(1) 2 3 »
What diffs have you put in a 1000?
From Sydney
Ive done a little research as In need to put a diff in my 1000 coupe. Im not really after measurements or specs but more feedback.
Has anybody actually put a ute diff in? What did it look and drive like? What wheels did you use?
Has anybody put a skyline diff in? Was it to heavy? Was it overkill?
Posted on: 2009/7/9 23:06
Re: What diffs have you put in a 1000?
From Perth
Getting a BW78 (Skyline-Falcon-Pintara-Commodore) done now for mine
4.11 LSD 28 spline
Overkill... but... won't break this one
Posted on: 2009/7/9 23:37
From sydney australia
I've used a H165 ute diff in a 1000,the mounts had to be moved in about 50 mm each side. I used front wheel drive offset wheels & the wheel was common enough that I was able to get rear wheel drive offset wheels for the front. The later wheels to suit bluebirds or pintaras are pretty neutral,so you could probably use them.
Posted on: 2009/7/10 0:41
From Armidale N.S.W
Could be way wrong but im pretty sure steveo put a ute diff in a 1000 pretty recently.
Posted on: 2009/7/10 0:57
73 1200 wagon SOLD
From Darwin NT
gav i have a 1200 ute diff with bluebird discs should go in under a coupe easy as they have a heap more space then the other models. i did move the mounts but was out by about 5mm ... bugger..... but they can be cut and moved again sure matt could do it for you if your intrested? its all together complete center has been welded (locked) so it would probably be adviseable to get another centre for the street
Posted on: 2009/7/10 1:05
current project 4x4 patrol...
From Coondle, WA Australia
Im with you Dattoman, I am using a r31 skyline diff 28 spline unit. 3.9 LSD for me though. Yeah it may be overkill, but it wont break either like you said. It would have to be the biggest Diff you should consider for any datsun with almost any engine/gearbox combo.
Pretty much everything needs to be modified to fit, so just pick something cheap. That was my theory anyways.
Posted on: 2009/7/10 2:47
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
I have to disagree, Id rather something light weight and available
and although the BW are common and avail with many ratios they are
a heavy bugger defeating the reason to own the lightest datsuns mass produced.
I consider the B series a unique and important collectable and if you
can spend some money on this part of the build to compliment its lightweight.
I suggest an all alloy h190, modified h150 (usually strong enough for good
drivers), Alfa Romeo 105 (3.4, 3.6, 4.11, 4.3, 4.5 ratios avail) or a second
hand Winters or other similar quickchange for hotrods.
Gav since you are running one of the lightest engines ever made for cars
then please consider keeping the rest of that blue coupe featherweight.
Posted on: 2009/7/10 3:12
D you are right about weight. Yeah the BW is a heavy bugger for the datsun, and sure there are plenty of other options, but it all comes down to cost i spose. The winters units require you to sell a kidney, and alfa stuff is (i am under the impressions from an alfa mate) hard to track down cheaply, but I could be wrong on that front.
I considered the H150/H190, but they didnt come in an LSD option commonly, and after some ringing around in Perth I didnt find any that were usable. It sems that the only H190s I could find were from the 720 and they didnt look flash. the BW despite its weight wins on all the other fronts in my opinion.
All up my BW cost me $300 for the diff, $750 to modify to suit, and $350 for a rebuild. so $1400 for a new LSD 3.9 ratio cut to suit and unkillable, if a little heavy.
Posted on: 2009/7/10 3:23
From Sydney
I wanted to keep it light, thats why I was leanning towards the 1200 ute diff but hate the idea of finding wheels to compensate the increased track. Can you cut these diffs down?
Posted on: 2009/7/10 4:57
of course you can cut em down. But its not much.
Think you may need a new prop shaft as well.
Posted on: 2009/7/10 6:45
(1) 2 3 »
