is this recommended?
From dominican republic
i want to adapt an electric fan in my stock ute is this recommended? i have been told that this give more power to the engine is that true? what type of fan can i use?
Posted on: 2009/8/27 2:24
Re: is this recommended?
From Geelong, Vic
you would use an automotive thermo fan
they free up a bit of power as they only run when they need to unlike the current fan that would be running all the time
a thermo fan wont usually cool as well as the engine fan as its alot less powerful. engine fan has atleast 50hp making it turn....electric one doesnt
Posted on: 2009/8/27 2:29
maybe adapting a big one and put it direct, i think it will work, my friend´s 120y have one like this, but im no sure if it will work well
Posted on: 2009/8/27 2:57
From Geelong, Vic
oh yeah they work, just that they wont ever work as well as the stock one
ive got 2 12 inch thermos on my car and they seem to do the job nicely
can probably fit a single 12inch with the stock radiator
Posted on: 2009/8/27 3:10
well i´m going to ask my friend to tell me what type of fan is he using, and will put it on to my ute to see what happens, thanks for the help dude
Posted on: 2009/8/27 3:27
You'd be lucky to gain 1-2 bhp from swapping to an electric fan. and when the fan is off, the power to drive it comes from the alternator, so the power output under those circumstances would be the same. The only way it would be less is if the electric fan moves a hell of a lot less air.
Posted on: 2009/8/27 4:36
John McKenzie
From Vancouver, Wa
Give it a try, you can always switch it back it you don't like the outcome. remember it's all trial and error.
Posted on: 2009/8/27 5:25
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
From sydney australia
Some 120Y's came with a plastic shroud that fitted to the radiator. It was a 2 piece. If you could find something like that, & fit say the 10 inch fan from an N12 Pulsar so air was drawn from the whole radiator, it'd probably work well. Something I was going to try with my B310 Sunny was get a fan sender from an N12 Pulsar & mount it in the head opposite the temperature guage sender. Most later A series heads have a fitting that is part of the emissions control, I was going to use that outlet, with a relay to run the fan. That way the fan is only running when the engine is hot.
Posted on: 2009/8/27 5:39
From Lethbridge, AB, Canada
I just switched to a Subaru Justy 4x4 rad, the electric fan is actually the perfect size to fit inside the opening in front of where the radiator fits... on the outside of the rad, not the inside. (grill side not engine side)
I'll see how it works, I needed to get rid of the stock fan so I could run intercooler/piping etc.
I will get pics soon.
Posted on: 2009/8/27 7:37
'73 Datsun 1200 Sedan Turbo A12
Yes you can save 2% horsepower.
But you have to be really careful. The stock setup won't overheat, but many electric fan conversions have. Never fear, if you do it right it works just well.
Thermo (non-electric) fan:
Some Datsun 210 (B310) came with factory Datsun Electric Fan, see Tech: Electric Fan.
Posted on: 2009/8/28 6:34
