« 1 (2) 3 »
Re: Blew another engine
From South Africa, Bloemfontein
E15et, is this the Nissan EXA turbo engines?
Posted on: 2009/2/26 9:05
1977 Datsun 1200GX
From Christchurch NZ
I run a 200mm clutch, a 63a dogleg 5spd, and an h165 diff with a spring loaded locker modification.
Posted on: 2009/2/26 9:10
Forced Induction!
From Armidale N.S.W
We had an A12 that was happy to rev around 7,000 and that was just a bit of backyard port work and double valve springs. With a mild cam and 32/36 weber. it was running fine till i retired it for an A14. One day i pulled the head off and found Number 3 piston had spat the rings into the head like pickin glass out of wounds, yet it still ran fine. They are hard to kill the A series i miss me little A14 in some ways.
Posted on: 2009/2/26 9:13
73 1200 wagon SOLD
From Darwin NT
yes the e15 is the nissan exa motor
Posted on: 2009/2/26 10:07
current project 4x4 patrol...
From perth
blower belt prob came off because engine failed first.
boost + cast pistons + rpm = shrapnel
build a better bottom end to take some boost
Posted on: 2009/2/26 11:36
From Snohomish, WA USA
Sorry to hear that Bart.
I am officially back on the road with my H165 (locked rear diff). I've been rodding on it for the past week and that H165 has bee holding up. Haven't hit the Nitrous yet. I've had the bottle out of the car. Moving the bottle from the passenger seat to the trunk to satisfy track safety rules. Only thing left is to weld up the bottle bracket in the trunk.
It took me a while to locate some new wheel bearings for the H165 and also had to modify the mounts. Ends up I didn't have to shorten the driveshaft and only needed 8mm wheel spacers (I did replace the wheel studs with longer ones).
Its great to be back on the road and best thing is, drag season starts next month!
Posted on: 2009/2/27 4:55
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
great to hear Ernie!
My last motor only ran 7psi, and that went fine for two and a half years. I think wat killed that was holding it wide open for too long in top gear on a really hot day. The motor which just died was running 15psi, and greatly limited timing. (22' with a locked dizzy) TBH, I was amazed by the reliabilty of it up to the point it died. I should be outside pulling it out right now, but i forgot to bring my tools home. There is a chance that it may be repairable. The "good" motor will be getting ARP's for certain when I rebuild it. This was only a temporary engine.
Posted on: 2009/2/27 5:23
Forced Induction!
From Perth WA
main thing is u had fun doing it
Posted on: 2009/2/27 5:55
hey can u send me some specs on the motor ur buildin for the blower setup
ive decided not too sell mine gonna finish the a14 bottom end i have and bolt her in
also do u run water/meth injection??
Posted on: 2009/2/27 8:52
Car free
Not yet.
I pulled it down just before. turns out a piston disintergrated, bent two pushrods and took the head off a valve. very ugly.
Posted on: 2009/2/27 8:56
Forced Induction!
« 1 (2) 3 »
