what oil ?
From durban, south africa
hey guys,
what oil are you guys running in your cars??
i'm going to use magnatec, what do the critics think
nicholas
Posted on: 2003/8/4 13:31
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: what oil ?
From Brisbane
i got told not to use it with my motor, i use Penrite HPR30 this was advice from my motor builder (Feral) expensive but qualtiy,
Posted on: 2003/8/4 13:39
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Re: what oil ?
From Melbourne. Vic
I agree i run penrite in the coupe on the recomdation of Jeff Taylor!!
so it cant be that bad
cheers
stevo
Posted on: 2003/8/4 14:37
www.cm510/datto1000
Re: what oil ?
From Perth W.A
i use penrite now. but with my old engine that used more oil than petrol i used the closest i could find which was from the cheapm section. i was suggested penrite by my tuner
Posted on: 2003/8/5 3:07
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: what oil ?
im using magnatech now. its okay, oil is oil in that price range. if i could afford it i would use penrite (i did in my mini) as it is really good stuff in older designed motors.
Posted on: 2003/8/5 4:41
Re: what oil ?
I always used Penrite. HPR30 in the datto, HPR40 in the rotor.
My rotor builder uses penzoil, but says penrite is good too.
I don't use any castrol oils, they have always seemed to make the car run rough and sludge up really easily.
Posted on: 2003/8/5 5:00
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
Re: what oil ?
Quite a regular
From melbourne
It looks like Penrite is the popular choice although not necessarily the one to use.I have used nearly every brand of oil in many different motors over the years and quite frankly have never noticed any major differences with exception to synthetic V mineral,or very thin V pea soup.My Datsun mechanics(datsun race car builders of 20 years) swear by and use Valvoline in their cars aswell as all their customer cars.At the moment so do I and I believe XLD plus is as good as any in a Datsun.
Posted on: 2003/8/5 11:39
Re: what oil ?
From Mudgee NSW Australia
I used to run penrite HPR30 on my old A series I changed to mobil 1 for the CA18 but changed to shell ultra helix as it used a fair bit with mobil one. for soem reason. Its good now with Shell. A good gearbox oil is the castrol VMX80 good for japanese boxes just m,ake sure your sealsare in good nick as its pretty thin and can leak a little.
Cheers Andrew
Posted on: 2003/8/5 11:49
If In doubt run more BOOST
Re: what oil ?
I'm partial to dinosaur oil myself. It is inexpensive, and my street engines have all gone over 100k miles (160k km)-- burning no oil. All this without using synthetic oil.
They do tend to leak though. Does synthetic cause less gasket leaks?
Would synthetic make a typical engine last twice as long? Mine usually start burning oil around 150k miles.
Posted on: 2003/8/5 20:21
Re: what oil ?
Once I read in a car magazzine that once you use synthetic, you should not go back to regular oil(within the same engine) because the synthetic oil penetrates the gaskets and when going back to regular(non synthetic) oils, this oils do not bond to the gaskets in the same way, but since synthetic oil bonded to the gaskets already and regular oils do not, then the space left by the synthetic oils is an invitation for leaks.
I read it, I am not making this up, but nobody ever confirmed me this, everytime I mention this fact, nobody ever heard of it, any knowledge over there?
Jaime
__________________________________
Posted on: 2003/8/6 0:01
