 rear axle housing that is made for a 1200 (common in Australia). If so, there no need to cut & weld, just obtain the bottom plate brackets that match.
Posted on: 2009/1/14 2:59
From Christchurch NZ
You'd have to cut the spring pads off your old diff, and weld them onto your new one. Or get some box section, cut it in half, and weld it to the spring pad, but leave enough meat on the box section to attach the shock to.
Posted on: 2009/1/14 3:44
Forced Induction!
yeah the h165 (aussie ute) axles housings r thicker than that of a h145, ill just cut them off the sedan and make the ####ers fit, 10kg ball peen hammer should get the required result then weld in place off the ute ones, or the box section sounds good, ne idea of thickness 5mm 6mm???
Posted on: 2009/1/14 6:33
This is a tough one.
UTE: shocks mount at an angle to the plate below the leaf spring, like a Coupe
SEDAN: shocks mount straight up, to the bracket above the leaf spring. This sedan bracket (shown at top right corner of this pic) does not exist on a Coupe or Ute.
Shock Mounts
Also, the sedan doesn't use the same housing flat mounts...the ute housing is more like the coupe housing:
Comparo: Rear Axle Housing
Posted on: 2009/1/14 7:18
From Geelong, Vic
you can make the sedan mounts fit pretty easily, i just squashed them in a vice slightly so they opened up enough to fit the ute axle tube
or you could just pull out a grinder and grind a bit out of the mount so its the right shape where it meets the diff
Posted on: 2009/1/14 7:35
did the standard u-bolts and mounting plates all work just using the sedan mounts flanged?? Gona start and finish this weekend hopefully
Posted on: 2009/1/14 11:23
